Chirping noise coming from engine
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Falcoholic87, Mar 26, 2023.
  1. Mar 26, 2023 at 7:11 AM
    Falcoholic87
    Falcoholic87 [OP] Active Member
    2005 Tacoma
    My 05 Tacoma just reached the 250,000 mile mark and she just recently started making a chirping noise. I had my belts checked yesterday with an oil change and they said they looked fine but I was leaking a small amount of oil from somewhere as a bit of it had collected on some hoses. I check my oil level most weekends and don't notice the level dropping.
    My question is how much of a concern is this minor oil leak and what can I do to make this chirping noise go away?
  2. Mar 26, 2023 at 7:31 AM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    An easy thing to do is to remove the belt, then start up the engine. You can safely run it this way for a few minutes when cold. If the chirp is gone, then it’s one of your spinning bits that probably has a bad bearing. Go through and check all the idler pulleys and the tension pulley, alt, A/C, water pump, power steering. If you’ve never replaced them, I’ll bet the idlers and tension pulley are all in need of replacement. All but one on my ‘11 needed it at 112K.
    Taco 422 and LeftyTom like this.
