Chirping noise on first drive of the day
Discussion in '1st Gen. Tacomas (1995-2004)' started by GreenTacoSr5, Sep 6, 2016.
  1. Sep 7, 2016 at 5:27 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Belts and other components can cause your symptoms. One thing not yet mentioned is the 3.4 "Fan Support Bracket". You can search "fan support bracket", this forum, posts by member "Dirty Pool" or start with this one. Fan Clutch Info...
  2. Sep 7, 2016 at 6:19 PM
    GreenTacoSr5
    GreenTacoSr5 [OP] Active Member
    1999 Tacoma prerunner 3.4
    Wow man thanks! both forums were really handy and helpful I'll be examining my truck and checking with a screwdriver the FSB for any sounds. Thanks again for the helpful information.
  3. Sep 7, 2016 at 6:33 PM
    indetrucks
    indetrucks Well-Known Member
    Christian
    Southern CA
    Supercharged 03 TRD Tacoma 4x4 Xtra Cab 5spd
    Based on that pic of your belt, I would replace all the belts ASAP.
    I am 99% sure the noise is one of your belts.
    Mine did the same chirping noise when I first drove the truck in the am. Went away after a block. Even though the belts appeared tight, they needed to be tightened up a wee bit more to make the noise go away.
    Belts can stretch with age and/or get glazed causing them to slip on the pulley.
    replace the belts and thank us later :)
    wilcam47 and GreenTacoSr5[OP] like this.
  4. Sep 7, 2016 at 7:00 PM
    GreenTacoSr5
    That's where I would most likely start by replacing all the belts, I'm about to reach the 150,000 mark! Yet regarding the tightness of the belts, I know im suppose to use a gear reach to reach a bolt that I would turn to make a pulley lose and that's how I'll be able to replace them... hoe would I make a belt tighter?
  5. Sep 7, 2016 at 8:41 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    alternator belt you tighten by loosening the alternator then get you belt to the desired tension and tighten the bolts that hold down the alternator. I believe the other adjustment is either on the powersteering pump and or a/c clutch...same concept. Otherwise if the tensioner is losing tension it needs to be replaced.
  6. Sep 7, 2016 at 9:57 PM
    GreenTacoSr5
    Thanks to everybody that took the time to reply I really appreciate it hope you have a good day.
