chirping noise after engine shutdown
Discussion in '1st Gen. Tacomas (1995-2004)' started by zigzagg321, Mar 26, 2009.
  1. Mar 26, 2009 at 7:13 PM
    zigzagg321
    zigzagg321 [OP] T100
    Ohio
    96 T100 SR5
    sliding rear window
    After I shut the engine off there is a "chirping" or "eeep" sound coming from what looks to be the VSV (EVAP) box on the right side of engine bay, upper portion. Its the black box with all the vacuum lines going to it... If I disconnect one of the fatter vacuum lines, the noise stops until I reconnect it again. It will emit this noise for about 15 minutes after engine shutoff. Anyone else have this happen? Is this normal?
  2. Mar 27, 2009 at 7:56 PM
    zigzagg321
    Ohio
    96 T100 SR5
    sliding rear window
    bump...
    anyone? I cant be the only one that has ever had this issue.. but maybe I am.
  3. Mar 28, 2009 at 12:15 AM
    95tojo
    95tojo Well-Known Member
    Jared
    So IL
    '19 Cement Grey TRD Sport 4x4 6MT
    the flange inside the valve may be going bad and leaking . . . causing it to make a high pitch squeel
  4. Mar 28, 2009 at 9:08 PM
    zigzagg321
    Ohio
    96 T100 SR5
    sliding rear window
    That black box looks expensive.. :eek:
  5. Mar 28, 2009 at 9:29 PM
    95tojo
    Jared
    So IL
    if thats what it is go find a junk yard . . . or you would be suprised at how cheap most toyota parts are . . . (not from the dealer)
  6. Mar 28, 2009 at 9:32 PM
    zigzagg321
    Ohio
    96 T100 SR5
    sliding rear window
    yeah...the aftermarket has a lot to offer. I prefer the oem stuff though.. so a junkyard would be a good place to look.
  7. Mar 29, 2009 at 1:49 PM
    tjgraner09
    tjgraner09 South Carolina Member
    TJ
    Conway, SC
    97 XtraCab
    Bilstiein 5100 w/ TRD Coils in the front, new fog lights, 2 12" isignia subs,
    i had the same problem dude still have it...
    my dad bought the truck in 97 brand new with 2 miles on it and had done it since then. I just say the truck is farting. nothing bad has happened so far
  8. Mar 29, 2009 at 3:00 PM
    zigzagg321
    Ohio
    96 T100 SR5
    sliding rear window
    good to hear that... I think its kinda funny myself... "meep"... "meep"... I have chuckled several times. Its lke the Road Runner is under my hood... lol.
  9. Mar 29, 2009 at 3:05 PM
    tjgraner09
    TJ
    Conway, SC
    97 XtraCab
    lol yeah when will (tacomaman06) and jeff (tigerfan00) were working on my truck it was doing it... they were like wtf is that. I said dont worry my truck just ate and now it has gas lol i wouldnt worry about it dude
    oh and dont take it to the dealer to find out what it is cause they will try to charge an arm and a leg to find out what it is and then say they dont know what it is (happened to my dad)
