chevy engine?
Discussion in 'Performance and Tuning' started by thmpsntrv91, Mar 20, 2011.
  1. Mar 20, 2011 at 5:22 PM
    thmpsntrv91
    thmpsntrv91 [OP] Member
    trevor
    vermont
    91 tacoma
    2.5 inch lift
    is there any way to install a chevy small block engine into a 91 tacoma ?
  2. Mar 20, 2011 at 5:25 PM
    Dibblit
    Dibblit Eh?
    Paul
    Stony Plain
    Truck
    Icon Suspension ARB OBA
    If your good at fabrication it is possible, but a lot of work.
  3. Mar 20, 2011 at 5:27 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  4. Mar 20, 2011 at 5:30 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2005 Prerunner TRD Off Road
    265/75/16 BFG A/T, 18" Magnaflow, K&N Intake Filter, Ultra-Gauge, Kobalt Toolbox, Metal Tail Light Guards, Cobra 19 and 4ft fiberglass antenna, Plasti dipped Badges/lower valance/rear bumper/grill/bullbar/ac controls, black DIN kit, JVC KD-X40, Wet Suit Seat Covers
    It would be difficult to swap any engine into a Tacoma that existed 4 years before the Tacoma.....
  5. Mar 20, 2011 at 5:46 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    A 91 isn't a Tacoma.
  6. Mar 20, 2011 at 5:50 PM
    thmpsntrv91
    trevor
    vermont
    91 tacoma
    2.5 inch lift
    yeah a 91 isnt a "tacoma" but its the same thing really. and thanks. i usually work on chevys and have a couple extra engines sitting around. me and my friends have worked on his 04 tacoma and i like how they are easy to work on.. this is my first tacoma i bout in great condition and my chevys have more horse so i thoguht about swappign the engines
  7. Mar 20, 2011 at 5:53 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    There are plenty of aftermarket adapters out there so fab work will be as simple as bolting them in.
  8. Mar 21, 2011 at 12:48 PM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Currently under the knife for turbocharger..
    Wouldnt be too bad especially since you have the steering box in the front so you should be able to find headers to clear off the shelf, will be easier that doing it into a Tacoma..
    I just did an LS1 into a 98 Tacoma, was a pain because the steering shaft and the exhaust need to be in about the same place so I had to custom make a set of headers..
    Well worth it in the end, it is pretty much done, just need to get the gauges to work and I am golden, I have working AC (ice cold) and power steering just like stock and I am even going to make the stock Toyota gauges work as well, just need to find a place for the Toyota temp sender and get a Dakota digital signal modifier to adapt the Chevy signal from the T56 trans to my Toyota speedo.
    Wont be anything to give away whats under the hood except the sound of the V8...:D
