Choosing the right size CB antenna
Discussion in 'Audio & Video' started by Madjik_Man, Jul 21, 2010.
  1. Jul 21, 2010 at 11:22 AM
    Madjik_Man
    Madjik_Man [OP] The Rembrandt of Rattle Can
    Colorado Front Range
    So I have a topper for the Tacoma that is always on, unless I'm hauling something big. And I was planning on mounting the antenna on the rear bumper in one of the corners. With the stock bumper I can't mount it in such a way that it sticks off to the side unobstructed.
    So I was wondering how tall of an antenna must I get? Just enough to clear the top of the topper? Does it even have to clear it?
    Thanks in advance
  2. Jul 21, 2010 at 11:35 AM
    mlittle
    mlittle T O Y O T A
    Michael
    Fort Sill, OK
    2014 Toyota Tundra Crew Max 4x4
    From what I've been told, the taller the better, but it all depends on what you plan to do. If you want to talk local, you don't need anything huge. If you want to talk with others who are further away, you would need a longer antenna.
    I am in the process of purchasing an antenna, but I want to make some measurement to see the distance from the top of the bumper to the top of my cap. I am most likely going to purchase a 4' antenna unless I find that it's too short.
  3. Jul 21, 2010 at 12:50 PM
    Madjik_Man
    I won't be using this like a trucker would, that's for sure.
    Mostly trail riding, local communications, and in case of emergency if I get stranded on a mountain pass somewhere (where cellphones don't work).
    I'll try to keep tabs on your findings, thanks.
  4. Jul 21, 2010 at 1:17 PM
    dhurley
    dhurley Well-Known Member
    Doug
    Colorado Springs, CO
    04 Double Cab TRD SR5 V6
    TRD, Snugtop Super-Sport, bedliner, receiver hitch, alarm mod, deck plate mod, AFE Pro-Dry S, Saddleman camo seat covers, TW decal, grey wire mod w/switch, DRL, LED cupholder mod, Dynomax Super Turbo, aux back-up lights, Devil Horns by Andres, "blue plug" mod for 2LO, shorty antenna, Pro Comp fog & driving lights, receiver shackle, 15% tint front windows, stainless nerf bars, Ultra Gauge, diff breather mod
    If you don't go higher than the topper, your best receive/transmit will be on only 2 sides of your truck. Putting the antenna on the driver side rear no higher than the topper, your best signals will be the driver side and rear.
    Some options could be a magnet mount for the roof, the 102" steel whip on the rear bumper, or a bracket between the topper & bed to move the antenna up higher.
  5. Jul 21, 2010 at 3:00 PM
    Madjik_Man
    So if I'm reading you correctly, if I mount it on the bumper and just go higher than the top of the topper, I should be alright?
    How much of the antenna should be above the top of the topper? Is just the tip okay or do I need more of the shaft up there? (that's what I asked her)
  6. Jul 21, 2010 at 3:18 PM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    Get a Firestik. Figure out where your going to mount your antenn and then get one that clears the topper by about 6 inches. You can tune (standing wave) the antenna with the little screw on the tip of it.
  7. Jul 21, 2010 at 3:36 PM
    Chachie
    Chachie Well-Known Member
    Justin
    Nor Cal
    '06 TRD OR, 4x4, Auto, 6" Fabtech, 35's
    Locker mod, Anytime fog mod, always 400w mod.
    For this you might want to look into a HAM radio. There arent too many people, if any at all, that monitor a cb incase of emergencies. Not to mention with ham, even on 2m you can hit a repeater 50 miles away. And if that repeater happens to have auto patch, then you can make a phone call from your radio.
  8. Jul 21, 2010 at 6:51 PM
    Madjik_Man
    Thanks!
    That's what I was planning on doing. Thanks.
    I read a thread here that got into the HAM radios and my brain nearly exploded.
    Maybe I'll have to revisit it, again.
  9. Jul 21, 2010 at 8:19 PM
    Chachie
    Justin
    Nor Cal
    Ya. I did a Ron of research before getting my license so if u want, shoot me a pm and I'll give you the low down.
  10. Jul 21, 2010 at 9:01 PM
    Madjik_Man
    Thank you. I appreciate it.
  11. Jul 22, 2010 at 5:15 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Most state police monitor cb ch 9. Not as effective as ham, though.
