Choosing the right offset
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomariley09, Nov 11, 2023.
  1. Nov 11, 2023 at 7:51 AM
    tacomariley09
    tacomariley09 [OP] Member
    2013 White Tacoma 2WD Prerunner
    Leveling kit
    Hi, I’m looking to get new rims for my 2013 Tacoma prerunner. I found a set I like but I’m wondering if a 15mm offset will fit. That’s all they have for this rim. Offset has me a bit confused so any help is appreciated.
  2. Nov 11, 2023 at 7:55 AM
    scocar
    scocar Patron of the Farts
  3. Nov 11, 2023 at 9:16 AM
    YotaFAB
    YotaFAB Well-Known Member
    this tool helps as well.
    tacomariley09[OP] likes this.
  4. Nov 11, 2023 at 9:39 AM
    tacomariley09
    Leveling kit
    Those are both great tools! Thank you. But how will I know if it will rub on my breaks or not?
  5. Nov 11, 2023 at 9:51 AM
    YotaFAB
    What are the wheel and tire specs you're looking at? lots of variables to consider. Rubbing on the spindle, UCA, and bumpers is something to consider as well as clearing the brake calipers.
  6. Nov 11, 2023 at 10:17 AM
    tacomariley09
    Leveling kit
    Same as I have on now which is 265/70 18. The rim I have now is 18x9 and an offset of 0 and it looks pretty close to the calipers already.
  7. Nov 11, 2023 at 10:21 AM
    tacomariley09
    Leveling kit
    I thought about running spacers but I’ve read a lot of negative things about them
  8. Nov 11, 2023 at 10:49 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    If that’s a +15 offset it’s gonna really close. That’s just bit more than a 5.5” backspace which it about the max back space on these trucks you can go. I’m assuming it’s a 9” wide wheel.
  9. Nov 11, 2023 at 11:54 AM
    tacomariley09
    Leveling kit
    Hey Steve, thanks for the reply. Yes it’s a 9” wide wheel. What’s your thoughts on wheel spacers?
  10. Nov 11, 2023 at 2:19 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Can you find another wheel that you like that has a lower offset? Maybe 0 or negative?
    Blacktacoma23 likes this.
  11. Nov 11, 2023 at 2:40 PM
    gotoman1969
    Are you saying that the backside of the wheel face is close to the caliper? Wheel spacer are a non issue as long as they’re quality unit ( spidertrax, bora etc . And bolt on hub centric units.
  12. Nov 11, 2023 at 2:43 PM
    gotoman1969
    What size tire are you running? Oops I see that you’re running a 265. Personally I’d run an 18x8 0 offset with that size tire if just changing wheels.
  13. Nov 11, 2023 at 6:16 PM
    tacomariley09
    Leveling kit
    Yeah I’m thinking about just going to a shop and have them do everything.
  14. Nov 11, 2023 at 6:18 PM
    tacomariley09
    Leveling kit
    Yes I did mean caliper. I’ll take a look at those brands. Thank you
  15. Nov 11, 2023 at 6:30 PM
    tacomariley09
    Leveling kit
    Do you know if KSP Performance is a good brand? I see good reviews but I’m sure ppl in here know best
  16. Nov 11, 2023 at 6:38 PM
    gotoman1969
    Im not familiar with that brand unfortunately but can confirm the ones I mentioned are of high quality and have a proven track record.
  17. Nov 12, 2023 at 12:10 PM
    scocar
  18. Nov 12, 2023 at 12:15 PM
    scocar
    I'd avoid wheel spacers and find a wheel that does not need them. There are so many cool quality wheels that fit our trucks, you might want to take more time.
    Although there may be quality spacers out there, you are adding another potential failure point, and it is increasing leverage force on your CV joints...oh wait you are 2WD but still, it is increased leverage on everything attaching the wheel to the suspension.
