Chirping in belt when gas is applied
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Brian808, Oct 6, 2024.
  1. Oct 6, 2024 at 9:09 PM
    Brian808
    Brian808 [OP] New Member
    I have a 2018 Tacoma sport with 27k miles original belts. I just need some help where the noise is coming from. Could it been the serpentine belt that’s making the chirping sound when I apply gas? When it idles there’s no chirping. Is it possible to just shoot some kind of lube or just replace the belt. Also my truck hasn’t been used very much in the past 3 months.
  2. Oct 6, 2024 at 11:48 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    There’s belt dressing you can apply. But belts aren’t that expensive and pretty dang easy to install. I just replaced mine again at 80k miles (first time around 35k) along with an idler pulley.
    Get a spray bottle (water) and squirt the belt a little bit and then give it some gas…see if it stops chirping. It’s probably the belt
    auskip07 and Chew like this.
  3. Oct 7, 2024 at 12:51 AM
    mit88
    mit88 Well-Known Member
    Planet earth
    Should check the tensioner too.
  4. Oct 7, 2024 at 4:00 PM
    TacoLin1234
    TacoLin1234 Well-Known Member
    Lance
    Sutherlin, OR
    2020 TRD Sport
    Yep. Probably just needs to be tightened up a bit.
  5. Oct 7, 2024 at 6:45 PM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    There was a TSB for belt chirp. Mine was changed via warranty @ ~30K IIRC to a V-rib pattern belt and went away.
  6. Oct 8, 2024 at 1:59 AM
    Brian808
    Sorry, didn’t realized the video never upload. I ended up figuring it out. It was the tensioner/ idler wasn’t good and ended up wearing out my belt also. Thanks for the help guys
