Chevy Colorado G80 axle swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mharv76, Nov 14, 2010.
  1. Nov 14, 2010 at 11:23 PM
    mharv76
    mharv76 [OP] Member
    Dallas
    2006 Prerunner
    6 in lift
    Has anyone entertained an axle swap from a 4x4 ChevroletColorado with 3.73 or 4.10 gears onto a 2nd Gen Prerunner? I used to own a Chevy Colorado and I loved the G80 locker set up it had. I think I'll take some measurements, but it appears the axle width is pretty close and the Colorado has a six lug set up. The only issue I see is brake lines, E-brake, and drive shaft. Any thoughts?
    Just an idea to throw out there for everyone.
  2. Nov 15, 2010 at 8:21 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You're talking about a rear axle swap just to get a locker?
    1. I think the taco is a few inches wider than the Colorado.
    2. Probably easier to swap with a Taco offroad axle that's got a locker. Easier bolt up.
    3. Post pictures if you do it! :D
  3. Nov 15, 2010 at 10:16 AM
    Di Trut
    Di Trut Well-Known Member
    a gov-bomb??? i would never entertain tthat thought. They are notoriously unreliable.
    Better off with a no-slip, lock-rite, or ARB. Probably cheaper with any of those routes too.
  4. Nov 15, 2010 at 4:42 PM
    mharv76
    mharv76 [OP] Member
    Dallas
    2006 Prerunner
    6 in lift
    I just liked the auto lock style of the Chevrolet, no electric, no push button, no air, and extremely reliable (my experience). I had the push button differential lock on my 2001 Tacoma and was disappointed to find out this feature had been dropped on these newer Prerunners for the LSD set-up. The old style was extremely useful on boat ramps. BJMOOSE meantioned the width. Perhaps a wheel spacer to compensate. They are built by Eaton, a company that has been around a long time.
    How it works: http://www.youtube.com/watch?v=KbMZ9vcYVSg
    Demonstration ( elementary I know): http://www.youtube.com/watch?v=p8nAbg5suFw
  5. Nov 15, 2010 at 4:50 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    The right way to lock the rear is ARB. It is on demand and can be turned ON when YOU want it. Meaning much less stress on the driveline components.
    Detroit, or Power-Trax are automatic lockers. Those are ON most of the time. For example Detroit locker locks the wheels when there is power transmitted from the engine, in other words most of the time the rear is locked. That has TWO major disadvantages...
    1, More stress on the rear
    2, It will chew up tires faster
  6. Nov 15, 2010 at 5:31 PM
    mharv76
    mharv76 [OP] Member
    Dallas
    2006 Prerunner
    6 in lift
    I'll check out the ARB. Thanks WhiteTaco.
  7. Nov 15, 2010 at 6:59 PM
    bk1
    bk1 Well-Known Member
    Lower Mainland, BC
    08 Tacoma TRD Sport
    ProComp Stage 2 6" lift, AAL, Heated Mirrors, DVD/NAV, Amp & Subs, Fog Light Mod, Rear Diff breather. WeatherTech Mats, Soft Tonneau Cover, 33" TrXus M/T, M8000 Winch & Bumper, CB, Rock/suspension Lighting and a whole lot more Soon to come rear Locker and more....
    I dont think you're able to swap out the locker from the OR model into the sport or LSD Diff's... there 2 differant sizes from i've seen.. I think the OR is an 8" and the LSD units are 8.4"
  8. Nov 15, 2010 at 7:45 PM
    05RedTaco
    Tony
    Scottsdale
    http://home.4x4wire.com/erik/diffs/#T100-Tundra <--- Good info!
  9. Nov 15, 2010 at 7:47 PM
    05RedTaco
    Tony
    Scottsdale
    The only bad part about ARB is the cost...
    ARB locker - $800
    Compressor $100-$200
    Professional install - $100-$300?
    So you will end up paying $1100-$1300 for ARB locked rear end :eek:
    Powertrax - $300
    Detroit - $500
  10. Nov 15, 2010 at 8:04 PM
    DiamondDG
    DiamondDG Well-Known Member
    Central Cal
    2010 Prerunner DC TRD Sport
    3" Ready lift SST lift, Magna Flow cat back exhaust, Volant cold air intake, Grillcraft MX grill, N-Fab Prerunner light bar w/ 4 Hella 7 series lights
    Not sure what year they started but auto-
    LSD was standard on all 2nd gen 09' and up Prerunners. Might double check on yours. They may have started earlier.
