Chevy 63 Swap
Discussion in 'Trail Toys' started by SMKYTXN, Nov 6, 2018.
  1. Nov 6, 2018 at 10:44 AM
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Trail Toys is available to help with your swap if you're local, or just want to bring your rig down to Texas. Send me an email to discuss your build. nathan@trailtoys.net
    Here's the rundown of my chevy 63 leaf spring swap. I figure it'll be nice to have this as it's own dedicated thread for ease of searching.
    I decided to go with the Chevy 63 leafs primarily to hold up the heavy flat bed.
    Taco leafs that will support the weight of the bed, toolbox, and gear don't exist. The allpro expos state an extra 400 to 500lbs of cargo. Here's the breakdown of the weight that's currently out back.
    Toolbox = 200lbs (without tools or gear)
    Bed = approximately 350lbs (I should get an actual weight on it)
    Stock DCSB bed = 250lbs
    So I'm 300lbs over stock in the rear. The expos will only give me 100-150lbs of capacity before I start sagging. I don't think that will work. The expos also cost $500.
    So, in enters the chevy 63" swap idea. When I weighed my truck, the back end weighed in at 2900lbs. This was on a cat certified scale.
    Here are the box weights for the 1/2 ton Chevy pickup.
    Box curb weights:
    Standard box - 2219lbs
    Long box - 2267lbs
    Payload capacity:
    Standard box - 1508lbs
    Long box - 1802lbs
    Let's look at the standard box. I'm 681lbs heavier than the stock curb weight so I'll have to reduce the payload capacity by that much. That would leave me with 827lbs of payload capacity if I just run the stock springs. I could also choose to add an add a leaf to the chevy springs.
    Cost breakdown:
    Ruffstuff ideal 63" swap kit = $226.50
    63" springs from the junk yard = $100 (supposedly)
    Add a leaf for 63" springs = $80 (if I need them)
    Total cost = $406.50
    Right off the bat I decided to use Skyjacker 5" lift springs instead of factory chevy 63's. The leafs I used from Skyjacker are CR55's. If I had to do it again I would buy the CR75's, which are meant for the 3/4 ton truck. The 5" lift spring is significantly longer than the stock 63's, which have resulted in more droop.
    When ordering the ruffstuff swap kit you'll need to know the axle diameter so they send you the correct u-bolts. The 8.4" sport rear axle tubes measure out to 3.25". Here's what you get in the Ruffstuff kit. The only thing you'll be missing is a rear perch for the rear shackle hanger.
    Time to start putting the kit together. You have to weld up the front spring hangers from ruffstuff.
    Powdercoated shackles
    Things never go according to plan. I had to buy an air chissel to get the old OME bolts out of the lower shock mounts.
    I had cut the rivets for the rear spring hangers when I built my flatbed, so taking them off now was the easy part.
    The skyjacker leafs have two different size eyes. The front requires a 5/8" bolt and the rear needs a 1/2" bolt. I have no idea why they're different, but keep it in mind if you're going to use these leafs.
    Front spring hangers gone.
    Tacked in the front spring hangers and called it a day.
    Rear spring hangers. Due to our frames tapering at the rear you'll need to build a perch for the rear hanger. This was my solution.
    With everything tacked in place I tried out two of the four leafs and found that they were no where near the capacity I needed. Time to put the whole pack back together and see how they work.
    All four leafs turned out to be too much. In the end I went back to four leafs, but that was after I had moved the rear hanger forward.
    You can see that my shackle angle is too steep here. I didn't know enough at the time and welded everything out. I had to cut off the hanger and turn it around, which moved the hanger about 1.5" forward.
    Fool droop with the wrong shackle angle and no retainers on the leafs.
    Paint :)
    So one of the problems I ran into was the axle rotating enough that the stock shock locations wouldn't line up. I had to take the axle shim out to get the shock to fit. The skyjackers are way to bouncy to run without a shock for more than a few feet.
    Doing a little testing before buttoning it up to go home.
    Phill stopped by the shop this evening to help me measure for the new shocks. I took measurements between the underside of the bed and the centerline of the shackle. Here's what I got.
    Compressed = 29.5"
    Extended = 43.75"
    Distance between flat leaf and bump pad = 6"
    Brake lines = 36" (there will be plenty of slack with that length)
    So with adding an inch for forced travel I'm looking at 15.25" of travel in the rear.
