Cigarette plug mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AMfowl, Oct 28, 2015.
  1. Oct 28, 2015 at 7:06 PM
    AMfowl
    AMfowl [OP] Member
    2015 Trd off road
    I've searched on the 2nd gen mods thread for power to cigarette plug anytime but can't seem to find it, can anyone post the link or suggest their own mod or is this even possible? I'm tired of having to live the ignition on to be able to charge my phone
  2. Oct 28, 2015 at 7:23 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
  3. Oct 28, 2015 at 7:26 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    ZachPrerunner likes this.
  4. Oct 28, 2015 at 7:31 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Cause they suck duhhh :rofl::bananadead:
  5. Oct 28, 2015 at 7:39 PM
    TacomaArto
    TacomaArto Well-Known Member
    Wisconsin
    2015 White DCSB SR5
    I actually debating a Frontier for like 3 days.
    #phew
    #gladiregainedclarity
  6. Oct 28, 2015 at 7:44 PM
    ramonortiz55
    Ramon
    Texas
    stock
    get out
  7. Oct 28, 2015 at 7:48 PM
    TommyG
    TommyG Around
    Grouch
    MELTING POT
    21 MAX
    No mods
    Yikes
  8. Oct 28, 2015 at 7:49 PM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    QFT.
  9. Oct 28, 2015 at 7:53 PM
    phx13
    phx13 Well-Known Member
    Rob
    2015 DCSB TRD O/R
    MT stuff, RTT stuff, the usual.
    Can't find the link right now, but just did it.
    -Disconnect neg from battery term.
    -remove lower dash portion.
    -remove top left bolt holding in fuse box in cab
    -loosen bottom left bolt on the bracket for the fuse box in cab about halfway.
    -rock fuse box towards you, see behind it on top there's like 3 relays? The one in top left corner (looking at fuses, so one closest to door) is the one you want. Mine was blue.
    -snake a small screwdriver in there and carefully start it out, then pull it out.
    -take apart relay, exposing insides.
    -cut a small zip tie and shove it under the littler rocker inside, thus holding it closed.
    -put relay back together and back in.
    -hook up neg batt cable. Check to see if 12v outlets are hot.
    -if so, reassemble everything.
    Took me like 15 mins, and that was taking relay apart twice, because I shoved the zip tie in holding relay OPEN the first time.
  10. Oct 28, 2015 at 8:13 PM
    ZachPrerunner
    Southeast TN
    o_O You initially thought about purchasing a Frontier before you bought the Tacoma? Or you're thinking about buying one?
    Arkie-Marty likes this.
  11. Oct 28, 2015 at 8:49 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    you dont even have to do that.... simply pull the relay from the socket. Get a 2-3in piece of wire with 2 male blade connectors crimped on either end, and use it as a jumper between the two main pins of the relay socket. Boom done.
  12. Oct 28, 2015 at 9:23 PM
    phx13
    Rob
    2015 DCSB TRD O/R
    Ehhh, I like my way more
    Tis more better n stuff.
    ramonortiz55 likes this.
  13. Oct 31, 2015 at 1:11 PM
    infensus
    infensus Active Member
    Seattle
    2015 Tacoma Access Cab 4x4 v6, SnugTop HiLiner
    small stuff: interior lights, cigarette outlet constant power, license plate lights
    Where is the relay? Also, all of the links posted for this are either missing pictures or pointing to dead word docs.
    https://www.tacomaworld.com/threads/cheap-free-mods.4838/page-6#post-57580 - All links to instruction documents are dead. - Ditto. - images dead, difficult/impossible to follow as a noob who has never done this.
    I'm trying to implement constant power to the 12V cigarette outlets in my 2014 Access cab 4x4. This is behind the accessory box. The second 7.5 A fuse from the left is the ACC fuse #4 according to the manual. Do I install a jumper here?
    Under the hood. The second 50 A fuse from the top, next to the grey square, is the AM1 fuse #31 which also affects ACC. What about putting a jumper here?
  14. Oct 31, 2015 at 1:41 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Do NOT bypass a fuse. Its the relay you need to remove then install a jumper across pins 3 and 5 in the relay socket. Im just not sure where the relay is located because the link I had bookmarked for future mods is also dead. Im sure somebody will chime in.
  15. Oct 31, 2015 at 2:15 PM
    nd4spdbh
    SoCal
    the relays you seek are on the BACKSIDE of the fuse panel thats inside the truck.
  16. Oct 31, 2015 at 3:45 PM
    infensus
    Seattle
    Thanks for responding. Do you mean the back side of the fuse panel behind the accessory box near the steering wheel, or the one under the hood next to the battery? Sorry I'm just starting out with modding and don't want to kill myself or the truck.
  17. Oct 31, 2015 at 3:56 PM
    phx13
    Rob
    2015 DCSB TRD O/R
    Backside of the fuse panel in the cab. When looking at the front of the panel, it will be upper left corner.
    Relay closest to the driver side mirror if that makes sense.
    If you're not comfortable with throwing a jumper on it (I wasn't because I didn't know exactly which one it was like you), then pull the relay open and use something to hold the connection points together (I cut a piece out of a zip tie, some people cut an old credit card or rubber)
    infensus likes this.
  18. Oct 31, 2015 at 7:16 PM
    infensus
    Seattle
    phx13 likes this.
  19. Nov 1, 2015 at 10:37 AM
    infensus
    Seattle
    Almost got it put back together except I unplugged the KARR alarm blue light wire, and don't know where to plug it back in! Horn starts blaring as soon as I reattach the neg terminal. Anyone know where the plug goes?[​IMG]
  20. Nov 1, 2015 at 3:43 PM
    infensus
    Seattle
    Anyone know where the Karr alarm box is usually installed? I've looked everywhere under there and can't find it. Really hoping I won't need to have this towed to the dealer just to plug in a wire.
