CHEVY 350 in my 95 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by bwall, Aug 29, 2012.
  1. Aug 29, 2012 at 1:39 PM
    bwall
    bwall [OP] Active Member
    Brantley
    South Carolina
    95 Tacoma 2.7 35" tsl Boggers 6" lift
    4.88s,
    I want to put a 350 motor in my 1995 tacoma what has to be done to make that happen??
  2. Aug 29, 2012 at 1:48 PM
    bwall
    Brantley
    South Carolina
    4.88s,
    i need details, ive heard they fit pretty good
  3. Aug 29, 2012 at 1:53 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    *snicker*
    Be nice, whipper. :p
  4. Aug 29, 2012 at 1:55 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Depends on where you want the spoiler installed, of course.
    Obviously the list of "details" is infinite. I don't believe there's a single Taco owner on here that has one done, and that's over 20k members. Go ahead and be the first, do a full write-up with pics, and you'll be a goddamn patriot hero legend pimp grand master idol
  5. Aug 29, 2012 at 1:56 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    For starters you'll need:
    . an engine
    . a transmission
    . engine and transmission control modules
    . custom engine mounts
    . custom cross-members
    . custom driveshaft
    . probably new radiator and custom mounting brackets
    . likely an entirely new rear axle to handle the power
    . custom exhaust system
    . a ton of fabrication work
    That's just to get started.
    Don't expect to pass smog or anything like that unless you're getting an engine from the same year or newer than your current vehicle.
  6. Aug 29, 2012 at 1:59 PM
    blake5995
    blake5995 Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    it actually wouldnt be that hard to smog as long as you get all the right stuff on the engine i have a friend with a 2001 and a small block in it and he smogs it with flying colors.
  7. Aug 29, 2012 at 1:59 PM
    Wild Card
    Wild Card Truck yeah!
    Doug
    Portland, MI
    02 TRD SR5 4x4 V6 Xtra Cab 5spd
    6" Deckplate. Trimmed TB gasket. Grey wire. Disable DRL's.
    350's are overrated, anyways. They don't seem to last forever like the Yota engines already in these trucks. If you really want power, just spend less money and effort and get the supercharger.
    But, if you REALLY wanted to do it....custom engine mounts, custom crossmembers (for transmission and transfer case mounting), MAJOR reinforcement of the rear-frame, heavier duty rear-axle and front axle, heavier duty front suspension from all of the extra weight.....shall I keep going? And that's assuming the 350 does actually fit in there, which might be tight.
    And yes, nice is overrated.
  8. Aug 29, 2012 at 2:00 PM
    blake5995
    Blake
    Truckee, CA
    you basically drop the drivetrain and replace it all
    front end
    rear end
    transmissions
    t case
    motor
    wiring
    computer (if newer)
    mounts
    all sorts of shit all you will have left is a tacoma body and frame
  9. Aug 29, 2012 at 2:00 PM
    babytruck
    NorCal
    Wouldn't it be easier to just buy a car with a 350 in it and then put the Toyota body on it?
  10. Aug 29, 2012 at 2:02 PM
    blake5995
    Blake
    Truckee, CA
    probably lol
  11. Aug 29, 2012 at 2:04 PM
    Smokey11
    Smokey11 You Can't Fix Stupid !
    Jeremy
    Anchorage, Ak
    99 ex-cab TRD 2.7L 4X4
    OME 881, 10MM top plate spacer,nitros,wheelers 5 pack, 1.25 Daystar Shackles,265-75-16 Duratracs on 16X8 Pro Comps,leer shell, husky liners, sway bar removed, X-runner badges, tint, auto start, BPV relocate, extended rear brake line.
    Like stated above its alot of work and money, my buddy did it to his 89 when we were in HS and granted it was bad ass but just not sure its worth it. His parents were rich so he didnt spend any of his time or money he had someone do all of it but I watched the process and I wouldnt want to do it.
  12. Aug 29, 2012 at 2:13 PM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    I'd rather rebuild my engine add a supercharger and some nitrous if your thaaat power hungry and financially well off, and why not add a tandem axle or some half-track too to up the bad-ass-ness of this :p
  13. Aug 29, 2012 at 2:13 PM
    bwall
    Brantley
    South Carolina
    4.88s,
    is there any other suggestions? i just want more power, What would the best conversion be for this build?
  14. Aug 29, 2012 at 2:24 PM
    bwall
    Brantley
    South Carolina
    4.88s,
  15. Aug 29, 2012 at 3:44 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    If you want more power,drop down a couple inchs,ditch the boggers, and like others said rebuild +supercharge.
    Or sell your i4 and get a v6.
  16. Aug 29, 2012 at 3:52 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    If I was seriously looking at an engine swap I'd keep it in the family and use a toyota 1uzfe. Could also look at the other uzfe motors. Apparently the 1 and 3 were very state of the art does their time, to the point where they are still appreciated today. Plus the idea of an all aluminium 4.0L v8 makes me grin. I read a build where a guy pur one in a 93 or 96 dont remember. Google it. I know there is a company in new Zealand that makes. 1uz to r150f (5-speed manual) adapter plate.
  17. Aug 29, 2012 at 4:47 PM
    Ecnerwal
    Ecnerwal Well-Known Member
    NW Mass
    '02 4x4 2.7 A/T Ext Cab
    gradually replacing the bumper with hairy bondo ;-)
    You have a 3RZ in there now?
    Will 1100 horses do you? Heck, that's from 8 years ago, how far can you go now on a 3RZ - but that's the easy web search result to find. Hope you won the lottery.
    A bit more.
    If you want a chevy 350, the only remotely affordable way (IMHO) is to get yourself a chevy 4x4 with a rotten body and a good frame, and instead of the Ford Pinto's all the kewl kids were slapping on top of the maxed-out lifted 4x4 in the 1970s (or an AMC Pacer I saw once), slap a Toyota body on there (should be some from rotten frames available cheap...)
    LCE supercharger - Probably cheaper than doing a 350.
  18. Aug 29, 2012 at 5:29 PM
    blake5995
    Blake
    Truckee, CA
    put a turbo on it and some nitrous if you really want that much more power
  19. Aug 29, 2012 at 7:15 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Yup.
    Drop a Taco body onto a '74 K5 chassis.
    Sex on wheels.... 2012 Tacoma, SFA
  20. Aug 29, 2012 at 7:17 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