    I decided to run 18" shocks vertical so that I can dampen the heavy rear bed and so that I won't have to strap the axle.
    The 18" shock has a compressed length of 28" and an extended length of 46". That would give me 1.5" of exposed shaft on compression and an extra 2.25" of extension past my calculated numbers. Definitely provides more room for error on my part. The additional cost to go from the 16" to 18" shock is only $25, so it's kind of a no brainer.
    Bump stops
    I did not take into consideration how much these bumps would compress, so in this picture they're 2" too short.
    New shocks
    I also ordered new brake lines at 10" over stock. So far I haven't had any issues with them.
    Rear shock mounting:
    I used a Ruffstuff lower shock mount. We had a few issues with the mount though. It should have been a little longer on the sides to allow the supplied bolt to fit. You can see here that it hits the frame.
    I also did a little machining since I didn't have spacers on hand. I turned down, and bored, a piece of sch 160 1/2" pipe for bushings. Each one is 1/4" thick. That also helped with spacing out the tabs since the shock eyes are 1-1/4" wide.
    The point of no return. No more stock shock mounts.
    Tacked on the upper shock mounts to the flatbed. Quickly realized they needed to be angled to get the lower shock mount to line up.
    First shock mocked up.
    With 4.1" backspacing on the wheels and a 1.25" spacer it looks like there will be plenty of room for the shocks.
    All welded up.
    I added 2" to my bumpstops to keep the leafs from going negative and the shocks from bottoming out. Everything looks good to go. I clear the tires at full flex, but I may move up to a 1.5" wheel spacer to gain a little wiggle room.
    And finally some real world testing. I still need to build a traction bar, but that will have to wait for another day.
    Operator8, Amchuge, k_j_souv and 9 others like this.
  2. Nov 8, 2018 at 7:37 AM
    TaKoToy
    TaKoToy Well-Known Member
    Robbie
    Prince George VA
    2013 4x4 OffRoad, 2020 cement DCLB OR
    Mostly stock
    :drool::thumbsup:
    SMKYTXN[OP] likes this.
  3. Nov 8, 2018 at 7:43 AM
    upTOPOverland_Drew
    upTOPOverland_Drew upTOP Overland Technical Design and Application
    Drew
    Littleton, CO
    2017 TRD OR DCSB SUPER WHITE
    All the things...click the link in sig
  4. Nov 8, 2018 at 7:49 AM
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    Holy cow I need a cold shower
  5. May 28, 2019 at 12:21 AM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    I am doing the 63 swap soon. I have all of the parts ready, including 16" kings. I don't have a flat deck (yet), so I'm building a bed cage to go through the bed with the shocks.
    My question is, what orientation should the shock eyes be? I have axle shock mounts that would put the eye in the same orientation as stock. Should I change them to be like yours? Or can I just turn the upper mounts 90°? Or are they fine both facing the same way?
    Thanks so much for your time @SMKYTXN ! I know this is pretty old and your truck is very different now, but I think you still have the same rear setup. Anything you would do different?
  6. May 28, 2019 at 12:37 AM
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Goddamn that rear flex!!
  7. May 28, 2019 at 6:19 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Even with the SAS I'm still on my 63's. I will eventually link the rear, but she's holding up just fine as is.
    I like both the top and bottom bolts to be perpindicular to the axle. That way you don't have any bind.
    WormSquirts[QUOTED] likes this.
  8. May 28, 2019 at 6:26 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I don’t know the answer to this but wouldn’t you want one parallel to the axle and one perpendicular to avoid binding? That would allow the shock to articulate front to back and side to side if the axle were to shift in either direction during travel? Or is it assumed that on leaf springs the axle doesn’t shift forward or backward during flex?
  9. May 28, 2019 at 6:33 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Your axle will move a bit front to back with the travel of the leafs, but not enough to overcome the travel of the joint in the shock. The axle moves a whole lot more in line with itself, vertical travel of one wheel. Having the bolt perpindicular to the axle allows it to roll on the bolt.
    I'll correct my previous post where I said parallel. I've done both though, both perpendicular, and opposing. It's best to tack everything in and verify it's not going to bind though.
    WormSquirts likes this.
