Check Your U-Joints
Discussion in '3rd Gen. Tacomas (2016-2023)' started by splitbolt, Jan 5, 2016.
  1. Jul 12, 2023 at 5:54 PM
    #1601
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    1. Try again, searching with fingers.
    2. Yes, it's possible.
    :hattip:
  2. Jul 12, 2023 at 6:31 PM
    #1602
    Shawgf2000
    Shawgf2000 Well-Known Member
    2018 Silver TRD Off Road
    I fingered the hell out of all those joints:fingerscrossed:
    The only one I couldn't get at was the back end of the propeller shaft, I also did it at the end of the day and right on the floor, I'll try again over the weekend when I can try and get the shield off that's blocking a view of it.
    thomasburk likes this.
  3. Jul 12, 2023 at 7:19 PM
    #1603
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Shaw
    Don't you have a 2018? Pretty sure theres no rear zerk.
  4. Jul 13, 2023 at 4:20 AM
    #1604
    Shawgf2000
    Yes, 2018 TRD Off Road
    I'm certain that the driveshaft doesn't have zirc fittings as I was able to closely inspect and felt around.
    The only one I question at this point is the hidden one on the rear of the propeller shaft
    thomasburk[QUOTED] likes this.
  5. Dec 21, 2023 at 6:17 PM
    #1605
    tacomatrddave
    tacomatrddave Well-Known Member
    2023 Tacoma Access cab sr5 v6 4wd
    Sumo springs. Shocker air hitch.
    Just reading this thread. I had a 2016 TRD OR. Mine had zerk fittings on the front drive shaft only. Just doing the extended 5000 mile service on a new 2023 SR5. No zerks left on any of the joints. And side note every single drive shaft bolt needed to be retorqued. Spec is 65 ftlbs. Every single bolt needed about a ¼ turn. So it's important not to skip that I think.
  6. Nov 16, 2024 at 12:11 PM
    #1606
    SeaDweller3T
    SeaDweller3T Well-Known Member
    2023 OR4x4
    Just confirming ‘23 OR has zero zerks.
  7. Nov 16, 2024 at 12:25 PM
    #1607
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    I just checked mine: 2021 Sport does not have zerks.
  8. Nov 16, 2024 at 1:08 PM
    #1608
    wayne0
    wayne0 Well-Known Member
    On a 2016, unless they have been replaced, there are fittings on the rear shaft at both ends, as well as both ends of the front shaft.
  9. Nov 17, 2024 at 6:07 AM
    #1609
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Correct
