Cigarette outlets out not the fuse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BDMcGuire, Dec 1, 2016.
  1. Dec 1, 2016 at 10:46 PM
    BDMcGuire
    BDMcGuire [OP] Well-Known Member
    Brent
    Peoria, AZ
    06 Tacoma OR SBDC
    I've gone ahead and searched the forum as well as Google. There hasn't really been anything on this topic since 2012. So let's get it going. I was running two air compressors off both outlets on my 06. They then shut off simultaneously, I checked the fuses which were fine. For the hell of it I even replaced it. While I had the fuse compartments at my will I checked every fuse for the greater good and everything is fine.
    Anyone have the next go to for cigarette lighter outlets? Before making suggestions on OBA. I have it sitting in my living room ;), but.my phone could use a charge.
  2. Dec 2, 2016 at 2:09 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Not much there dude:
    15 Amp Pwr Outlet fuse >> Acc relay >> Power Outlet / Cig Lighter >> Ground.
    7.5 Amp ACC Fuse >> Acc relay Coil >> Ground.
    Maybe 7.5 ampere Accessory fuse or the acc relay or wiring issue.
    BDMcGuire[OP] likes this.
