Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Mar 7, 2021 at 7:10 PM
    #1541
    Homiec
    Homiec Well-Known Member
    2020 TRD Sport Access Cab 4X4 MT
    I've looked multiple times from different angles, rotated the drive shaft, felt for them, etc., and nada front or rear. The maintenance guide clearly states to lube. Wonder how many stealerships are charging people for it when it physically can't be done.
    Island Cruiser, Junkhead and snowcat like this.
  2. Mar 7, 2021 at 7:47 PM
    #1542
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    My 18 OR DCLB does not have any zerks for the main driveshaft but did for the front. The fronts were centered on the "back" of the joint. Tricky to get to. I found it odd that I didn't have anything on the main shaft. Kinda bummed. I suppose when the time comes to replace I'll get some with zerks.
    snowcat and shakerhood like this.
  3. Mar 7, 2021 at 7:48 PM
    #1543
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    They eliminated the zerks from the rear driveshaft after 2016, my 2017 only has the 2 on the front also.
    snowcat likes this.
  4. Mar 7, 2021 at 8:09 PM
    #1544
    CAG Gonzo
    2018 OR DCLB BarRed
    I couldn't remember the year; I watched a video to understand where to find the zerks and could've sworn the dude had an 18 DCLB but maybe he said 16. Probably had some grease in my ears and misheard.
  5. Mar 7, 2021 at 9:02 PM
    #1545
    TacoJeff19
    TacoJeff19 Well-Known Member
    Jeff
    19' DCSB OR
    OVtune, ADM, Hurst Short Throw.
    So assuming my 2019 trd OR has even front zerks, I have never greased them in the 35000 miles I have had the truck since new? How bad could that be lol?
    Island Cruiser likes this.
  6. Mar 7, 2021 at 10:35 PM
    #1546
    CAG Gonzo
    2018 OR DCLB BarRed
    I think the forward driveshaft only rotates while in 4WD so if you haven't gone many miles in 4WD you should be good.
  7. Mar 8, 2021 at 12:18 AM
    #1547
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    I didn’t grease any of my zerks until about 50,000 miles :anonymous:
    BlackTRD4Me likes this.
  8. Mar 8, 2021 at 1:00 AM
    #1548
    CJH9980
    CJH9980 Well-Known Member
    Clint
    Shreveport, LA/Tucson AZ
    2018 TRD PRO
    Wescott lift Wescott rock sliders Prinsu Cabrack SpartanXcustoms skewp light Demon Hook front recovery point Diamondback SD (just shipped) N2 Designs Remote Start A few meso goodies
    This is going to make me crawl under the truck after work in the morning. I’m 99% sure my 2018 has them. But, I also have a 2nd Gen so I could be getting my lines crossed
    shakerhood[QUOTED] likes this.
  9. Mar 8, 2021 at 7:23 AM
    #1549
    shakerhood
    Southern Ohio
    Yeah your 18 should only have them on the front driveshaft.
    CJH9980[QUOTED] likes this.
  10. Mar 8, 2021 at 7:50 AM
    #1550
    CJH9980
    Clint
    2018 TRD PRO
    Yep, just looked, only the front 2
  11. Mar 10, 2021 at 6:16 PM
    #1551
    C41n
    C41n KDMax Pro Authorized Tuner | Portland, OR
    Anthony
    Portland, OR
    2020 DCSB OR MT
    2020 TRD OR DCSB - I looked and looked but there are no zerks that I can find on mine either.
    I do have a grease gun and some grease now. Guess I need to find something else to grease :cool:
  12. Mar 10, 2021 at 6:41 PM
    #1552
    snowcat
    snowcat Well-Known Member
    2021 Lunar Rock Tacoma TRD PRO
    Welcome to the club. I made the same mistake as well! Was ready to break it out and grease some zerks... :anonymous:
    C41n[QUOTED] likes this.
  13. Mar 13, 2021 at 1:59 PM
    #1553
    JakNY
    JakNY 30yr/360,000mi Plan
    Jack
    NNY
    21 TRD PRO DCSB SUPER WHITE
    Just ckd my 21pro and can confirm no zerks front or rear.
    C41n likes this.
  14. Mar 16, 2021 at 9:02 PM
    #1554
    TACOZAC
    TACOZAC Well-Known Member
    2018 OR 4x4
    One of mine didnt take any grease, what's the trick for getting the grease in the nipple to "purge" ? thanks
  15. Mar 18, 2021 at 5:25 PM
    #1555
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    just scrape the center of the nipple...... They come painted over from the factory. If that doesn't work, punch the ball in the center to get it moving. It is spring loader and should go in and out.
    Good luck
  16. Mar 18, 2021 at 6:42 PM
    #1556
    TACOZAC
    2018 OR 4x4
    @over60 i appreciate the tips. I didnt scrape it enough so thats next and or pushing the ball in! cheers
  17. Mar 18, 2021 at 9:33 PM
    #1557
    Illini Tacoma
    Illini Tacoma Well-Known Member
    2016 Dark Red Double Cab Short Box
    Checked my 2016 CCSB and it has the 5 grease fittings that have been mentioned earlier in the thread. 3 on the primary shaft and 2 nicely hidden on the front differential shaft. I've owned the Taco since late January and never dreamed a late model vehicle would have grease fittings. I could tell that the joints had never been greased and the truck has 35K on the clock. It took about 3 pumps to get grease out of the u-joint cups on all fittings.
    I found no grease fittings on the front quarter shafts going out to the front hubs. Am I missing them or are there none on them?
  18. Mar 19, 2021 at 4:25 AM
    #1558
    NC_Pinz
    NC_Pinz Well-Known Member
    North Carolina
    2018 Cavalry Blue TRD Pro
    There are none on the two axle shafts with CV joints (front diff to each front wheel).
    Illini Tacoma[QUOTED] likes this.
  19. Mar 19, 2021 at 1:04 PM
    #1559
    over60
    Muskoka, Ontario
    Well, I believe all 2016's have them. Look closely. they are not the same as the rear ones. These ones are in the "crotch" of the joinr, not on the and very visable. Your fingers will find them if you search carefully. There are pics. slowing them real well in earlier posts...
    Good luck.
  20. Mar 19, 2021 at 1:11 PM
    #1560
    Chaosh1
    Chaosh1 Well-Known Member
    2021 Tacoma TRD Pro
    I have the 2021 Taco Pro. How many (if any from what i read) are there? Is this also a known issue on the 21 models too? What would the recommended grease be? I used to use Moly until i was told that it could actually cause flat spots in some types of bearings due to how slick it actually is. I guess the roller would't roll but would just glide leaving only one spot on the roller getting worn down.
