Checking Major Fasteners - Chassis & Drivetrain
Discussion in 'Technical Chat' started by DGXR, Mar 18, 2011.
  1. Mar 18, 2011 at 9:54 AM
    DGXR
    DGXR [OP] Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    My '06 has 58k miles and surely the chassis & drivetrain bolts are all "settled in" pretty well, if you know what I mean. I have a good torque wrench that goes up to 150 ft-lb and a decent set of sockets and extensions. I would like to check these major fasteners just to make sure they're still solid and within spec. I'm talking about bell housing, tranny & engine mounts, suspension/a-arm bolts, crossmembers, leaf shackles, etc. Is it worth my time? Is this even a good idea, or should I just leave them well enough alone? Also I cannot find the torque specs in the FSM or anywhere else. Thx
  2. Mar 18, 2011 at 9:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    The FSM will have the torque specs listed under "Components" of the section you are checking. Example,
    http://ncttora.com/fsm/05+/data/ileaf/06toyrm/06toypdf/06rmsrc/rm2006ta/00700410.pdf
    The numbers in teh boxes next to the fastener give the torque values...
