Chirp on takeoff?
Discussion in '4th Gen. Tacomas (2024+)' started by thefinalstraw, May 17, 2025 at 5:42 AM.
  1. May 17, 2025 at 5:42 AM
    thefinalstraw
    thefinalstraw [OP] Well-Known Member
    2024 Underground TRD Sport 4x4 Premium
    Now that the weather is nice and I am driving with the windows down, I frequently notice a very quick "chirp" sound when accelerating from a stop. It seems to come from the driver's side, and only once, but it's not every time - maybe half. Might be happening between low gears, but I'm still not 100% sure on the when. It is not the turbo whistle sound; it is much higher pitched, almost like a metal-on-metal squeak. Any thoughts??
  2. May 17, 2025 at 6:02 AM
    TheWildMan
    TheWildMan Well-Known Member
    3rd Gen 23 Tacoma OR
    Scrubbed some tires, and knocked a dent out.
    Pulley? Something from the belt? Would really suck from a new truck.
  3. May 17, 2025 at 6:13 AM
    thefinalstraw
    now that you say that, it does resemble a belt chirp sound. but it's so specific to takeoffs, i don't know.
  4. May 17, 2025 at 6:58 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    Some of them had an issue with the ac belt chirp....
    dont recall let alone conflicting info on approach of repairs, belt tensioner & belt vs actually replacing the ac compressor.
    TAKE IT IN!!!! Dont wait, no, not at the next oil change, yesterday....
    My first 24 sr5 had the noise but never dug into it further as I was in middle of buyback & had plenty of ammo already....
    Dont necessarily need to be moving but shortly after starting, you would get just a real quick 1 time squeak...
    Just 1x, till you turn it off & let it sit for some time, repeat...
  5. May 17, 2025 at 7:52 AM
    rybern
    rybern Well-Known Member
    N Alabama
    2023 TRD OR & 2000 SR5
    5100's & 3AAL, 265/70r17 Toyo AT3
    Could it be chirp of the tires? :burnrubber:
    Something I've never heard in my 3rd gen. :p
  6. May 18, 2025 at 5:58 AM
    GrrrMaker
    GrrrMaker 2024 Tacoma SR5 4x4
    Woodstock, GA
    2024 Celestial Silver SR5 4x4
    DV8 OE Plus Side Steps MCX Skid Plate Bonobo Front Recovery Points Bonobo Hitch Recovery Point (2" Soft Shackle) Redline Hood Struts Volume Knob for 8" Infotainment Screen (TacoMods on Etsy)
    Please clarify what you mean here...
  7. May 18, 2025 at 6:02 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    My 1st thoughts are either a bad pulley or U-Joint. But neither of those should be an issue on a 2024.
  8. May 18, 2025 at 7:04 AM
    slater
    San Diego
    here's what I know...
    my sr5 made the chirp
    it was few seconds after starting the vehicle, just 1x after starting, after sitting for some time
    ive dealt with probably multi thousands of belt / accessory related repairs in the lifetime of my ford career so know a thing or 2
    I never had mine looked at by dealer...
    few posts here,
    suggested 1 toyota tech replaced the ac compressor on 1 truck
    while another tech replaced belt tensioner, or belt & tensioner, as I stated I dont recall exactly....
    Both repairs could make sense depending on what they found, thats they key, what did they find.....
    AC compressor clutch could easily make the noise at initial lock-up / engagement, on the tacoma theres engagement regardless if your climate control, vent, ac, etc is on or off, your system can be completely shut off & your compressor will still cycle on / off, I have a post about that.....
    I can also see how maybe after sitting for some time you can have a faulty tensioner or compromised belt also causing that quick initial squeak....
    Thats all I got, theres a thread around here somewhere about it...
    My 24 sr5 made the noise daily, once it started making it, didnt do it from day 1 though so something did change...
  9. May 18, 2025 at 7:20 AM
    slater
    San Diego
    All that being said, the op may not be experiencing what im describing....
    What im describing is more of just a quick very short squeak shortly after starting the truck only...
    Has nothing to do with "take-off"
  10. May 18, 2025 at 10:24 AM
    GrrrMaker
    Woodstock, GA
    Okay, thanks so much for expounding. I usually don't roll with my windows down, but I'll start leaving the driver's window down when parking in my garage to see if I hear it on startup.
    What else was wrong with your SR5 that made you want to trade it in for your TRD?
  11. May 18, 2025 at 11:19 AM
    slater
    San Diego
    I liked the sr5 ALOT, actually somewhat prefer it over the sport & offroad, wanted the 14" display....
    It got bought back due to paint defects, I made thread documenting it...
  12. May 18, 2025 at 2:19 PM
    thefinalstraw
    yeah, this very specifically upon accelerating in low gears - nothing to do with how long the truck has been running. it can happen from any stop (or any time i slow down to the lowest gears).
    it is hard as hell to pin down, but to me it doesn't sound like it's coming from the engine bay. my kid put the passenger window down, and said he can only hear it faintly coming through my window. so i think it's something on the driver's side.
    so weird. might drive me insane. nobody else huh?
    one thing i keep going back to is the insane clunking i would get from the n-fabs i put on my 3rd gen, when i would go over hard bumps unevenly. but it took me FOREVER to realize it was the running boards making the noise, it was something about the way the flexed/how they were bolted. so i wonder if it's something stupid like that.
  13. May 18, 2025 at 3:55 PM
    slater
    San Diego
    take it in, end of story..
    Dont make excuses like half of the people on this forum....
  14. May 18, 2025 at 3:56 PM
    Taco Ji
    Taco Ji Well-Known Member
    New Jersey
    2025 TRD OR - Hybrid Bronze-Oxide, Premium PKG.
    Only chirp I hear on mine is the tires when I accelerate.
  15. May 18, 2025 at 3:58 PM
    slater
    San Diego
    One more thing, this may be it...
    Check / try to further secure the extra dangling chain that secures your spare tire...
  16. May 18, 2025 at 4:13 PM
    thefinalstraw
    that would be hilarious if it was the issue...but it is just ridiculous enough to be possible lol. imma go crawl under there right now.
  17. May 18, 2025 at 4:19 PM
    slater
    San Diego
    my sr5 did it, my sport didnt...
    actually can hear the dangling chain in the rear when ide close my door...
  18. May 18, 2025 at 4:30 PM
    thefinalstraw
    chain has been tucked. had a cookout and a few beers so not going to test it tonight, but stay tuned!
    rybern, slater[QUOTED] and ole like this.
  19. May 18, 2025 at 5:32 PM
    slater
    San Diego
    :cheers:
    Heres to hoping...
  20. May 18, 2025 at 5:47 PM
    GrrrMaker
    Woodstock, GA
    Gotcha. I think I would've liked the 14 inch screen too, but the rest of the upgrade to the TRD Sport wasn't worth it to me. Love my SR5 4x4 tons, other than the craptastic wheels SET put on it (whole 'nuther conversation, you can check my posts on it).
