Checked the oil on my new 09 Taco and...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmed99, Feb 9, 2009.
  1. Feb 9, 2009 at 7:29 PM
    jmed99
    jmed99 [OP] Well-Known Member
    SC
    09 DC PreRunner TRD OR
    I've only had my brand new Taco for a couple weeks now. I was checking a few things like tire pressure, oil level, etc. and noticed the oil level seems high to me.
    The oil comes up to about 1 inch above the second dot on the dip stick. I checked it when it was cool (hasn't been driven in a couple hours) a few times and every time the oil horizontal line stopped about 1 inch above the second dot on the dip stick. :eek:
    It came from the factory that way. Is this normal???? :(
    Thanks guys!
  2. Feb 9, 2009 at 7:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Seems kinda high, but it could be the dipstick too. Only way to tell for sure, is to drain the oil, change the filter, and re fill with 5.5 qts. of your favorite oil. :)
  3. Feb 9, 2009 at 7:43 PM
    BUK 0H5
    BUK 0H5 Still For Sale
    Queen Creek, AZ
    Silver 09 2.7L Manual AccessCab SR5 PreRunner
    Removed Mud Flaps, Suspension TSB, 5100's all around, JVC KW-AVX710 Head Unit with Metra surround.
    I have just over 800 miles on my turck and checked the oil the other day when I put gas in the tank and thought it looked a bit hight too. I chocked it up to being warn but after reading this i just ran out to the garage and checked again and sure enough it is around 1/2 inch above the top dot. I was thinking about changing out the oil soon anyway for "break-in" purposes. I like to keep mine around the middle ground. I'll have to see exactly how much it takes to get in the middle of the dots.
  4. Feb 9, 2009 at 7:48 PM
    tacoholic
    tacoholic Well-Known Member
    East Bay, CA
    Seems like that would be a bit high anyways but yea if you've got about 500 miles on the break-in oil, change that piss out for something good.
  5. Feb 9, 2009 at 7:52 PM
    gdawg25
    gdawg25 Zoom-Zoom
    Victoria, BC
    '08 Mazdaspeed 3
    Are you parked on level ground when checking the oil level?
  6. Feb 9, 2009 at 7:56 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    before you change the oil, the dipstick sits crooked in the pan..Check the oil, but look at both sides of the dipstick..One side will be high, the other side will be perfectly normal. Just a thought
  7. Feb 9, 2009 at 7:56 PM
    jmed99
    SC
    Yes...it was in my garage.
  8. Feb 9, 2009 at 9:35 PM
    BUK 0H5
    Queen Creek, AZ
    X2
  9. Feb 9, 2009 at 9:42 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    These dipsticks suck-ass!
  10. Feb 10, 2009 at 6:21 AM
    jmed99
    SC
  11. Feb 10, 2009 at 7:33 AM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    he means in was in the garage too, i am going to check mine since you guys bring this up, i have 700 miles on my 09. let you know.
  12. Feb 10, 2009 at 7:36 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    I can't trust the dipstick in my Tacoma, but since I change my own oil, I know I have the right amount in the pan. Has anyone asked the dealer if the dipsticks are accurate, or do you go by the manual? That's what I go by.
  13. Feb 10, 2009 at 7:52 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I bought mine used, with a nice little giffy chain sticker in the corner of my windshield. First thing i did was rip that shit off, drain it, change filter then put in 5.5 qt of fresh stuff.
  14. Feb 10, 2009 at 8:03 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    I bought my Tacoma new, and when I checked the oil, it was about 1/2 inch above the full line. When I changed the oil I put in 6 quarts (the manual says 6.1) and sure enough it was 1/2 inch over the line. I don't know what to trust. Maybe I'll just put in 5.5 also. It's better to be a little low than over full.
  15. Feb 10, 2009 at 8:13 AM
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
    I put in 5.5 and it is right at the second dot or below it slightly.... good enough for me.
    Also I took sand paper and roughed up the dip stick around the dots, makes the oil stick to it a little better.
    But yeah the dip stick sucks
  16. Feb 10, 2009 at 8:18 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    I'll try that sandpaper trick, thanks.
  17. Feb 10, 2009 at 8:27 AM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    Funny that everyone is mentioning the factory says fill with 6.1 qts and its a tad over filled. Mine said the same thing and its a 96 4 banger. But like everyone else, its really more like 5.5 or so. I found that out after the 1st change when it was new. I don't even think about it now, but yup- 5.5 and she's good to go.
  18. Feb 10, 2009 at 8:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Just so everyone is on the same page:
    The Second Gen. 2.7 holds 6.1 qts.
    Second Gen 4.0 holds 5.5 qys.
  19. Feb 10, 2009 at 9:03 AM
    jmed99
    SC
    Thanks for clarifying!
  20. Feb 10, 2009 at 9:06 AM
    jmed99
    SC
    Because I have the lifetime warranty I'll need to take it to the dealership and get them to change the oil. For the lifetime warranty you have to have real good documentation of your maintenance.
    So should I go with the second dot on the dipstick or 5.5 quarts? From reading all the posts it seems like the 2 will be different. :confused:
