Cincinnati Area Thread (Tri-State, Ohio/Kentucky/Indiana)
Discussion in 'Ohio' started by Breezy, Nov 1, 2015.
  1. Dec 21, 2017 at 8:12 AM
    #4401
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    beertimecontinuum likes this.
  2. Dec 21, 2017 at 8:13 AM
    #4402
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Look on the connector itself, might be a part number. Or the wire size and connector style (round tube or square tube)
    That's all the info you need to buy a crimp on connector. Wire size and is it a square or round hole
    Caboose117[QUOTED] likes this.
  3. Dec 21, 2017 at 8:15 AM
    #4403
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Good info! Couldn't find any markings on the connector, it looks like a 16 gage maybe? Lol
    I would just call baja Designs and ask them if they'd send me some spares but they're all off for the holidays
  4. Dec 21, 2017 at 8:16 AM
    #4404
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Guess I'll just have to be patient :p
  5. Dec 21, 2017 at 8:18 AM
    #4405
    dirty deeds
    Nick
    Eastern KY
    Just buy connectors that can handle 16 ga and be done with it.
  6. Dec 21, 2017 at 8:20 AM
    #4406
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    It's gotta mate to the other side :p
  7. Dec 21, 2017 at 8:43 AM
    #4407
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    What light are you looking for connector info on?
    The Squadron/S2 Series Lights use a 2-Pin Delphi Weatherpack connector set very similar to the one shown here:
    https://www.amazon.com/Delphi-Packard-Weatherpack-Terminal-16-14/dp/B004DVM7RG
    The connector with the green seal is what is included on the harness side. The larger connector is what we include on the lights. These lights use 16 gauge wiring.
    The XL/S8/OnX6 Series Lights use a 3-Pin Delphi Weatherpack connector set very similar to the one shown here:
    https://www.amazon.com/Delphi-Packa...4536&sr=1-4&keywords=3-pin+delphi+weatherpack
    The connector with the green seal is what is included on the harness side. The larger connector is what we include on the lights. These lights use 12 gauge wiring.
    -Bailey, Baja Designs
    www.bajadesigns.com
  8. Dec 21, 2017 at 8:52 AM
    #4408
    dirty deeds
    Nick
    Eastern KY
    Exactly. Look at both sides, see how they mate, buy connectors. Done
    lol
  9. Dec 21, 2017 at 8:53 AM
    #4409
    dirty deeds
    Nick
    Eastern KY
    Looks to me like Baja found you and is very helpful in this matter!
    Caboose117 likes this.
  10. Dec 21, 2017 at 9:10 AM
    #4410
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    They are for the onx6 bars
    I ran one to the negative terminal to the battery and ran one to the power/switch on my switchpro
    And left the green wire slot unconnected.
    Unless that's wrong? Lol
    I basically wired it right but did so incorrectly to make it a proper water tight connection so I need to redo the female side
  11. Dec 21, 2017 at 9:11 AM
    #4411
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Seems like I should have saved everyone time and fustration and just called Baja Designs but Kellan said everyone was off for holidays haha
  12. Dec 21, 2017 at 9:26 AM
    #4412
    Baja Designs
    San Marcos, CA
    That is correct. White = Positive +, Black = Negative -, Green = Mode (leave disconnected if not used). If you are using our harness just run the negative to a ground and positive switch leads to the switch.pros.
    Here are our Holiday Hours:
    Friday 12/22 - 8:30-12:30
    Closed Weekends
    Monday 12/25 - Closed
    Tuesday 12/26 - 8:30-5:30
    Wednesday 12/27 - 8:30-5:30
    Thursday 12/28 - 8:30-5:30
    Friday 12/29 - 8:30-12:30
    Closed Weekends
    Monday 1/1 - Closed
  13. Dec 21, 2017 at 9:31 AM
    #4413
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    I just needed a couple more of this female pins, my connectors are good and so are the seals I just improperly crimped them and would like to redo them :)
  14. Dec 21, 2017 at 9:40 AM
    #4414
    Baja Designs
    San Marcos, CA
    Please give us a call if you don't want to order off Amazon. We'd charge you flat rate shipping of $7.15 and maybe a couple bucks for parts (depends how many pins and seals you need).
    800-422-5292
  15. Dec 21, 2017 at 5:16 PM
    #4415
    Mlskid
    Mlskid Member
    2008 Silver Taco 2wd
    I've seen those pins for computer connections as well so if you're looking for a local option check with computer stores and see if they have any ideas. As for crimping them you should be able to do that with something like this:
    https://www.moddiy.com/products/Professional-Molex-Crimping-Tool.html
  16. Dec 21, 2017 at 5:42 PM
    #4416
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    I actually hadn't considered a computer repair store or something.
    The common problem I've run into lately is to many business have gone under as lexington has become more commercialized and filled with a Starbucks or Walmart on every corner. It's made finding places like RadioShack that used to be common place more like finding the plastic store @Bluegrass Taco helped me find a week or so ago.
    I think I've got it sorted out now but those are def some good options if my option doesn't pan out haha
  17. Dec 22, 2017 at 9:05 AM
    #4417
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    Female side always be leakin bruh...lol
  18. Dec 22, 2017 at 3:54 PM
    #4418
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Internet killed the neighborhood stores
  19. Dec 22, 2017 at 4:13 PM
    #4419
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    Agreed
    Which makes finding unknown products in person impossible
    "Well find it online"
    But I don't know the size
    "Google it"
    Ughhh
    Lucky you knew of that plastics store and bailey was still working the social media stuff to see my quandary on that pin
    dirty deeds likes this.
  20. Dec 22, 2017 at 5:01 PM
    #4420
    dirty deeds
    Nick
    Eastern KY
    Most vehicle lighting wiring I've seen is under 12ga.
    Bluegrass Taco and Caboose117 like this.
