Chr. Ward Trident Pro 600 Dive Watch
Discussion in 'Buy / Sell / Trade - Other' started by KarlTheToyotaGuy, May 17, 2018.
  1. May 17, 2018 at 11:01 AM
    KarlTheToyotaGuy
    KarlTheToyotaGuy [OP] Well-Known Member
    Karl
    East of DFW, Tx
    V6, 4WD, 5 speed ... With mudflaps.
    • Description
      A true CW bestseller, the Pro 600 combines modern dive watch looks with the robust build quality you'd expect of a Trident.
      The re-engineered 316L marine-grade stainless steel case now incorporates a zirconia (ZrO2) ceramic unidirectional bezel for scratch resistance, while the watch is watertight at depths of up to 600 metres (2,000ft) - twice that of its predecessor.
      The dial retains the guilloche wave pattern of the first Tridents but the new indexes are now deep-filled with SuperLuminova SLN T C1 for additional luminosity. Our new logo sits at 9 o'clock.
      The crown - embossed with our twin flag motif - is easier to use, while the backplate has the Trident motif deep-stamped and prominent. And if the self-winding movement is the same it's only because there's no better available mechanism for this watch.
    • Movement
      Swiss movement manufacturer Sellita started as an outsourced manufacturer of ETA's 2824-2 movement.
      Changes in the industry, and the expiry of IP rights associated with the 2824, led to Sellita developing its own virtually identical version, the SW200-1. The only real difference is the addition of a 26th jewel which sits just below the ratchet wheel and reduces friction associated with automatic winding.
    • Technical
      • Diameter: 43mm
      • Height: 13.30mm
      • Case weight: 104g
      • Weight with 21cm bracelet: 203g
      • Calibre: Sellita SW200-1
      • Case: 316L Stainless steel
      • Water resistance: 60 ATM (600 metres)
      • Vibrations: 28,800 per hour
      • Timing tolerance: +20/-20 seconds per day
      • Dial Colour: Black
      • Lume: SuperLuminova SLN-T-C1
      • Strap width: 22mm
      • Lug to Lug: 51.5mm
      Features
      • Swiss made
      • Self-winding mechanical movement
      • 38 hour power reserve
      • Date calendar
      • Central hacking seconds
      • Anti-shock system
      • Marine-grade, stainless steel case
      • Embossed screw-in crown
      • Unidirectional zirconia ceramic bezel
      • 3.4mm anti-reflective sapphire crystal
      • Guilloche wave pattern dial
      • Super-Luminova indexes and hands
      • Signature Trident counter-balance on seconds hand
      • Screw-down deep-stamped 3D backplate
      • Unique engraved serial number
      • Marine-grade stainless steel bracelet with micro-adjustable ratchet clasp
      • Luxury presentation case and owner's handbook
      $600 Shipped
