Chux's 2013 Beach Buggy Build
Discussion in '2nd Gen. Builds (2005-2015)' started by Chux, Aug 10, 2014.
  1. Feb 6, 2019 at 6:08 AM
    #2761
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Achooally. Not sure if it matters but all the videos I’ve seen the ring rotates around on the soft shackle
  2. Feb 6, 2019 at 6:11 AM
    #2762
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'll be damned, it spins. I hadn't actually watched a video but saw them talk about friction, so I assumed it slid around a stationery ring. My bad.
  3. Feb 6, 2019 at 6:13 AM
    #2763
    Chux
    Chux [OP] Pura Vida
    NJ beaches
    2013 TRD O/R Beach Buggy
    Click on my Build
    Nimble9 and EatSleepTacos like this.
  4. Feb 6, 2019 at 6:13 AM
    #2764
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's the same video I just watched. Cool shit, I want one now.
  5. Feb 6, 2019 at 6:31 AM
    #2765
    Chux
    Chux [OP] Pura Vida
    NJ beaches
    Click on my Build
    Hah yea I want 3 rings to replace my 3 snatch blocks but at $100 a ring that’s not gonna happen.. I was def intrigued and wanted at least one.
    My theory is the recovery ring completes the synthetic revolution in off road recovery. First you had synthetic line itself, people still using bow shackles/D rings and snatch blocks. Than soft shackles came about and people were using synthetic winch line, soft shackles and snatch blocks (designed for steel cable). Now you got the trifecta of everything synthetic and designed for synthetic line use.
    The biggest issue I saw first hand was using a soft shackle attacking a snatch block to an anchor point. The snatch blocks I have dug into the soft shackle under pressure. The surface point of the snatch block to soft shackle is like 2 1/8” plates next to each other. Possibility of soft shackle failure or longgevity to the shackle would be an issue.
    EatSleepTacos[QUOTED] likes this.
  6. Feb 6, 2019 at 8:27 AM
    #2766
    cynicalrider
    cynicalrider #NFG
    Jersey
    Eliminating bow shackles all together (except standard pull points on the trucks) will definitely increase recovery speed. When I needed to do some crazy snatch block self recovery where I needed to move the snatch block from tree to tree, it was a royal pain in the ass unscrewing and screwing the bow shackle in over and over. Now I'm curious, if you are hooking a strap or line to your recovery points, are you using a bow shackle or one of your soft shackles? Or going bow shackle to soft shackle to strap?
  7. Feb 6, 2019 at 8:46 AM
    #2767
    Chux
    Chux [OP] Pura Vida
    NJ beaches
    Click on my Build
    Truu bout speed.
    And I guess if it’s puddle stuck it’s important to be on it before subbed.
    The other point to add is if a side pull is needed soft shackles to sliders are the perfect solution. 1. You can’t get a D ring on the slider 2. I would never wrap the line around the slider and attach the winch hook on the line itself.
    I have from day one of bumpers tightened down the D rings located on the recovery points with a wrench to deter theft. Admittingly before soft shackles, after a few times getting a wrench to undo the D rings I started going D ring to Dring. I have still kept them on the bumper so tight it’s impossible to undo by hand. So now I would put a soft shackle direct to the D ring.
  8. Feb 6, 2019 at 9:37 AM
    #2768
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yup all these issues I have experienced as well as well as the bolded scenario :anonymous: hence my purchase from you lol. It's annoying as fuck getting the wrench out for the d's that stay on the truck all the time. Especially when you are cold and already in a high stress situation. Tough because in my head I feel like I am chaining recovery items together, potentially creating more points of failure, but at the same time a hella tightly closed d ring shouldn't fail.
    Gunshot-6A likes this.
  9. Feb 6, 2019 at 9:41 AM
    #2769
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    this is the exact reason my d rings don’t live on the bumper. I keep them handy with my other recovery gear, so they’re rust free and ready to be used. They’re a tool, not an aesthetic accessory.
    geekhouse23, uurx and Gunshot-6A like this.
  10. Feb 6, 2019 at 9:43 AM
    #2770
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    But...but...how you gonna get all the 'Gram likes without shackles rattling around all over? :D
  11. Feb 6, 2019 at 9:44 AM
    #2771
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I prefer to pose on my hood semi nude. That really racks in the likes.
    DETaco13, geekhouse23 and uurx like this.
  12. Feb 6, 2019 at 9:59 AM
    #2772
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I was about to ask how else are you supposed to intimidate people at the mall? Especially those mall crawling Jeep fuck Bois..
  13. Feb 6, 2019 at 10:03 AM
    #2773
    Chux
    Chux [OP] Pura Vida
    NJ beaches
    Click on my Build
    Holy shit it’s the mother fucking Lair up in here... Y’all roll deep.
  14. Feb 6, 2019 at 10:05 AM
    #2774
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I regret nothing
    geekhouse23 and Gunshot-6A like this.
  15. Feb 6, 2019 at 10:13 AM
    #2775
    Gunshot-6A
    Conner
    Everett, WA
    We mallcrawl together, we 'Gram together. Taco Boyz 4 lyfe. :D
    geekhouse23 likes this.
  16. Feb 6, 2019 at 10:13 AM
    #2776
    Chux
    Chux [OP] Pura Vida
    NJ beaches
    Click on my Build
    Exact reason I keep my D rings on the bumpers at all times is the same reason I’m geared up for cross country even tho I’m just going to the grocery store. My stuff lives where it lives. Nothing has a temporary spot. With periodic visual inspection and countless use the D rings are fine to live on the bumper as anchor points, even on the east coast. It has zero to do with aesthetics. It’s like your saying why have a high lift out in the open permanently mounted when you can just throw it in the bed when you leave on trips..
    Gunshot-6A and uurx like this.
  17. Feb 6, 2019 at 10:16 AM
    #2777
    Chux
    Chux [OP] Pura Vida
    NJ beaches
    Click on my Build
    Why you haz no Taco in your profile pic.
    How a I suppose to now who you roll with :notsure:
  18. Feb 6, 2019 at 10:20 AM
    #2778
    Gunshot-6A
    Conner
    Everett, WA
    I roll with everyone as long as you're not a douche, or at least be a funny douche.... *cough* @Wheelspinner *cough*
    I've had my VT avatar since '09. Seems wrong to change now.
    Chux[QUOTED][OP] and geekhouse23 like this.
  19. Feb 6, 2019 at 10:25 AM
    #2779
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    All my recovery gear lives on the truck. It just lives in a dry environment, the rifle case on my roof rack. It’s nice and neat and organized, so in the event of a recovery (which typically raises stress levels) everything is ready to go. No fumbling with a frozen or rusted D ring.
    Your rebuttal would make more sense if I said to leave gear at home and only bring it on trips, but that’s not what I said.
  20. Feb 6, 2019 at 10:29 AM
    #2780
    geekhouse23
    Squad gang AF :cool:
    Side note: didn't realize this wasn't the lair until after I posted
    EatSleepTacos likes this.
