Chirping at idle when warm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoman10101, Mar 27, 2021.
  1. Mar 28, 2021 at 8:46 AM
    Waasheem
    Waasheem
    2007 xrunner
    Give the fan a spin, it should spin but have resistance and not keep spinning when your hand leaves it.
    Do the wooden dowel test described above.
    I’d look at the belt from the side. It should align perfectly with everything it touches, not being pulled sideways onto a pulley.
    Since you’re a professional at it, I’d remove the belt, spin every pulley, idler, tensioner. They should spin feeely, no notchyness, no wobbling.
  2. Mar 28, 2021 at 8:53 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Remove the belt, start the truck... if noise is absent, you now just have to narrow down which accessory it is; if noise is present... time to re-think the plan.
    wi_taco likes this.
  3. Mar 28, 2021 at 8:54 AM
    Waasheem
    Waasheem
    2007 xrunner
    Not necessarily. Mine does the same thing. Squealing noise but only at idle when cold, goes away once warmed up.
    wi_taco likes this.
  4. Mar 28, 2021 at 9:00 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    All the time you have replacing parts some twice and you don't want to try a 5 minute test . Good luck .
  5. Mar 28, 2021 at 7:27 PM
    Jason J
    Jason J Well-Known Member
    oregon
    08 tacoma 4x4
    Lets make sure you don't own a manual transmission with the chirp only present when there is no pressure on the clutch pedal?
    mojojojo78, 74cam and vtown like this.
  6. Mar 28, 2021 at 7:41 PM
    Tacoman10101
    Tacoman10101 [OP] Well-Known Member
    Ya I've had a manual Tacoma and FJ cruiser that had that, I know all about that annoying chirp and it's not that. Trucks auto and It sounds more of like a belt squeal
  7. Jul 8, 2021 at 11:02 PM
    Tacoman10101
    So just an update incase someone else ever has this issue I can save them lots of monies and tiiiiiiiime!!.... It was a super hot day, A/C was on, then the belt squeal came on for a bit lounger than normal, then it stopped, then the AC stopped working and then a really bad smell started blowing from vents. Soon after got the AC button flashing and my AC clutch was fried. But on the bright side... NO MORE BELT SQUEAL!!
  8. Jul 9, 2021 at 12:06 PM
    Waasheem
    Waasheem
    2007 xrunner
    Did you need to replace the belt? I had a compressor go out, smelled like burnt clutch material. Opened the hood, smoke & sparks were flying out of the compressor, the belt was shredded.
  9. Jul 9, 2021 at 12:24 PM
    Tacoman10101
    No my belt was fine, clutch just completely seperated. And if it did go I have 3 new belts just sitting there ‍♂️
