Chirping Noise and Vibration
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Irish Tacoma, Mar 13, 2011.
  1. Mar 13, 2011 at 7:15 PM
    Irish Tacoma
    Irish Tacoma [OP] Member
    San Diego
    08 4x4 TRD Sport
    I have a 2008 Toyota Tacoma 4x4 Crew Cab TRD Sport with 53,500 miles.
    Lately my truck has been vibrating pretty good when I'm around 2000 RPMs. Vibration happens when accelerating and when cruising at speed, but always seems to be around the same RPM and is independent of speed. When I take my foot off the gas, the vibration goes away. Vibration only happens when drive is in gear and truck is moving, no vibe when stationary or not in gear.
    Also, when I punch it from a stop, I hear a chirping noise from what seems to be the front right of the truck. Sounds like metal on metal. Sound only present when I really punch it. Under "normal" acceleration, there is no sound.
    I just had the tires replaced which helped to reduce the vibration, but its still present. Also, the chirping is still present. I asked the mechanic at the shop to take a look at the u-joints when they were replacing the tires, but they checked out ok. Not sure where to look next. Any thoughts or questions
  2. Mar 13, 2011 at 11:53 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    how about the carrier bearing?
  3. Mar 14, 2011 at 12:07 AM
    Series1000
    Series1000 Gots a Taco!
    Vancouver Canada
    2007 Access Cab 4X4 4.0L
    3" Redi-lift (spacer lift) up front
    is it noisy in 4wd?
  4. Mar 14, 2011 at 8:12 AM
    Irish Tacoma
    San Diego
    08 4x4 TRD Sport
    I was told by the shop that my whole drivetrain looked good. How would I check the bearing myself?
    Also, I haven't tried to drive it in 4wd since this started happening. I'll try it this afternoon and post back.
  5. Mar 14, 2011 at 3:31 PM
    Irish Tacoma
    San Diego
    08 4x4 TRD Sport
    I just took it out again and I still get the vibration when in 4wd
  6. Apr 21, 2011 at 12:11 PM
    Irish Tacoma
    San Diego
    08 4x4 TRD Sport
    UPDATE: took my truck to the dealer to have it looked at...
    The rear drive shaft was out of balance / bent so the whole thing needed to be replaced. Fortunately it was covered under the powertrain warranty. Once they swapped it out, the truck drove like it was brand new.
