Chirping Nosie?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chrislee, Nov 19, 2023.
  1. Nov 19, 2023 at 7:37 PM
    chrislee
    chrislee [OP] Member
    Chris lee
    2017 Toyota Tacoma SR5
    6in Rough Country Lift
    hey guys,
    2017 tacoma with 35in grapps and 6in lift
    chirping noise coming from the rear? i can’t pin point where it is or what it can be.
    i’ve had ppl tell me multiple things. just trying to see what other people think
    just replaced the front brakes after i first heard it. so that eliminates one thing
    200k+ miles
  2. Nov 20, 2023 at 2:15 AM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    You replaced the front brake pads after hearing a chirp in the rear…?
  3. Nov 20, 2023 at 2:17 AM
    chrislee
    Chris lee
    no, it was time for a front brake change. i heard the noise before i even changed them. i just didn’t know where it was coming from until i heard it in the rear.
  4. Nov 20, 2023 at 2:24 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    When does it chirp?
  5. Nov 20, 2023 at 2:27 AM
    chrislee
    Chris lee
    pulling into a parking lot , pulling out the driveway, slow rolls
    between 0-15 mph is when i hear it the best
  6. Nov 20, 2023 at 2:30 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Flat ground? Over bumps? Both?
  7. Nov 20, 2023 at 2:39 AM
    boi951
    boi951 Well-Known Member
    Boo
    Galveston Island, Republic of Texas
    2020 SR5 2.7 2WD 2009 OR................. 2006 AC.................
    I had a chirping noise on my 2009 OR at about 130k miles.... it was caused by bad U-joints in my case.
  8. Nov 20, 2023 at 2:58 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    After some major service to my truck (which is stock), I had a chirp that was driving me nuts. It took several months before I could figure out how to consistently replicate it so the dealership could fix it. Initially I thought it was slow speed related but it turned out to be more RPM related and required a load to be put on it. So I learned I could replicate the issue by brake-torquing the engine.
    My issue ended up being a loose exhaust hanger. They tightened it up and the noise hasn't returned in several months since. Not saying it is your issue, but something to think about.
  9. Nov 20, 2023 at 6:56 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Drop the drive shaft and check the u-joints
    faawrenchbndr and chrislee[OP] like this.
  10. Nov 20, 2023 at 3:40 PM
    chrislee
    Chris lee
    mostly when turning into the driveway or red lights , stop signs , slow turns, etc
  11. Nov 20, 2023 at 3:41 PM
    chrislee
    Chris lee
    i’ll check the U Joints when i have a chance to
    thanks for the advice guys
  12. Nov 20, 2023 at 10:10 PM
    TRD-Troll
    TRD-Troll Smoked Orc 75% off
    NV
    2019 TRDOR DCSB AT
    Birds nest in the frame? :cookiemonster:
