Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. May 9, 2019 at 1:50 PM
    #1461
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    You only need to worry if you are met with resistance trying to pump grease or one or more of the seals doesn't purge.
    The former is likely a bad zerk. The latter can be a bound up seal. Rotating the shaft will usually allow it to purge. If it still persists in not purging, it's a possible indicator something's wrong. Up to the individual at that point if they want to replace or run it until it becomes a nuisance.
  2. May 12, 2019 at 1:02 PM
    #1462
    Sasquatchian
    Sasquatchian Well-Known Member
    My '93 4x4 actually had a greasing diagram on the back of the driver's side sun visor. I drove that one 300,000 miles on the original u-joints without a single problem before I sold it. I greased them every couple of years with whatever grease was in the gun, usually Mobil 1. I got under my 2018 OR DCLB AT yesterday (build date June 21, 2018 in Tijuana) and there was a grand total of exactly one zerk at the front of the front driveshaft. Nothing anywhere else. I went back and triple checked every joint to be sure I wasn't missing anything, hand rotating each joint while looking. And for those who don't know already, all you have to do to be able to rotate the rear driveshaft by hand (and mine has a Spicer Balanced Driveshaft label on it) is to jack up only one rear wheel so it just clears the ground while you shut the engine off with the transmission in neutral. Then, when you turn the driveshaft, that wheel will turn as you rotate the shaft.
    It seems like, after slogging through this entire thread that there are quite a few assembly variations over the last few years so the only way to really know is to get underneath and carefully inspect.
    TRDSport10 likes this.
  3. May 12, 2019 at 1:55 PM
    #1463
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    You missed 1…. At the rear of the front shaft.... Remove the shield and there it is....!!:thumbsup:
    shakerhood and Vbpiper like this.
  4. May 12, 2019 at 2:55 PM
    #1464
    Sasquatchian
    Sorry guys. No I did not miss one. I took the shield off and turned that sucker 360 a couple of times. Nada.
  5. May 12, 2019 at 4:11 PM
    #1465
    over60
    Muskoka, Ontario
    what year is yer truck..??
    Helps a lot if you put that info in your signature.
    OOOpppS.. sorry I now see its a 2018......WTF.
  6. May 12, 2019 at 5:01 PM
    #1466
    Sasquatchian
    Well, I did put the exact date it was built in my original post this morning. And I know that because it was special ordered and they notified us the actual day it was built - June 21, 2018. So maybe this is a summer solstice thing, I don't know, but I've been greasing zerks for something like fifty years now and I do know what they look and feel like.
    Vbpiper likes this.
  7. May 12, 2019 at 5:35 PM
    #1467
    Not_Sure
    Not_Sure Well-Known Member
    J
    NC
    2019 Model 7545 in Silver Sky
    Bike rack
    LOL, I told my wife the same thing! :)
  8. May 12, 2019 at 11:18 PM
    #1468
    Sasquatchian
    It seems that there was at least one person here several pages back who reported having only one zerk as well. This is not something I'm going to spend much time thinking about.
    sierra141 likes this.
  9. Jun 20, 2019 at 12:12 PM
    #1469
    Raistlen0
    Raistlen0 Well-Known Member
    PA
    2017 TRD Sport DCLB AT QS
    I think its there just painted black so hard to see.
  10. Jun 20, 2019 at 12:33 PM
    #1470
    Sasquatchian
    Then I would have been able to feel them with my fingers, which I also stuck in there, while looking with a strong flashlight. Nada.
  11. Jun 20, 2019 at 1:06 PM
    #1471
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Maybe 1 got broken off.
  12. Jun 20, 2019 at 1:15 PM
    #1472
    SandyTaco4x4
    SandyTaco4x4 Well-Known Member
    Southern CA
    17 DCSB/AT QS TRD Sport 4x4
    Is this what my manual means when it says "lubricate propeller shaft"?
    TheGoat likes this.
  13. Jun 20, 2019 at 7:51 PM
    #1473
    Sasquatchian
    Dude - NO. Nothing has broken off. You're grasping for someone else's straws and just guessing.
  14. Jun 20, 2019 at 8:02 PM
    #1474
    tcjacado
    tcjacado Well-Known Member
  15. Jun 20, 2019 at 8:06 PM
    #1475
    MacStrong
    MacStrong Well-Known Member
    Justin
    Oregon
    2019 TRD sport DCSB
    None... yet
    Shit, just seeing this thread. Is this still an issue on 19’s? I’m like 6500 miles in and this post is freaking me out lol
  16. Jun 26, 2019 at 12:39 PM
    #1476
    jcfergus
    jcfergus Member
    Jim
    Roseville, CA
    2019 TRD Sport Access Cab
    TRD Pro wheels (gray), Snugtop shell
    I just checked my 2019 TRD Sport 4X4. No grease fittings on the driveline.
    One would have to presume that sealed bearings are properly greased, wouldn't one?
  17. Jun 26, 2019 at 12:41 PM
    #1477
    shakerhood
    Southern Ohio
    Did you check the front driveshaft?
  18. Jul 17, 2019 at 10:41 AM
    #1478
    The Smith
    The Smith Well-Known Member
    Trinity Alps
    '17 4x4 V6 SR5
    My 2017 SR5 DCSB 6-cylinder 4x4 has 0 zerks. I couldn’t find any, and I had a friend with more automotive experience than me check as well.
  19. Jul 17, 2019 at 12:15 PM
    #1479
    sierra141
    sierra141 Mean Green
    New Mexico
    18 TRD Offroad
    Kings
    Mine is a 2018 only two zerks as well. Other ones are sealed u joints maintenance free.
    shakerhood likes this.
  20. Jul 17, 2019 at 12:35 PM
    #1480
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    Mine had 2 zerks, one in each u joint in the front driveline. You have to look closely.
    shakerhood and over60 like this.
