Chips (not the potato kind)
Discussion in 'Performance and Tuning' started by Met1149, May 8, 2012.
  1. May 8, 2012 at 12:42 PM
    Met1149
    Met1149 [OP] New Member
    Bill
    07 Tacoma
    Does anyone have any experience with plugging in chips designed to increase hp and gas mileage? I'm currently looking at something from autochipsdirect.com. Do these things actually work? Is there a trade-off or downside to doing this? What about reworking the air intake? Is this advisable with the chip. We have a yearly vehicle inspection - will this be a problem? We're talking 2007 Tacoma, 4cylinder.
    Thanks for the help!
  2. May 8, 2012 at 12:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    They dont work. The URD MAF Calibrator can give WOT improvements, as does teh APR-X1, but those are the only 2 I know of.
  3. May 8, 2012 at 12:47 PM
    09tacorunner
    09tacorunner Well-Known Member
    Duke City
    09 PreRunner TRD OffRoad
    chips dont do anything for the tacoma. as for gas milage best advice i could give you would to be keep the RPM under 2k
  4. May 8, 2012 at 1:57 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Things like SuperChip, Bullydog, Banks, Edge, SCT, HP Tuners, or Cobb, are all for ECUs that can be re-written. Ours cannot be, for the most part. That is why ours have to use piggy-backs or better. URD also now has the UCON EMS. ProEFI, and AEM are others.
