Choosing tire size: 265 or 275
Discussion in '3rd Gen. Tacomas (2016-2023)' started by songmin695, Dec 16, 2022.
  1. Dec 16, 2022 at 9:43 AM
    songmin695
    songmin695 [OP] Member
    Min
    Memphis, TN
    2020 Tacoma SR 4x4
    none
    I have a 2020 Tacoma SR 4x4 with stock wheels (245/75r/16) with stock suspension. I'm upgrading to the typical Bilstein/ARB 5100 2" Assembled Coilover Lift Kit, OME 2887 2" 590lb rate front coils, and 1" Block Kit rear in the next week or so, and trying to decide what tire size I should use.
    I see a lot of people running 265/70r/17 and see no underlying issues.
    Has anyone experienced any rubbing/scrubbing with 275/70r/17 with a wheel size of 17x8.5 and -6 offset? The offset is what I'm concerned about and I'm trying to avoid CMC or any trimming. I don't have any mud flaps so that wouldn't be an issue.
    RaminMan likes this.
  2. Dec 16, 2022 at 11:15 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    I would stick with 265's, You could also go with 255/75's if you want taller tire
  3. Dec 16, 2022 at 11:29 AM
    Bishop84
    Bishop84 Well-Known Member
    8.5 makes more sense to have 275s
    don’t be afraid of cmc, it’s not that invasive, just ask for max caster with your alignment and see if it rubs
    DavesTaco68 likes this.
  4. Dec 16, 2022 at 11:32 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Poor tire selection in 275, either go 265 and be done or step up to 285 and all that comes with it.
    2Nice likes this.
  5. Dec 16, 2022 at 11:38 AM
    Brex69
    Brex69 Well-Known Member
    2023 Lunar Rock DC LB Off Road
    Do have a 4 or 6 cylinder?
    BigEasy likes this.
  6. Dec 16, 2022 at 12:17 PM
    jjsinaz
    jjsinaz Well-Known Member
    Jim
    Sun City West, AZ
    2023 TRD Sport DCLB Ice Cap 4X4
    Stick with the 265. With that offset and no mudflaps you should be fine
  7. Dec 16, 2022 at 12:23 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    So you’re swapping out rims?
    Are looking for the wider stance or just a taller tire?
    sixfourherbivore likes this.
  8. Dec 16, 2022 at 12:52 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I run 285s and for the past 3 years I was against 285s. I will say I'm happy to have some light in weight SL rated Toyos AT3s on my SEMA pro wheels with the factory mud guards, great alignment and no rubbing, barley any loss of mileage and I upgraded to the new KDMAX Pro 9 tune and I didn't notice any power loss. 265s do look small but your safe from rubbing.
    sixfourherbivore and DavesTaco68 like this.
  9. Dec 16, 2022 at 5:42 PM
    tndriver
    tndriver Active Member
    David
    Hohenwald TN
    2018 tacoma sr 4x4
    5100s and 265-75-16
    I basically had same truck/wheel/tire. Today I swapped to bilstein 5100s all the way around. 16x8 moto and 265/75/16 tire. It looks pretty good and rides great. But could have easily went bigger.
  10. Dec 17, 2022 at 10:29 PM
    White_Truck
    White_Truck Active Member
    Jacob
    2023 White Tacoma TRD Sport
    I just put 275/70r17 on mine. It has the Trd factory lift. (2 inch in the front 1 in the back). The tires fit with no rub.
    I got 8” wheels with +10 offset. I feel at -6 you could end up with some rubbing.
    don’t go 285 unless you don’t care about fuel economy at all. Already a pretty noticeable difference in mine with just the 275. But they sure look sweet
  11. Dec 17, 2022 at 10:41 PM
    RaminMan
    RaminMan Well-Known Member
    Littleton Colorado
    2020 Super White Tacoma TRD Off Road
    Just asked similar question, following!
  12. Dec 17, 2022 at 10:42 PM
    RaminMan
    Littleton Colorado
    Any pics?
  13. Dec 17, 2022 at 11:23 PM
    White_Truck
    Jacob
    Just got this one. The plus ten offset is perfect. Flush with the truck.
  14. Dec 17, 2022 at 11:28 PM
    Gord0
    Gord0 Well-Known Member
    255/75’s for me and amazed at how well this has worked out.
    I’ve been down the big/heavy tire rabbit hole before, not worth it. But it’s your money…
    White_Truck likes this.
  15. Dec 17, 2022 at 11:43 PM
    VaToy
    Parts Unknown
    285s in SL are lighter than anything in 275s as I have yet to see a 275 in a SL rating. I run 285s in Toyo At3s and they are 46 pounds and put on Toyota SEMA 4 runner wheels which are a +4. Gas mileage is averaging 17.5 to 19 in the city and no loss of power. I did upgrade my tune to the kdmax pro 9 so I'm satisfied. Plus no rubbing and able to keep my mind guards. The heavy tires is what kills the mileage. I re-calibrated the speedometer as well. IMG_20221115_144132442.jpg
  16. Dec 18, 2022 at 12:08 AM
    venezian
    venezian Well-Known Member
    Los Angeles
    2022 7545E
    Look at my post history. I have the same offset and 2” lift. 275’s no problem.
  17. Dec 18, 2022 at 12:30 AM
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    How many inches of lift?
  18. Dec 18, 2022 at 1:56 AM
    VaToy
    Parts Unknown
    Almost 3 inches in the front on Bilstein 5100s top setting, 1/4 shim for the lean and a 1 inch rear block, front diff spacer and a rear carrier bearing shim, ECGS Clamshell bushing, Sumo bump stops all the way around, the alignment is the key to no rubbing with the 285s on these wheels. Not one bit of trimming, I did slide the mud guards back by re-drilling a new hole on the bottom hole of the guard. Ride is awesome.
  19. Dec 18, 2022 at 2:31 AM
    Limetacop8530
    Limetacop8530 Well-Known Member
    2022 ELG TRD PRO 6SPD MT
    Nice truck
  20. Dec 18, 2022 at 2:36 AM
    VaToy
    Parts Unknown
    Thank you, I have done a lot of things that you just do see in the pic. I did the remote start, all LED interior lights, back up and reverse, new Led headlights, Rigid industries fog, Pro grill, exhaust, trd skid plate, tail gate lock, new speakers, sub and amp all hidden, front cam which work off the steering wheel controls, catch can TRD CAI, so yea I do a lot you can't see. If you need anything DM me.
    eurowner and gvfs like this.
