Choosing between two similar front suspension setups
Discussion in 'Suspension' started by ardrummer292, May 23, 2020.
  1. May 23, 2020 at 12:58 PM
    ardrummer292
    ardrummer292 [OP] 500k or bust
    Austin
    Virginia Beach, VA
    2015 DCLB V6 A/T 4x4 1D6
    Overbuilt daily driver
    I could use some advice. I have two possible front-end suspension setups that will yield the same lift and load carrying capacity, but am unsure what one setup offers over the other.
    Setup 1: uses a longer spring and standard shock, which has 4.4 inches of travel.
    Specific parts involved: Dobinsons C59-354 spring and GS59-221 shock.
    Setup 2: uses a shorter spring and extended travel shock. This shock has a coil seat 1 inch taller than the standard shock above. It also has more travel, at 5 inches.
    Specific parts involved: Dobinsons C59-350 spring and GS59-220 shock.
    As previously mentioned, both setups have the same spring rate, the same lift, and the same load carrying capacity.
    I'm not sure what kind of performance difference I could expect between the two setups. Ride stiffness, risk of topping- or bottoming-out, suspension geometry issues, something else? Any experiences you can share are welcome.
  2. May 24, 2020 at 9:19 AM
    ardrummer292
    Austin
    Virginia Beach, VA
    Bump. I’m sure someone has an opinion.
  3. May 24, 2020 at 9:25 AM
    ZekeR7
    ZekeR7 Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    Not sure about performance-wise, but just make sure if you go with Set-up 2, you install an aftermarket UCA. For any extended/mid travel you need an aftermarket UCA. OEM will hit the springs at full extension.
  4. May 24, 2020 at 10:23 AM
    ardrummer292
    Austin
    Virginia Beach, VA
    Yep, that’s the plan. I’m still trying to decide between SPC, JBA, and Dirt King. Getting a (near) perfect alignment is really important to me, but I don’t know how much adjustability I need to get there.
  5. May 24, 2020 at 10:43 AM
    ZekeR7
    Honestly, you don’t need SPC. Kinda over kill.
  6. May 24, 2020 at 2:51 PM
    ardrummer292
    Austin
    Virginia Beach, VA
    Why do you say that?
  7. May 24, 2020 at 4:05 PM
    ZekeR7
    Were you planning to get the adjustable spc? You don’t need it unless you plan to go long travel.
  8. May 24, 2020 at 4:45 PM
    ardrummer292
    Austin
    Virginia Beach, VA
    I was considering SPC specifically because of all the fine tuning available for the alignment. Tires are expensive, so I’m gonna do everything I can to get the most mileage out of them.
    Front sight likes this.
  9. May 25, 2020 at 11:42 AM
    MT Hunting/Fishing Tacoma
    MT Hunting/Fishing Tacoma Well-Known Member
    2019 Cement Tacoma TRD Offroad
    Have you thought about Dobinson’s UCAs?
  10. May 25, 2020 at 11:45 AM
    ardrummer292
    Austin
    Virginia Beach, VA
    I haven’t done much research into them, since they appear to offer less adjustability than SPC at an equal/higher price. What’s your opinion on them?
  11. May 25, 2020 at 12:38 PM
    3 degrees of caster built in seem to be pretty stout. Not sure if there is any clearance issue if you decide to go a wider tire. Just figured since you were going with Dobinson, why you would not get the UCAs. SPC are well respected here except for a very few manufacturing defects that have been correct
    ardrummer292[OP] likes this.
  12. May 25, 2020 at 12:46 PM
    Rawdoggy
    Rawdoggy Well-Known Member
    Jba
  13. May 25, 2020 at 12:49 PM
    ardrummer292
    Austin
    Virginia Beach, VA
    The idea of sticking all with one brand is appealing, just to minimize potential interoperability issues. Trouble is, the Dobinsons have no adjustability and come in at $640 for the pair (with ball joint installation). I'd rather get the highly adjustable SPCs for $10 less, or go non-adjustable with JBA for nearly $200 less.
  14. May 25, 2020 at 12:50 PM
    Rawdoggy
    200$ to do freely with is way better.(they do mil dsc, I see your profile says navy)
  15. May 25, 2020 at 12:54 PM
    ardrummer292
    Austin
    Virginia Beach, VA
    On the flip side, saving $200 means nothing if my tires wear out too fast due to poor alignment. I'm leaning towards SPC because I can get my alignment perfect.
  16. May 25, 2020 at 12:57 PM
    Rawdoggy
    Your setup it way different than a standard, I revoke my rec’s. I misread. My bad!
  17. May 25, 2020 at 7:46 PM
    ardrummer292
    Austin
    Virginia Beach, VA
    I just pulled the trigger on the short spring/extended shock setup. I won't be buying the rest of the parts (UCA, ECGS bushing, axle shims, etc.) for awhile, so the installation won't be any time soon.
