Choosing a 3 inch Lift Block/spacer Kit after the TSB? What are my options??
Discussion in 'Suspension' started by Jeffman1991, Feb 2, 2009.
  1. Feb 2, 2009 at 6:41 PM
    Jeffman1991
    Jeffman1991 [OP] Active Member
    Jacksonville, Florida
    '08 Blue Pre-Runner TRD
    Standard Profile Black Toolbox, Straight Pipes with Borla Tips, Secondary air filter removal, K&N Air Filter, CB Radio with 4 foot whip, 50 watt PA, two 8 inch JL Subwoofers, Pioneer Headunit, Jensen 400 watt speakers all around. 3 inch lift coming soon.
    I recently got the rear leaf TSB done. I kinda like the trucks angle and overall look (plus more ground clearance) so instead of doing a lift and level I have decided that if possible I want to just lift my truck 3 inches in the front and back. All done as cheap as possible but still pretty good quality.
    Front: Either the toytec 3 inch spacer $140, but I did find this on Ebay which is tempting but probably poor quality.
    http://cgi.ebay.com/ebaymotors/Part...5&_trkparms=65:2|39:1|240:1308#ht_1033wt_1028
    Back: Because I have gotten the TSB done I figure I need blocks. Does anyone make a 3 inch block kit, can I just buy universal blocks or should I get the 1 1/2" inch toytec kit and add another 1 1/2" block.
    Thanks For reading, hope someone comes up with a unique idea. Id like to keep my parts total to $200-$250
  2. Feb 2, 2009 at 8:31 PM
    TacoTycoon
    TacoTycoon Well-Known Member
    Justin
    Hayes, VA
    07 TRD Sport 4WD Indigo Ink
    Bilstein 5100 Coilovers, Diff Drop Kit, TSB AAL, 285/70/17 BFG A/T Tires, 17X8 Helo HE835 Wheels, Rear Bilstein 5100s, Dual Flowmaster 50 series, TRD CAI, TRD Front Seat Covers, Rear Suspension TSB, 35% Tint, Redline Hood Struts, MagLite Mod
    well I can't really offer anything towards who manufacturers a 3 inch block kit, but in all honesty I would go with the ome spring/TSB AAL package from toytec, will yield a much better ride and it is not much more expensive than your $250 limit. Good luck with the lift bro and make sure to post pics when you are done regardless!
  3. Feb 2, 2009 at 8:36 PM
    6shooter
    6shooter Well-Known Member
    portland, or
    06 sport........
    plenty.......
    just to clarify, you gained no actual ground clearance.
  4. Feb 2, 2009 at 8:40 PM
    Khaos
    Khaos Big Member
    Bryant
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    A 3" lift is usually 3" of lift up front and 1.5" of lift in the rear.
    For the front, on the lower end you can go with Spacers (I'd advice against this). For $169 you can get adjustable Bilstien 5100s that will give you up to 2.5" of lift in the front and a better ride. If you want the 5100s contact Downsouth Motorsports, they are a vender here and have them for the cheapest price out there SHIPPED.
    Toytec recently released a rear AAL that works with the TSB leafs, so you don't have to run blocks.
    Under $200 for an entire lift is a pretty low budget. You can do it with Spacers/Blocks, but I wouldn't suggest it.
    BTW, You should come to the Daytona meet in March.
  5. Feb 3, 2009 at 4:35 AM
    Jeffman1991
    Yea Id still like to get a full three inches in the back. Any opinions on the ebay spacer kit? TacoTRD ill look into it Bolles Baseball has me pretty busy but it sounds like alot of fun.
  6. Feb 3, 2009 at 4:42 AM
    rick
    rick `
    if you put a 3" lift on the rear it will be like 4 inches higher than the front
  7. Feb 3, 2009 at 7:40 AM
    Notty
    Notty Well-Known Member
    5Twenty
    2017 DCSB TRD OR
    Bilstein 5100s OME887 Deaver AAL BAMF CMC ECGS Bearing Replacement Sprint Booster
    I have 3 inch spacers in the front from EZ-lift (extremetrucktoys.com) that were only $120 shipped. Then in the back I have the rear TSB and 1.5" blocks from wheelersoffroad.com that were only $69 shipped! So, for a total of $189 I got a 3 inch lift and I think it looks amazing and rides/handles fine. It obviously isn't the most popular way of lifting, but it works. Check the link below for pics! You'll see that with the 1.5" block and TSB you get the 3" lift in the rear and it looks great. If you tried to add another 1.5" in the rear (your 3 inch block) the rear would be WAY higher than the front!!
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/25438-got-my-wheels.html
  8. Feb 3, 2009 at 10:17 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    Hey,
    Here is that for the TSB
