Cincinnati Area Thread (Tri-State, Ohio/Kentucky/Indiana)
Discussion in 'Ohio' started by Breezy, Nov 1, 2015.
  1. Nov 20, 2017 at 6:02 PM
    #3801
    omgwtfbbq!
    omgwtfbbq! Well-known Idiot
    Ohio
    2013 X-Runner
    I dunno but lemme know if you find a deal on it lol. Mine hasn't been done.
    tacofort likes this.
  2. Nov 20, 2017 at 6:05 PM
    #3802
    presta24
    presta24 Well-Known Member
    chris
    Cincinnati
    2014 Taco TRD 6spd, 2k3 SR5 4runner V8
    Scratches, dents, lots of squeaks.
  3. Nov 20, 2017 at 6:07 PM
    #3803
    presta24
    chris
    Cincinnati
    Wat he said. I actually don't know anyone that paid a shop to put their lift on. It's a huge cost savings to do it yourself, not to mention you'll understand what's what and that can help you big time on the trail, if you're gonna wheel. Or street even for that matter.
    PS. Don't let beertime anywhere near your beer, wife, or pets
  4. Nov 21, 2017 at 7:49 AM
    #3804
    dnaTRD
    dnaTRD Well-Known Member
    It's been posted a while now...figured I'd have better luck on here instead of craigslist
  5. Nov 21, 2017 at 12:45 PM
    #3805
    tacofort
    tacofort Well-Known Member
    Joe
    Cincinnati, OH
    2017 Toyota Tacoma TRD PRO, Automatic, Cement
    Adventure Trailers Tacoma Habitat Pelfreybilt Rock Sliders Line-X Pelfreybilt Pro mid, Gas, Exhaust Reroute Skids Hondo Unholey Dash mount Total Chaos Bed Stiffeners Redline Tuning Hood Lift Struts Weathertech Floor Liners
    My vote is get all the weight and armor on, then suspension, then tires, but that's me. I don't think there is a wrong way to do it, so go for it. I got mine too heavy right now, but that will all change in the next month or two. Just been too busy lately.
    Jibbs[QUOTED] likes this.
  6. Nov 21, 2017 at 12:49 PM
    #3806
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    The problem is that I already have tires and they are only narrowly avoiding rubbing. That's part of why I'm opting out of a full bumper up front til later, because I don't know how much wiggle room I have before I start rubbing. I want to get the winch on ASAP as possible, so I'm going the route that adds minimal weight up front then doing suspension next because if adding the slimline bumper + winch doesn't make me rub, I'm sure adding sliders and skids will. It's all a delicate balancing act around 'I dont want to cut up my fender liners'
    dirty deeds likes this.
  7. Nov 21, 2017 at 1:06 PM
    #3807
    tacofort
    Joe
    Cincinnati, OH
    I took an angle grinder to my fender liners when I put on the steel bumper. What type of suspension are you planning front and rear? You might be able to do a cheap spacer on the front (I know sacrilege) to buy you some time. Or I wonder if better bumpstops would help?
  8. Nov 21, 2017 at 1:16 PM
    #3808
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Planning either Fox 2.5s front and 2.0s rear, or just getting the 3rd gen specific OME setup. Haven't decided yet, basically gonna come down to what kind of budget I'm working with when the time comes since it's about a $700 delta, unless there's another crazy Fox group buy next year.
    I'll probably go with Fox cause I don't want to settle. All I know for sure now is I'm definitely getting progressive.
    JHEAL77 and tacofort[QUOTED] like this.
  9. Nov 21, 2017 at 1:16 PM
    #3809
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Bump stops only "help" when you are at the end of down travel. The good one soften the bump when you bottom out.
    You're actually on to something with the top plate spacers. I ran them for 14 months on my current truck until I knew what I was going to use for my final lift. So long as you don't go hucking giant whoops or jumping dunes, they really aren't as bad as some will tell you. You end up with same ride as stock. I put a spacer between the bump stop and the frame to prevent the shock from bottoming and chived on! 2 trips to Black Mountain on $75 ebay spacers.....no regrets.
    Not a long term fix, but a good short term bail out if there's hard rubbing.
    Or....$500 for 5100s and coils...
    tacofort[QUOTED] likes this.
  10. Nov 21, 2017 at 2:52 PM
    #3810
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    51s are digressive. As near as I can tell billy doesn't make anything progressive for our trucks
  11. Nov 21, 2017 at 3:08 PM
    #3811
    presta24
    chris
    Cincinnati
    Blablabla
    dirty deeds and Bluegrass Taco like this.
  12. Nov 21, 2017 at 3:49 PM
    #3812
    tacofort
    Joe
    Cincinnati, OH
    Agreed on both counts. Wasn’t sure how low he was. Pretty sure bumpstops would raise me a little bit with all my truck’s weight. Lol.
    Lt. Dangle likes this.
  13. Nov 21, 2017 at 4:00 PM
    #3813
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Bump stops kept you from fully compressing into your suspension components that don't have springs or rubber surfaces. Which is UPtravel.
    DOWNtravel would be where limit straps come into play.
    With my 2/3 motor, as it's been put :), and 885 coils, don't think I've ever touched em up front. But the new ones need put on regardless
  14. Nov 21, 2017 at 4:19 PM
    #3814
    tacofort
    Joe
    Cincinnati, OH
    Still haven’t gotten rid of my trd pro rigid fog lights. If anyone is interested? I took care when removing the bezels, they’re intact. I unwired the factory fogs past where they joined together and snipped them past the connector. Would make for an easy install for anybody.
    Ordered a little keyed switch to put in the back of the habitat, so I could energize a relay to turn on all the lights around the vehicle from the back in the event of an animal or whatever screwing with my rig. Excited to install it. Still figuring out the wiring, but it will basically bypass all my other wires and turn everything on.
    Replaced my factory low beams with LED replacements due to the headlights being pathetic in comparison, now it looks like the high beams need to be replaced. Seems like I might anger a few folks. :)
  15. Nov 21, 2017 at 4:42 PM
    #3815
    tacofort
    Joe
    Cincinnati, OH
    On a side note, anybody going to SMOR?
    https://www.smorally.com/
    Met a dude at expo east that had a Habitat next to mine. It looks like a lot of fun for a long weekend event and not too far from all of us.
    Bluegrass Taco likes this.
  16. Nov 21, 2017 at 4:45 PM
    #3816
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Will be pulling in the driveway after Moab trip about that time.
  17. Nov 21, 2017 at 5:21 PM
    #3817
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Subd. Check yo text messages bb
    presta24 and dirty deeds like this.
  18. Nov 21, 2017 at 5:24 PM
    #3818
    dirty deeds
    Nick
    Eastern KY
    Btw, I think the 6100 series of Billies are progressive shocks. Not 100% on that
  19. Nov 21, 2017 at 5:35 PM
    #3819
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    At least the 6112s are digressive according to the Bilstein site. Those are also almost as expensive as OME stuff new
    dirty deeds[QUOTED] likes this.
  20. Nov 21, 2017 at 5:43 PM
    #3820
    dirty deeds
    Nick
    Eastern KY
    Just buy some shocks already damn it