  10. Jun 6, 2019 at 11:43 AM
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    So I’m setting up some 63s on my truck. They’re just springs pulled from the junkyard. Is there a final consensus on shackle angle when you’re setting these up? From what I read it’s 45 degrees during setup and 20 at ride height when on all 4 wheels. Is that right? I’m seeing different things in multiple places.
  11. Dec 6, 2020 at 8:01 AM
    Heinouslurk
    Heinouslurk New Member
    Max
    1996 Tacoma
    Aluminum Tray, 33” tires, 3.5” lift, Chevy 63’s etc etc
    Was your truck a 4dr long box?
    How much farther forward did you move your front hanger from stock location?
    Did you center your axel on the truck before tacking in the hangers?
  12. Jul 16, 2025 at 5:13 PM
    cwk84
    cwk84 Well-Known Member
    2019 TRD OFF-ROAD
    Is axel shift normal with the Chevy setup on a Tacoma? My fabricator just did the swap and after we did a flex test on one side the axel shifted. He says it’s normal and that a track bar will help. There isn’t a single person mentioning anything about axel shift on this forum so I didn’t expect that I may need a track bar. The flex with the Chevy springs is so crazy that even with 14s I need limit straps. I could easily do 16s. I have 5” shackles in case anyone wants to know. With 6” it would be even crazier.
  13. Jul 23, 2025 at 4:26 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    You shouldnt need a trackbar. By axle shift do you mean it is offset at ride height?
  14. Jul 23, 2025 at 9:13 AM
    cwk84
    2019 TRD OFF-ROAD
    Yes, after the first flex test. According to the guy who did the alignment as well as my fabricator, the truck was level and the axel was centered. He has done the swap a few times and he checks his measurements. He even showed me everything and it is all centered. He said that every time he has done the swap he has seen the axel shift due to the RuffStuff shackles not being hammer hangers that keep the leafs in place. So when you flex it out it can move a bit. I can see that the leafs aren't totally centered. The bottom leaf has moved a bit. So I think he's right by saying that they aren't kept in place. I got the springs from General Springs rather OEM from Chevy. Maybe that is the issue. The steel seems to be very soft. The truck sways a lot on the freeway. It's as if the rear axel moves. My fabricator said that sometimes the Chevy's are so soft and flexible that a track bar makes sense to make sure the axel stays centered. But I have never seen a Tacoma C63 swap that necessitated a track bar so I'm a bit lost as to what I should do. I could get OEM C63s and see if that will solve it. But then again, I'll most likely 3 link it in the distant future so I might as well get the track bar now.
  15. Jul 24, 2025 at 5:50 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    I wouldnt do a trackbar on a rear leaf application. You are over constraining the axle.
    A trackbar actually makes a horizontal shift in the axle through its travel due to forcing it to travel in an arc.
  16. Jul 24, 2025 at 9:55 AM
    cwk84
    2019 TRD OFF-ROAD
    You certainly speak truth. I shouldn't need it. And the shackles, albeit not as sturdy as the hammer hangers from AG, should keep the axel centered. I just can't shake the feeling that it's due to an installation issue. My fabricator showed me everything but what do I know. The only variable that is left is that the leafs themselves are the issue. That somehow they have twisted, or the center pin is off or maybe they were installed the wrong way. But it could also be that my fabricator installed the swap kit the wrong way and doesn't want to be truthful about it. But I highly doubt it. I have had a good relationship with him and he's done so much work on my truck without any hiccups. I feel like I'm in a shitty situation because part of me wants to get a second opinion but another part of me wants to give him the benefit of the doubt.
  17. Jul 24, 2025 at 12:58 PM
    cwk84
    2019 TRD OFF-ROAD
    Welp, I just found the issue. It is the leaf springs. My dumb ass ordered the OEM replacement springs for a 2025 Chevy 1500 which are actually shorter than 63 inches AND have a WAY higher load capacity. The center pin may also not be where it needs to be for the RuffStuff kit. So basically all the measurements are now off because I used the wrong springs. A way to fix it would be to move the spring perches but I don't wanna do that. Instead I ordered OEM replacement leafs from a 1998 1500 with a load capacity of 1425lbs and a total length of 64" (all of them up to 2010 are 64"). That means my fabricator has to redo EVERYTHING. My wallet is bleeding already...
