Cigarette Outlet Not Working Please Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Defend_Pono, Dec 4, 2013.
  1. Dec 4, 2013 at 12:16 PM
    Defend_Pono
    Defend_Pono [OP] TOYOTAHOLIC
    Kupono
    Oahu, Hawaii
    2015 X-Runner (Blue Ribbon)/2003 S-Runner (Radiant)/2015 X-Runner (Black)
    Purchased New: May 15, 2015 PERFORMANCE Sittin Sic Xii Performance Drop Kit Xii Performance Front & Rear Sway Bars Pro Comp 2.5 Drop Blocks URD Maf Calibrator URD Short Shifter AFE Stage 2 TCAI Air Raid Throttle Body Spacer Volant Air Ram Intake Mod 18' Magnaflow Muffler Doug Thorley Long Tube Headers Custom 2.5 Y-Pipe Custom Transparent Orange Pexi Glass Intake Box Cover Aftermarket Blue TRD Oil Cap LIGHTING Fog Light Mod Cali Raised 3x2 LED Amber Fog Light Pod Replacements Lamin-X Fog Light Film Tint Smoked OEM LED Tail Lights Amber LED Reverse Lights Amber LED Turn Signals 8K HID Headlights White LED Dome & Map Lights Custom Retrofitted Headlights (SOLD) 2015 TRD Pro Tacoma Headlights VIPMOTOZ Sequential Side Mirror Turn Signals INTERIOR Black Dash Over Orange Ball Shift Knob TRD All Weather Floor Mats Black and Orange Wet Okole Seat Covers Ultra Gauge EM EXTERIOR TRD Pro Grille Blue Ribbon Metallic Color Matched TRD Tailgate Spoiler TRD Exhaust Tip T2 Angry Eyelids Craven Speed Shorty Antenna Tacoma Bed Mat Weather Tech Window Visors Half Evo Mod Orange Painted X-Brace 5% Tint All Around Varrstoen ES2 Wheels (SOLD) SSR Professor SP4 Wheels (SOLD) Enkei RPF1 SBC Wheels (SOLD) Extang Revolution Low Pro Bed Cover AUDIO 12” Alpine Type R Subwoofer 2 6x9 Alpine Type R Speakers Custom Ported TRD Engraved Subwoofer Box
    I have changed the fuse for it twice, and it keeps on blowing. I have noticed that the battery of my truck seems to be a bit week and i am wondering if that is the problem. If not the weak battery, do you think its my amp that is blowing the fuse? Any ideas guys??
  2. Dec 4, 2013 at 12:18 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    You have a stereo amp plugged into it? They are only rated for a certain amount of draw, and any more will get the fuse too hot and will blow it. Do not put a higher amp fuse in there, you can fry the wiring and start a fire.
    Hardwire the amp to the battery with an inline fuse rated to the correct amperage for the amount your amp draws.
    What amp do you have?
  3. Dec 4, 2013 at 12:24 PM
    Defend_Pono
    Kupono
    Oahu, Hawaii
    No i dont have the amp connected to the cigarette plug, i was just thinking it might be draining all the power from the truck. I have a mtx 1000 watt amp, but for some reason i think its my weak battery. What do you think man?
  4. Dec 4, 2013 at 12:54 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    A weak battery will not cause fuses to blow. What are you plugging into the power outlet? How much current does it draw?
    My print shows a single 15 ampere fuse for Both Outlets Cig Lighter and Power Point. If that is exceeded it will blow the fuse. The only other thing in the circuit is the Wiring and the Accessory Relay.
    Assuming that the 15 Ampere Fuse is the one getting blown. You probably are over loading it with what is plugged in or you have a wire shorting to ground. Have you modified anything electrical recently?
  5. Dec 4, 2013 at 4:29 PM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    Quit smoking!
  6. Dec 4, 2013 at 4:30 PM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Damnit!!! beat me too it
  7. Dec 4, 2013 at 4:32 PM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    "Damnit"???
  8. Dec 4, 2013 at 4:36 PM
    RearViewMirror
    Craig Christ
    Sorry... Caught by the spelling police again dammit
  9. Dec 4, 2013 at 4:38 PM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
  10. Dec 6, 2013 at 4:11 PM
    Defend_Pono
    Kupono
    Oahu, Hawaii
    i dont smoke i use it to charge my phone
  11. Dec 6, 2013 at 4:13 PM
    Defend_Pono
    Kupono
    Oahu, Hawaii
    i only have those usb plug ins so i can charge my i phone but thats about it. i did my sounds a long time ago before this happened
  12. Dec 6, 2013 at 6:53 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    A weak battery shouldn't blow the fuse(Does it blow with a running engine?). If it's blowing only when you use the phone charger, I would suspect a bad ground. Pull the cig socket and inspect the wires in the back of the socket for corrosion or rubbing on metal. CLean and tightened your battery terminals if corroded or loose and maybe even have Autozone load test the battery and alternator for free if you suspect a low battery. Cold weather takes more battery juice (cold cranking amps) to start your truck and you don't want to be stranded.
