Chop/Cut/Trim
Discussion in 'Wheels & Tires' started by snorinlorin, Jun 20, 2011.
  1. Jun 20, 2011 at 2:25 PM
    snorinlorin
    snorinlorin [OP] Snorinlorin
    Maine
    2011 TRD Sport Dbl cab
    Laradoe tonneu cover,Weather tech window vents/ floor mats, OME 3 inch lift / AAL., Light Racing UCA's, Painted engine cover, Avid off-road step tubes,Cross Fab light bar,Hella black magic lights,Satoshi grille, Trophy D-551 wheels,285/70/17 Duratracs
    Hey guys, I'm sure there is a post on here somewhere with the answer,but I can't seem to find it, I have a 2011 DC Sport with a OME 3" lift, and 1.25 spidertrax wheel spacers.I want to mount P 285/70/17 BFG Rugged Terrain T/A's on my stock rims. My question is. Will I still need to cut the cab mounts when using the wheel spacers?
    Thanks in advance.
  2. Jun 20, 2011 at 2:27 PM
    BulletToothTony
    BulletToothTony Im only a dick 90% of the time
    You can call me Susan if it makes you happy.
    You may or may not some people get away with just taking the mudflaps off, others have to trip some and then some have to do the cab chop, if you do alot of off roading and flexing then you probably will want to...
  3. Jun 20, 2011 at 2:29 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    You shouldnt have to chop the cab mounts. You will mostly likely have to remove the front mud flaps and do some minor to moderate trimming around your front fenders. Its easy and can be done with a simple dremel.
  4. Jun 20, 2011 at 2:33 PM
    snorinlorin
    Maine
    I don't do a lot of off roading, a trip to deer camp couple times a year. Other than that pretty much pavement,of coarse paved roads here in Maine are like camp roads elsewhere
  5. Jun 20, 2011 at 2:44 PM
    BulletToothTony
    then you should be fine without the chop....
