Checking the transmission fluid level on a '98 MT Taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by Draper98Tacoma, Mar 15, 2017.
  1. Mar 15, 2017 at 6:14 PM
    Draper98Tacoma
    Draper98Tacoma [OP] Member
    Draper
    1998 Tacoma 4x4
    How do I check the transmission fluid on my 98 Tacoma, MT 5vzfe. Also, once I've done that, how do I add fluid if need be? I'm completely new to most car things, but i have a feeling my tranny is leaking.
  2. Mar 15, 2017 at 7:54 PM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    If it's leaking you should be able to see signs of the fluid escaping. Do you see any seeping oil coming from it?
    To check the fluid level you need to remove the full plug and check the level by hand. i.e. Stick your finger in the full hole and there should be fluid at the bottom of the fill hole. Make sure you're doing this on level ground.
    DustStorm4x4 likes this.
  3. Mar 15, 2017 at 8:13 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Truck on level ground. Remove fill plug. Does fluid dribble out? You're fine. Nothing coming out? Put some in there till it does. Plug it back in. Done.
    Also, pretty sure you'll need a 24mm socket
  4. Mar 16, 2017 at 4:26 AM
    Draper98Tacoma
    Draper
    1998 Tacoma 4x4
    Thanks for the reply. Where would the fill plug be located?
  5. Mar 16, 2017 at 6:27 AM
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
    This might help.
    Do not remove the drain plug until you make sure the fill plug will come out! Sometimes the previous owner has rounded off the plug or tightened it too much.
    https://www.youtube.com/watch?v=j_ZEQcS0pg0
  6. Mar 16, 2017 at 7:09 AM
    Deere9798
    Deere9798 Well-Known Member
    Charles
    Western NY
    2001 Tacoma 4x4
    It will be the upper of two 24mm bolts that are located on the rear of the transfer case.
    _Charlie
  7. Mar 16, 2017 at 7:47 AM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    No, no, NO!
    We're talking about the transmission here.
    ThunderOne and DustStorm4x4 like this.
  8. Mar 16, 2017 at 8:05 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    what he said
