Checking the timing on a 2.4L
Discussion in '4 Cylinder' started by flesheatingvirus, Sep 1, 2012.
  1. Sep 1, 2012 at 11:17 AM
    flesheatingvirus
    flesheatingvirus [OP] Well-Known Member
    ABQ, NM
    2016 TRD-OR 4x4AT Access Cab - Magnetic Gray
    Tech Package
    How do I check the timing on my 1996 Taco with the 2.4L?
    It was suggested that I get Cylinder 1 up to the top (compression cycle) and verify that the distributor rotor is pointed to the #1 post. Would that work?
  2. Sep 1, 2012 at 11:32 PM
    BamaToy1997
    Bill
    Navarre, FL
    There is a bit more to it than that. You actually need a timing light. I am not sure the exact proceedure, but you disable spark advance, connect up the timing light, point it at the crank pulley and with the engine running, pull the trigger. The strobe will flash each time the spark plug for #1 fires. Then you adjust the distributor until the mark on the crank pulley is lined up with the correct timing mark on the indicator.
  3. May 9, 2024 at 2:36 PM
    Piper86Hotel
    Piper86Hotel New Member
    Don
    Toyata Tacoma
    Stock
    If you get a manual , say Haynes or some thing to that effect , it will show you and tell just how to check and set timing . The way that the Distrubutor is made there is very little leyway to move the Distributors, At Idle with out jumping E1 and TE1 it will show the timing between 8 to 18 degrees with it jumped it will be 3 to 7 degrees . don .
