Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Jul 17, 2019 at 2:06 PM
    #1481
    crazyfingers
    crazyfingers Soft Sweet But True
    Chuck
    Annapolis, MD.
    TRD Off-Road DCLB Quicksand
    TRD Pro 17' Rims With Goodyear Wrangler DuraTracs Toytec 3" Boss Aluma Series With OEM HD Leafs. With A GoFast Camper
    Thanks for the feedback. I no longer have a SR5 I traded it in. I now have a 2017 TRD off-road Long Bed. Does anyone have any idea of how many there are on a 2017 OR?
  2. Jul 17, 2019 at 4:05 PM
    #1482
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Congrats on the new truck..... You should have the 2 on the front shaft (if it's a 4X4)..hehe
    shakerhood and crazyfingers like this.
  3. Jul 17, 2019 at 4:42 PM
    #1483
    crazyfingers
    Chuck
    Annapolis, MD.
    Thanks @over60 it a much better ride for sure, and thanks for the tip. I will be checking them out this weekend. I forgot they do offer the off-road in a 2x4 which is crazy but each to there own I guess. And Yes mine is a 4x4.
  4. Jul 17, 2019 at 4:53 PM
    #1484
    opeesha
    opeesha Well-Known Member
    C
    2018 SR5 4x4 DCSB
    Found and pumped full of new grease two zerks. Took like 6 full pumps just to get what little of the old grease that was in there to start coming out. Did it 5k miles later only needed one pump to get seepage so I think I can go 10k without checking them again. Two bolts on one set of U bolts were loose but only marginally
  5. Jul 17, 2019 at 6:48 PM
    #1485
    TRlPPlN
    TRlPPlN Pavement Cruiser
    Bay Area, CA South SF to be precise
    MGM DCSB 09 DC TRD Sport 4x4 - Family Hauler
    Just check every oil change. pump until new grease comes out and not just the old grease
    The Real Moondog likes this.
  6. Jul 17, 2019 at 8:27 PM
    #1486
    opeesha
    C
    2018 SR5 4x4 DCSB
    Maybe I should’ve been clearer, 6 pumps to get the old out and then for the new to start coming out. Then when I rechecked recently at 9k miles it took 1 pump to see new grease. But yes this is great advice. Out with the old in with the new!
    over60 and TRlPPlN[QUOTED] like this.
  7. Jul 28, 2019 at 6:37 PM
    #1487
    G-Dawgg
    G-Dawgg Well-Known Member
    Torrance, California
    '17 DCSB Super White TRD OR 4X4
    Can anyone recommend a narrow type grease tip or coupler? Im having a hard time greasing my u joints with my stock grease gun tip.
    What are you guys using?
  8. Jul 28, 2019 at 7:09 PM
    #1488
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I grinded the tip down and it makes it easier to get to those front 2 zerks.
    over60 and G-Dawgg[QUOTED] like this.
  9. Jul 29, 2019 at 6:45 AM
    #1489
    G-Dawgg
    :proposetoast: Just saved me some bucks! Thank you sir!
    shakerhood[QUOTED] likes this.
  10. Jul 29, 2019 at 7:16 AM
    #1490
    NC_Pinz
    NC_Pinz Well-Known Member
    North Carolina
    2018 Cavalry Blue TRD Pro
    Also, I upgraded to a grease gun that has a single hand pump versus the longer handle. I use one hand to put pressure on the zerk fitting to insure the grease goes in.
  11. Sep 22, 2019 at 7:57 PM
    #1491
    mario0622
    mario0622 New Member
    2017 trd sport
    Do all 5 purge? I was reading somewhere that one should only take 2-3 pumps because there no room for excess to escape. Might be for 4runners only.
    NC Rick likes this.
  12. Sep 23, 2019 at 11:59 AM
    #1492
    TRlPPlN
    I hope that helps.
  13. Oct 3, 2019 at 3:35 PM
    #1493
    MyWifesTaco
    MyWifesTaco Well-Known Member
    OKC/Southern Colorado
    2019 Tacoma Cavalry blue 4cyl access cab 4x4
    TRD pro grille .
    Thank you for the video TRIPPIN strangely satisfying to see the grease purge
    I just checked today when doing the first oil change and rechecking the transmission fluid
    It took about 6 easy slow pumps on the wife's Taco to get the job done :rofl:
    I mean the front driveshaft zerks needed about 6 pumps of grease to purge and a side note they still had factory paint over the end and the check ball so they never were touched after the assembly and paint down on the assembly line
    So basically in Dana/Spicers very own video they basically throw their own "lifetime " u joints that are chosen by Toyota from the factory under the buss since there is no way to know if they are actually greased proper or not
    Would I be crazy to just get some Spicer joints and put them in ?
    If someone could share a Spicer or even a Orielly Precision PN# for a center grease for the 17 and up that didn't get them
    Thanks in advance Mike
  14. Oct 3, 2019 at 5:37 PM
    #1494
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    U-Joints, generally, do not suddenly explode from lack of grease. Wait for the sealed OEM ones to wear out, then replace them with ones with a grease fitting.
    https://m.youtube.com/watch?v=YVWC_hgS1wM
    Annoying host, but true facts. 5 minute mark for the wiggle test.
    https://m.youtube.com/watch?v=5gOeBE-ylQw
  15. Oct 8, 2019 at 7:35 AM
    #1495
    Rocky.Mtn
    Rocky.Mtn Well-Known Member
    Canada
    2024 Tacoma TRD OR (Hybrid)
    Greased the front 2 on my 2017 last night. Purged a lot of black.
    I've been having some clunks and a high pitch squeaking while moving (still trying to track this down, could be leaf springs) and hope this will help!
    Thanks for the info on here. I had no issue getting the gun fitting onto the zerk using the Lumax Grease Gun. The longest part was figuring out how to reattach the heat shield.
  16. Oct 8, 2019 at 8:32 AM
    #1496
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    True...
    99% of the ones I've seen fail on TW start chirping.
    On inspection, the needles are completely rusted away.
  17. Oct 26, 2019 at 2:21 AM
    #1497
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    I watch a lot of his videos. Super informative. His blinker fluid video had me dying lol
    Stocklocker[QUOTED] likes this.
  18. Nov 24, 2019 at 5:32 PM
    #1498
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    My mechanic neighbor and I only found one zerk on the front u joint, couldn't find any other locations...anyone got photos of the second front zerk for 2017 4x4 trd off road?
    wrekd619 likes this.
  19. Nov 24, 2019 at 6:32 PM
    #1499
    Stocklocker
    17TRDORDCSBAT
    There are two u-joint in the front driveshaft. One at the transfer case, and one at the front diff. On a 2017, both have a grease nipple in the center of the spider.
    over60 and shakerhood like this.
  20. Nov 25, 2019 at 9:24 AM
    #1500
    Greg.Brakes.Tacos
    Greg
    wanna be mods
    That's what I kept reading (prior to doing this with him last night), but we rotated the entire section by the T-case and couldn't find a it, then I found a reference to the sheild and a 12mm bolt, but we pushed forward and went ahead with the rest of the diffs and t-case, ATF and exhaust chop. We'll check after another ~1500 miles while doing the oil change.
    A photo or link to one with the t-case one would also help (but we didn't see one on any side of the spider gear/u-joint).
