Checklist....
Discussion in 'Suspension' started by dud122, Mar 9, 2009.
  1. Mar 9, 2009 at 8:36 AM
    dud122
    dud122 [OP] rabble rabble rabble
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Lights, CB, Switches, skids, LED's... OH MY!
    Due to my sweet tax return this year and the extra 600 for qualifying for last years stimulus package I've decided to go ahead with the lift and tires...
    just wanted to double check to make sure I have everything I'll need lined up so I can buy it all as soon as the return gets deposited. Here is what I got...
    Toytec's 3" lift w/ heavy duty OME coils and rear AAL kit
    Camburg UCA's
    Front OME N91S Shocks
    Rear OME N85 Shocks
    (Most likely...) BFG AT 285/75/R16
    Maybe some spacers... I know a lot of people go for the spydertrax ones but is there a huge differince in quality with different brands? should i stay away from ones made from a certain material?
    Thanks
    guys.
  2. Mar 9, 2009 at 8:47 AM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    8112, SPC, Elka 2.0 rear and Icon AAL. About 1.5”
    The rear lift sounds great. AAL and OME shocks will do the trick nicely.
    For the front.... You want the 2.5" lift 882 OME coils and a 3" toytec spacer?
  3. Mar 9, 2009 at 9:26 AM
    Alaskaflyer
    Alaskaflyer My other ride Hovers
    Cape Cod, MA
    08 Prerunner DC TRD Off Road
    OME 885 AAL, 2.5* shim, Light Racing UCA's. BFG AT KO 285/75/16, Spidertrax spacers, OME Shocks up front, Bilstein 5100 Shocks in back.
    Sounds about right, I have the spidertrax spacers and they are great. The only thing I could think of adding is if your truck has the famous "Taco Lean" then the the 5mm trim packer for the drivers side coil/shock assembly.
    Gary
  4. Mar 9, 2009 at 11:30 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Sounds good! But I do believe you want to go with the 882 coil setup. With the top plate spacer, it will give you the 3" lift. The heavy duty coils might be too much lift for ya. Oh! and If your 4x4, dont forget the diff drop kit.
  5. Mar 9, 2009 at 4:41 PM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    shouldn't i get the heavy coils if i want a heavy duty bumper later?? will the front be higher if i get the heavy coils now with no bumper?
  6. Mar 9, 2009 at 4:45 PM
    Alaskaflyer
    Cape Cod, MA
    If you are getting a big bumper then you should consider the heavy duty being a double cab. It shouldn't be higher, just more stiff.
  7. Mar 9, 2009 at 5:02 PM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    yeah... it may not be till the next tax return that i get my bumper but i definately am at some point
    and where do i get the 5mm trim packer to correct the "lean"
  8. Mar 9, 2009 at 5:14 PM
    Alaskaflyer
    Cape Cod, MA
    Toytec has them, at least they do for the 2nd gen tacos
