Chevy S10 trouble
Discussion in 'General Automotive' started by parkman, Oct 25, 2018.
  1. Nov 4, 2018 at 3:24 PM
    parkman
    parkman [OP] Well-Known Member
    Park
    2024 Ford Ranger XLT
    Figured it out myself, spark plug wire wire came loose on the plug. Heard sparking when I had the window down. Popped the hood could see the spark, shut it off reattached it and good as new!
    irayfz6 likes this.
  2. Aug 1, 2019 at 4:10 AM
    parkman
    Park
    Update...
    Having some trouble again.. I was having problems where once the truck got up around 45 it would at times not want to speed up at all even if I floored it. The RPM's would accelerate but no change in MPH. I ran a OBD II scanner and got a code for the MAF sensor. Replaced that and that problem went away for a day or two. Now I'm having that problem again as well as I'm getting a random misfire code, and if I hit the gas more than a little bit I get a grinding noise from what sounds to be underneath and a slow increase in speed if that. Now if I have the truck parked or put it in Neutral I don't get that noise at all I just get a little vibration from a loose heat shield towards the back.
    I'll be honest I'm no mechanic but I do know some basics. I'm just trying to look for any opinions on what it could be. Thanks Everyone!!
  3. Aug 21, 2019 at 4:42 AM
    parkman
    Park
    Any Ideas? :hattip:
    At this point now it can go up to 50MPH but it literally takes like a few minutes minutes of hitting the gas then let it go then hit it again and repeat without allowing it to be floored.
  4. Aug 21, 2019 at 6:08 AM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    Your description sounds similar to when my parents Buick had a clogged cat. Getting up to highway speeds was a real task. You had to hold the pedal down for a long time until you got close to highway speeds and then actually let off the gas a little and it would shift into overdrive.
    parkman[QUOTED][OP] likes this.
  5. Aug 21, 2019 at 7:22 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    You might be onto something. I'm wondering if the misfires destroyed the cat from the raw fuel dumping in it. I've seen it several times.
  6. Aug 21, 2019 at 6:29 PM
    parkman
    Park
    What exactly could have caused a clogged cat?
    auskip07 likes this.
  7. Aug 21, 2019 at 7:29 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    Sometimes it's just age or mileage.
  8. Aug 22, 2019 at 9:34 AM
    parkman
    Park
    Hmmm, thanks for the info.. I did a little research online this morning.. Symptoms sound right for what some of the repair sites talk about. Used my scanner today came up with the codes P101, P0137, P0300, and P455.
