Cincinnati Area Thread (Tri-State, Ohio/Kentucky/Indiana)
Discussion in 'Ohio' started by Breezy, Nov 1, 2015.
  1. May 7, 2018 at 7:42 PM
    #6121
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Did you find out that Hooters in Newport is having a wet tee shirt contest on May 26????
  2. May 8, 2018 at 5:26 AM
    #6122
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Funny how that shit happens
    TRDZILA[QUOTED], mwc273 and tacofort like this.
  3. May 9, 2018 at 12:22 PM
    #6123
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    DCSB 12 slightly lifted Tacoma
    Ripped off all four mudflaps. Scratches all down both sides 6112’s up front on 3rd notch 5100’s in back with Toytech 1” block Skids & sliders from SOS Concepts I got rid of the 1” block and put on Wheelers 1 1/2” progressive AAL. SPC UCA. Be sure your standing on the drivers side when reading the instructions! I swapped sides so many times that I can swap UCA’s in 15 minutes. I put in the 3/4” spacer to eliminate the Taco Lean, and just got my 4th alignment. Traded the OEM rims for 17” Sport rims and a bora bora 1” spacer. I got my Firestone 285/70/17 MT2’s. Pelfreybilt gas tank skid and hi-lift jack should be here Friday. Looking at bumpers, but I think they will wait for next year. So far I’m happy with my build. I’ve done it all myself, leading to a lot of cussing and frustration, but it’s all mine.
    Not sure how this works. I had a couple of rubbing issues with my new tires that I took care of with a heat gun. I put in my 3/4” taco lean spacer, got it realigned and now I’m going to have to do the cab mount chop, or shave off some rubber like a monster truck does.
    tacofort likes this.
  4. May 9, 2018 at 12:52 PM
    #6124
    dirty deeds
    Nick
    Eastern KY
    Where's the rub? Are you sure the alignment is correct?
    Or, ignore my questions. Cut all the things! :sawzall::welder:
    Jibbs likes this.
  5. May 9, 2018 at 12:53 PM
    #6125
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    Just do it like I do. I have rubbing, I just let it rub until it will rub all the rubbing it can do where it won't rub any more.....
    Problem solved :cheers:
  6. May 9, 2018 at 12:55 PM
    #6126
    dirty deeds
    Nick
    Eastern KY
    Just take your fenders off. You don't really need them in the woods.
    TRDZILA likes this.
  7. May 9, 2018 at 1:41 PM
    #6127
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    When turning left going up into my driveway is when it happened.
    There’s fresh rubber shavings on the cab mount.
  8. May 9, 2018 at 1:42 PM
    #6128
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    I’ve already trimmed the flares.
    Gonna have to go the bushwhacker route.
  9. May 9, 2018 at 1:48 PM
    #6129
    dirty deeds
    Nick
    Eastern KY
    Gross.
    Sounds like you just need a CMC
  10. May 9, 2018 at 2:05 PM
    #6130
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    They also hit up top when the tires are stuffed.
    I trimmed the lip, but I don’t think it’s going to be enough.
  11. May 9, 2018 at 2:18 PM
    #6131
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    On the bright side,, my truck sits level and I shimmed the carrier bearing and fixed the driveline vibes.
  12. May 9, 2018 at 4:24 PM
    #6132
    dirty deeds
    Nick
    Eastern KY
    Touching the uppers at stuff?
  13. May 9, 2018 at 4:36 PM
    #6133
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    The top part of the flares.
    Bluegrass Taco likes this.
  14. May 9, 2018 at 4:36 PM
    #6134
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    I like touching the Uppers while at Full Stuff personally.
  15. May 9, 2018 at 5:00 PM
    #6135
    dirty deeds
    Nick
    Eastern KY
    Take em off or cut more
  16. May 9, 2018 at 5:01 PM
    #6136
    dirty deeds
    Nick
    Eastern KY
    :gossip: I have small tires. Glad I could help tell ya to cut your truck up :D
    TRDZILA likes this.
  17. May 9, 2018 at 5:12 PM
    #6137
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    If they can make it through GSMTR next week I might leave them alone for awhile.
  18. May 10, 2018 at 2:43 AM
    #6138
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Space bump stops to limit front travel or cut flairs
    beertimecontinuum and tacofort like this.
  19. May 10, 2018 at 3:36 AM
    #6139
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    I think I’ll draw the line right there on doing everything myself.
    I’m fairly confident I’ll screw it up and make it look like crap.
    Good idea though,,,, as long as someone with a better eye for what the finish look will be is doing the cutting.
  20. May 10, 2018 at 8:21 AM
    #6140
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    *and
