Chirping heater fan
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004TacomaSR5, Feb 8, 2017.
  1. Feb 8, 2017 at 8:17 PM
    2004TacomaSR5
    2004TacomaSR5 [OP] Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    My 04 started doing this recently and it's driving me up a tree. Does anyone else have this problem? Sometimes it does it, and sometimes not. Is there an easy way to go about stopping it without ripping the whole dash apart? It's getting to the point where I'm probably just going to quit using the heater altogether and just bundle up and deal with it. Even the radio can't drown out the noise.
  2. Feb 8, 2017 at 8:23 PM
    wamego
    wamego Well-Known Member
    2002 Tacoma 2x4 TRD SR5
    You might post a video on it. That could help.
  3. Feb 8, 2017 at 8:28 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Probably the blower motor if it goes away or changes the sound when you turn the vent speed up or down
  4. Feb 8, 2017 at 8:34 PM
    TacosConQueso
    TacosConQueso Well-Known Member
    Brian
    1999 Sierra Beige Tacoma 4x4
    +1 on this^
    Mine does this too, its a chriping noise that changes with the fan speed. You can pull the blower which is held in by just a few bolts under the dash on the passenger side, super easy. Mine had a bunch of pine needles and such. It helped a little but its back again so im going to try and oil it a little and see if that helps. Worst case is you get a new one for $40 and be done
  5. Feb 9, 2017 at 3:07 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Yip, common. Oil it or buy new.
  6. Feb 9, 2017 at 5:59 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I vote for not using the heater !!
    Then remember to keep both windows open so the windshield does not fog up
    I went without heat in Wyoming Montana is not much different
  7. Feb 9, 2017 at 6:31 AM
    01GreenTacoma
    01GreenTacoma Well-Known Member
    I always give mine a little bump with my foot and it seems to make it go away for a good while.....
    Xbeaus likes this.
  8. Feb 9, 2017 at 6:36 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Mine chirps to. Amongst all the other small noises a 20 y/o pickup makes it's surprisingly quiet. When my gf rides in my pickup (she has a practically brand new Mazda) all the little noises bother her some. Lol. I'm used to old vehicle noises. Shows character ha. Easy to replace the squirrel cage. Maybe you have a squirrel in there. Storing nuts for the remainder of winter. ;)
  9. Feb 9, 2017 at 6:40 AM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Don't oil it. Drop it down, clean it out with compressed air, then use graphite powder in the center.
  10. Feb 9, 2017 at 6:43 AM
    Xbeaus
    Beau
    I used oil that's meant for electric motors. Same stuff that I used on a pellet stove electric motor. Worked for quite a while until I replaced the motor. Amazon. $15 for a new cage
    Seabass[QUOTED] likes this.
  11. Feb 9, 2017 at 10:36 AM
    Madjik_Man
    Colorado Front Range
    It's your blower motor.
    Mine used to sound like a rodent orgy.
    I was going to buy a new one (around $45) but was given a used one that doesn't make noise. For now.
