chevy 6 lug rims
Discussion in '1st Gen. Tacomas (1995-2004)' started by killzone90, May 4, 2011.
  1. May 4, 2011 at 8:48 PM
    killzone90
    killzone90 [OP] Well-Known Member
    Ethan
    Fairdale,ky
    96 tacoma
    Will chevy 6 lug rims fit on my 96 tacoma?
  2. May 4, 2011 at 9:38 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    I think so. Pretty sure they are both 6-5.5 bolt pattern. Not 100% positive though
  3. May 4, 2011 at 9:46 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The bolt pattern is the same but the center hole is smaller on the Chev rims because their hub is smaller. Test fit before you commit.
  4. May 4, 2011 at 9:50 PM
    phoenix ray
    phoenix ray Well-Known Member
    ray
    Phoenix AZ
    00 PreRunner X-cab TRD
    5100's, AAL, AEM/Spectre true CAI , Magnaflow muffler with mandrel-bent exhaust and header, 4.88's, BFG KO2 12.5 x 33 on 15" AmRacing Outlaw II's, 17" electric cooling fan in factory shroud, frame-mounted remote large-size oil filter, adjustable cam sprocket
    The rims have to come off of a Colorado/Blazer, and not the full size trucks. Check backspacing. The lugs nuts may not fit in the holes -- Toys have a special diameter. Good luck.
  5. May 4, 2011 at 9:50 PM
    lvlytaco
    lvlytaco Well-Known Member
    Allan
    Hawaii
    Got Lip?
    6" procomp basic lift, alpine dbl din, 9" headrest screens, mb quart components, jl amp, yellow top battery, wet okole seat covers all around
    if the the center bore is 87mm if wont fit, toyotas are 108mm. but not all rims have 87mm center bore so u have a good chance
  6. May 5, 2011 at 6:37 PM
    killzone90
    Ethan
    Fairdale,ky
    96 tacoma
    thanks.i have the rims on a full size blazer im scrapin just havnt had time to try them yet but was jw
