Chirp at cruising speeds
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ortacoma10, Aug 30, 2024.
  1. Aug 30, 2024 at 8:38 PM
    Ortacoma10
    Ortacoma10 [OP] Well-Known Member
    2010 Tacoma Trd Off-road 4x4
    2010 4.0 with 164k. Been having a chirp at low cruising speeds up to 45 mph. Not always consistent. Any idea if anyone has had same thing? Tia
  2. Aug 30, 2024 at 8:39 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Does it sound like crickets? I had a bad driveshaft center support bearing that was bad and made cricket chirping noises.
  3. Aug 30, 2024 at 8:42 PM
    Ortacoma10
    I guess you could say. Been putting it off but it’s gotten more consistent. Truck drives great overall
  4. Aug 30, 2024 at 8:46 PM
    BLtheP
    Plano, TX
  5. Aug 30, 2024 at 8:58 PM
    Ortacoma10
  6. Aug 30, 2024 at 9:01 PM
    BLtheP
    Plano, TX
    Yeah, mine didn’t do it 24/7 once it started. More like after driving for a bit, as if the bearing had to warm up. It went to the dealer the day after it started so I didn’t hear it long enough to gather any patterns.
    If yours sounds like mine, it’s pretty much guaranteed to be the bearing. Some people keep on driving with no problems besides the embarrassing noise. I was under warranty so off to the dealer it went. If I was out of warranty then I’d have kept driving and casually ordered parts and done the work myself when I had time. If doing the work yourself, you will need a u-joint as well because the u-joint by the bearing needs to be removed to get the bearing off. Some will argue that since you’re replacing one u-joint, it makes sense to buy 3 and do them all. Up to you. Dealer only changed the one for me, I had no u-joint problems. The bearing goes bad way more often than the joints do.
    Ortacoma10[OP] likes this.
