Chip key question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WileyG, May 16, 2012.
  1. May 16, 2012 at 6:17 AM
    WileyG
    WileyG [OP] Member
    Alabama
    2007 DC 4x4 V6 AT 141 TRD Sport
    I searched and couldn't find an answer so here goes. I have the gray valet key from my '07 Tacoma that was totaled in March. I just bought another '07 TAcoma that only has 1 black chip key. Can the dealer reprogram my gray key from the other truck to work in my 'new' truck?
  2. May 16, 2012 at 6:29 AM
    TacoVerdeDos
    TacoVerdeDos Member
    Geo
    Maryland
    09 Reg 2wd manual
    OE color match grille, WeatherTech Visors, Fold-A-Cover, Pop-N-Lock tailgate handle, JVC single din
    Electronically it should be possible as you make the truck recognized the key, not the key to the truck. Mechanically probably not. The cuts on the blade would have to match the new key. Unless all the cuts on the new key are deeper you won't be able to re-cut the old key to match.
  3. May 16, 2012 at 7:10 AM
    Peru
    Peru Well-Known Member
    Jonathan
    Redmond WA
    SR5 -- V6 -- 2005 -- 4X4
    none
    just get a new rechipped key. her in Mexico you can get it done on just about every corner. Havent checked the prices but ive heard is pretty cheap -- bout 20 to 30 clams.
    I am sure in the US it can be done where the dealer is not ivolved and not too expensive.
    BTW -- I agree with the post above. once cut a key can not be recut to fit a diverent set of tumblers
  4. May 16, 2012 at 8:23 AM
    2011 TRD Sport
    2011 TRD Sport Active Member
    Jeff
    North Kingstown, RI
    2011 DC TRD Sport Lifted
    Lift Kit Ultra Goliath 17" LT275/75/17 BFG KO
    The chip can programmed but the metal key won't be able to turn the ignition. So it is kind of pointless. You can cut the head off and tape it to a metal head key if you want a "emergency key". At my shop that would cost you around 40.00 plus the key.
    Also a grey headed key cannot program a master key but that is another story.
  5. May 16, 2012 at 8:37 AM
    TurboGT
    TurboGT Stirring the pot since...
    Gabe
    Portland
    '06 DC LB 4x4
    OME lift w/ Dakars & 885's Remote Start w/ window control
    I picked up two new chipped keys for my truck off ebay.... uncut and ready to be programmed, cost me $35. Have a buddy that's a tech at a toyota dealership that got his parts department to cut them for me, and he programmed them.
  6. May 16, 2012 at 8:44 AM
    WileyG
    WileyG [OP] Member
    Alabama
    Looking at the key it only needs 1 new cut to turn the cylidner is why I asked......looking back I see how dumb it sounded without that info.
    But, I'll see if I can find a deal like the post above for $35 for 2
  7. May 16, 2012 at 9:49 AM
    Peru
    Jonathan
    Redmond WA
    none
    Strange -- it worked for me and it wasnt done at a dealer. It was done at a corner kiosk down the street. if they can cut a metal key then they can cut a programmable key.
    or i could have miss understood your post
