Chronicles of a High Idle Post Tune-up
Discussion in '1st Gen. Tacomas (1995-2004)' started by smokn, Feb 23, 2015.
  1. Mar 4, 2015 at 9:19 AM
    #41
    keakar
    keakar Well-Known Member
    karl
    louisiana
    yep, took me a while to find it so I figured I'd share.
    got a genuine Toyota tps for $25 shipped lol
    it came in a Toyota box so I think its some guy at the dealership stealing and selling parts on ebay but hey its brand new oem so I don't care where it came from as long as its original.
    #41
    lvs2rock likes this.
  2. Mar 4, 2015 at 9:45 AM
    #42
    smokn
    smokn [OP] Unsenior Member
    08 DCSB TRD SPORT SR5 4x4
    Don't ask don't tell:spy:
    #42
  3. Mar 5, 2015 at 7:36 AM
    #43
    lovemytacolots
    lovemytacolots Show your Taco some love every day!
    Jen
    Oregon
    98 3.4L V6 5vzfe 4wd TRD Off Road
    It starts correctly now, thanks to the best dealer tech ever.
    Hey OP! Wanted to ask you more details about your hot start issue. Was there any consistency to it - meaning, did it only occur at certain time intervals?
    In our case, it's been always at the half hour mark. If truck is full op. temp, then shut off, with hood down, then ~30 min later, it's excessive cranking. But the weird thing is, then once it starts, if you shut it off then try to restart it immediately after that, it starts right up. One of the mechanics that did a good amount of work on it felt that the hot starts were worst at the hour mark, but we always noted the 1/2 hour mark being the problem.
    Anyway - just wondered how similar/different our problems were with starting, and also wondered how your situation is coming along. Wishing you the best!
  4. Mar 5, 2015 at 9:43 AM
    #44
    smokn
    No time interval for me. Starting effort used to be directly proportional to engine temp.
  5. Mar 5, 2015 at 10:58 AM
    #45
    lovemytacolots
    Jen
    Oregon
    Ah, I see. So proportional to engine temp - what was it when the starting problem occurred? Was it an elevated ECT or elevated IAT that seemed to coordinate with your issue?
  6. Mar 5, 2015 at 12:01 PM
    #46
    smokn
    As best as I could tell, an elevated ECT. I don't exactly have a scientific basis for this, but I never even considered IAT as a problem. I just looked at the coolant gauge and knew it would be that hard to start.
  7. Mar 5, 2015 at 12:58 PM
    #47
    lovemytacolots
    Jen
    Oregon
    Gotcha. Sounds like overall, its a bit different from our problem, but I'm still hopeful this could be it for us too. Who knows - maybe when they malfunction, they display a variety of wacky problems? Hope so - would LOVE to find the answer to our situation.
    How is your hot start issue doing today? Do you still have your wife's MAF on your truck, or did you clean and put yours back in?
  8. Mar 6, 2015 at 2:39 AM
    #48
    smokn
    Yesterday my hot start was gone. I have my cleaned MAF sensor in. My lean code has stayed gone also.
  9. Mar 6, 2015 at 5:47 AM
    #49
    lovemytacolots
    Jen
    Oregon
    Yay!! This is great news for you, and hopefully might mean some good news in my future too! Thanks for keeping me updated! :)
    And congrats on smacking that damn hot start down to hell where it belongs! :)
  10. Mar 6, 2015 at 6:21 AM
    #50
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The throttle plate does not close completely that keeps it from jamming in the bore. If it closes all the way it will stick and you can feel it when you press the pedal it will make the truck lurch from a stand still.
  11. Mar 6, 2015 at 6:34 AM
    #51
    smokn
    Seems entirely logical. Thank you for enlightening me!
  12. Mar 6, 2015 at 7:25 AM
    #52
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    The throttle stop sets the closed position of the throttle plate (10 degree angle) to keep it from jamming. The "throttle opener" on the rear of the t-body keeps the plate open a tad more via a little spring tension when the engine is off. This allows some additional air flow during starting. As soon as the engine starts and vacuum develops the "throttle opener" allows (overcomes the spring) the plate to close against its stop at the normal idle position.
    A bit more can be found in post #1839 in the Lovemytacolots thread.
  13. Mar 7, 2015 at 4:31 AM
    #53
    geoyota760
    geoyota760 Allergic to pavement
    PHOENIX, AZ
    2019 TRD OR
    5.29 Nitros Bilstein ICON Kansei BFG
    :popcorn:
    sub'd
    Great information here...:)
  14. Mar 9, 2015 at 9:02 AM
    #54
    smokn
    Update: my idle is now either 750 or about 825, depending on the mood of the beast. I may not replace the IAC valve. I know it'll idle around 650 with a good one on it, but the FSM says 700±50 is acceptable. Besides, it may come down a little more given time to adjust and magic to fix it.
  15. Mar 10, 2015 at 8:38 AM
    #55
    lovemytacolots
    Jen
    Oregon
    Hey there OP!
    How's the hot start issue?
    Sounds like your idle is doing better, very cool!
  16. Mar 10, 2015 at 10:42 AM
    #56
    smokn
    100% better on the hot start!
  17. Mar 10, 2015 at 1:01 PM
    #57
    lovemytacolots
    Jen
    Oregon
    Hurray! Glad for you and hopeful for me! Just dropped off my donor MAF and told my mechanic about your situation. Fingers crossed.
  18. Mar 10, 2015 at 1:18 PM
    #58
    smokn
    Good luck!
    lovemytacolots likes this.
  19. Mar 14, 2015 at 7:40 PM
    #59
    smokn
    Just for the sake of completeness I figured I'd update my maintenance check list. Today I:
    -flushed the coolant
    -changed all 4 drivetrain oils
    -replaced my t-body gasket with a TRD (old one was shot)
    -got appropriately sized bolts for the t-body (the long spacer bolts were still in there)
    -greased all my slips and youies
    -replaced the freaking squeaky clutch spring with a 4 cylinder linear spring (best 4 dollars I ever spent)
    No drivetrain shock now, but there is a very minor hesitation like I described in an earlier post. I think it may be normal, I think I'm too used to driving an LS2 GTO and a well cared for 5.3 Sierra. Regardless, I get awesome mileage and my truck runs like a raped ape when I mash the go pedal. I guess I can't ask for much more. Thanks for a good truck, Toyota.
  20. May 21, 2015 at 7:16 AM
    #60
    lovemytacolots
    Jen
    Oregon
    FWIW, my hot start issue wound up being dripping fuel injectors, even though they were passing on injector testing machines. Replaced all 6 with brand new (not rebuilt/reman'd) Toyota OEM injectors, fires right up now! Also replaced a crapton of other stuff along the way as well, before a dealer tech finally figured this out for us about the injectors. Good luck to fellow Taco fans!
