Chirp Sound when clutch pedal not pressed
Discussion in '1st Gen. Tacomas (1995-2004)' started by Assforkr, May 13, 2015.
  1. May 13, 2015 at 1:16 PM
    Assforkr
    Assforkr [OP] Well-Known Member
    MA
    03 taco
    03 5spd v6. Getting a new noise chirping sound reminiscent of a slipping belt. Sound is best heard on driver side from underneath the car out of the engine bay. Belts have just been changed have good tension. Sound started as the temperatures in Boston started coming back. Sound rate is relative to revs and responds to throttle and is present during driving and idling in and out of gear. Sound dissapears when clutch is depressed. TOB? Idler? Any clues?
  2. May 16, 2015 at 5:14 PM
    Assforkr
    MA
    03 taco
    Cmon! Where are all the shade tree mechanics at? A whistling chirp just like a warped disk hitting a pad so it increases with speed. Sound is present when the car is and isn't moving and disappears when I depress the clutch pedal. Who's got ideas?
  3. May 16, 2015 at 5:15 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Clutch throwout bearing.
    Ripper likes this.
  4. May 16, 2015 at 6:00 PM
    Aught2TaCO
    Aught2TaCO Well-Known Member
    Troy
    Wheat Ridge, CO
    '02 Taco TRD, aka Pearly
    Billie 5100's, new leafs, Falken WILDPEAK A/T 3W, 265/75/16E
    I'm not familiar with your transmission, but I had a Sonoma with a chirping sound similar to yours. It turned out to be the clutch fork/pivot ball being dry. Applied grease to it and the sound went away.
  5. May 16, 2015 at 8:35 PM
    Assforkr
    MA
    03 taco
    Great suggestions! I will look up the DIYs the TB and pivot ball. Hopefully something will work because I'm tired of pretending the sound isn't annoying and turning up the music.
  6. May 17, 2015 at 5:29 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    TO bearing
  7. May 17, 2015 at 6:20 PM
    BAT24
    BAT24 Well-Known Member
    Ohio
    TRD Rugged Trail
    TRD - CAI Sport Hood Sport Grille Sport Headlights OEM LED Tails Factory Roof Rack
    Pilot Bearing
  8. May 18, 2015 at 11:22 AM
    Assforkr
    MA
    03 taco
    we have a winner. Aught2Taco wins with a blast of lithium spray lube onto fork pivot. All chirps and squeaks gone. Thanks all.
  9. May 18, 2015 at 9:28 PM
    Aught2TaCO
    Troy
    Wheat Ridge, CO
    Woohoo! Good to hear it was a cheap fix, glad to help Assforkr! Cranking the jams can be for pleasure now instead of noise cancelling.
  10. May 19, 2015 at 7:44 PM
    Assforkr
    MA
    03 taco
    Are you kidding? I've spent two days driving in silence and loving it. 8)
  11. May 19, 2015 at 7:48 PM
    Aught2TaCO
    Troy
    Wheat Ridge, CO
    Enjoy my friend, silence is golden... until you hear the latest noise lol.
