Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Nov 25, 2019 at 10:10 AM
    #1501
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    It may be that you have an odd duck. The weird thing, is the T-case nipple is hard to see, even with the heat shield removed. Something about the angle makes it difficult, but if it’s not there on yours it’s not there.
  2. Nov 25, 2019 at 10:27 AM
    #1502
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    I guess they're consistent on the lack of consistent zerks on 3rd Gen TRD OR 4x4
    Stocklocker[QUOTED] likes this.
  3. Nov 25, 2019 at 11:02 AM
    #1503
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    It will likely vary between 2WD/4WD/Frame size/Diff size/Production Batch, etc.
    Still, it can sometimes be difficult to see the fittings, so having pics of the potential locations will make it easier for people to spot.
  4. Feb 2, 2020 at 9:34 AM
    #1504
    Tacostastegreat
    Tacostastegreat Well-Known Member
    East Coast USA
    Tacoma TRD OR
    Zero........ Zero zerks on my 2020 TRD OR 4x4. I was not expecting to find any on the rear shaft (confirmed) but was expecting to find 2 zerks on the front shaft. Removed heat shield and rotated shaft many times, there are no zerks on my front shaft on either end. Front Spicer Dana shaft B = no zerks at all. Anyone want to buy an unopened Valvoline Synpower NGLI 2 grease canister? LOL.
    C41n, VanGo3, bbartol and 3 others like this.
  5. Feb 2, 2020 at 11:50 AM
    #1505
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    Careful...they might be hiding. They are NOT on the ends of the bearing.....they are in the crotch and very hard to see...!!
  6. Feb 2, 2020 at 12:49 PM
    #1506
    Tacostastegreat
    East Coast USA
    Tacoma TRD OR
    I hear you. Rotated the shaft around with a strong light, looked from different angles, physically stuck a finger into all the available crotch/interiors and there was nothing. I'll check again but I am 99% sure my 2020 has non-servicable front and rear propeller shafts.
    Edit: checked again, no zerks. Went back and looked at the phots of the front shaft zerks on this thread/location of the zerks inside the crotch/interior of the joint. Nope, nothing on mine, I checked every single angle and it is completely sealed up. I did make a video but it did not turn out very good.
    pop.tremuloides, C41n and SuperBad like this.
  7. Feb 4, 2020 at 12:38 PM
    #1507
    over60
    Muskoka, Ontario
    "WELL KICK ME IN THE SHINS AND CALL ME "HOP-A-LONG".
    Never gave that a thought; however Toyota is saving another $5.00 per truck, I guess..... Here's to you, mother Toyota..:crapstorm::crapstorm:
  8. Feb 4, 2020 at 1:13 PM
    #1508
    Tacostastegreat
    East Coast USA
    Tacoma TRD OR
    Yup. I guess if I can get 200,000 miles without drive shaft problems, I won't complain. But zerks make it so easy to add nice, clean, fresh grease.
    over60[QUOTED] likes this.
  9. Feb 4, 2020 at 5:07 PM
    #1509
    Joisey
    Joisey Well-Known Member
    The zerks on my 18 TRD Off Road were dry and the drivshaft slip yoke had zero grease in it. So much for the predelivery check list being signed off on.
  10. Feb 10, 2020 at 5:13 PM
    #1510
    Jeff Lange
    Calgary, Canada
    Neither of those items are on the pre-delivery check sheet.
    Jeff
    ericvega likes this.
  11. Feb 10, 2020 at 5:37 PM
    #1511
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    That grease on Amazon has some reviewers saying that grease liquefies at low temperatures into puddles on floor. Basically sayng it is garbage.
    Anyone have any experience with it or what to use instead ?
  12. Feb 10, 2020 at 6:06 PM
    #1512
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    Lucas Red N Tacky
  13. Feb 19, 2020 at 8:16 PM
    #1513
    Joisey
    Very true, but I was assured by the service writer that their dealership checks these before the trucks are put into service.
  14. Apr 7, 2020 at 4:46 PM
    #1514
    767heavy
    767heavy Member
    2020 TRD 4x4 OFF ROAD has 2 zerks.
    VanGo3 and shakerhood like this.
  15. Apr 10, 2020 at 6:25 PM
    #1515
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Thank you for showing us where the grease nipples are .
    heybronicetacoma likes this.
  16. Apr 10, 2020 at 6:34 PM
    #1516
    VanGo3
    VanGo3 Modern vehicles are ugly.
    Northern California
    20 SX AC 4x4
    Mostly dust and dirt.
    where?
  17. Apr 16, 2020 at 11:49 AM
    #1517
    Jeff Lange
    Calgary, Canada
    It likely depends on transmission, box, and cab size. There are a lot of different shafts used for the same year, and there are often running changes throughout the year as well as occasionally more than a single factory supplying components. You really need to check your own truck to see if there are grease fittings or not, because it seems Toyota and/or Dana/Spicer isn't always using the same components in all trucks and/or shafts.
    Jeff
    splitbolt[OP] likes this.
  18. Apr 19, 2020 at 8:06 AM
    #1518
    NorrinRadd
    NorrinRadd Well-Known Member
    WA
    2019 Sport, access cab, MT, Eibach 2.0 stage 2, tow, silver.
    To add to the discussion, took my new 2019 TRD Sport manual to a local shop and he crawled underneath and after a bit slid back out and told me I have fully sealed u-joints but that he could get me into a a set of Spicers for $250 complete. I think I'll wait until these die at 75k-100k miles before swapping since all it means is that I then have one more maintenance item.
    pop.tremuloides likes this.
  19. Apr 19, 2020 at 8:12 AM
    #1519
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    I'd wait as well as you will get quite a bit of mileage out of U-joints regardless whether sealed or not.
    Got 414,000 on my '96 u-joints.
    NorrinRadd likes this.
  20. Apr 19, 2020 at 8:39 AM
    #1520
    splitbolt
    splitbolt [OP] Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    At $250, I'd jump into a new 1-piece or 2-piece with a CV in the middle.
