Checking Engine oil Level Frustration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rob01, Mar 5, 2011.
  1. Mar 5, 2011 at 8:35 PM
    rob01
    rob01 [OP] Active Member
    Winnipeg, Canada
    2010 silver Crew cab TDR sport
    This is my 2nd Tacoma 6 cylinder 4x4 double cab Trd and the problem I have is when you check the engine oil level it does not read proper on the dipstick because when you put it back in oil covers the dipstick and you cannot get an accurate reading. Both my 06 and 2010 do this. Do you guys have the same trouble and what do you do about it.
  2. Mar 5, 2011 at 8:38 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    are you checking it with the engine running? i dont have a problem when i check mine but i always check with engine off
  3. Mar 5, 2011 at 8:58 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Common problem man! Sucks, but just make sure after you shut it off that you give plenty of time for the oil to drain down to the pan. Still gonna do it some though.
