Cincinnati Area Thread (Tri-State, Ohio/Kentucky/Indiana)
Discussion in 'Ohio' started by Breezy, Nov 1, 2015.
  1. Mar 12, 2019 at 6:18 PM
    #8321
    09TRDSport4x4
    09TRDSport4x4 OCD Approved!
    Nick
    Southwest Ohio
  2. Mar 12, 2019 at 6:19 PM
    #8322
    09TRDSport4x4
    Nick
    Southwest Ohio
    How do I not buy those for $695 shipped?
    Edit... I bought them. Looks like I’ll officially be joining the 33” club. And I guess that solves the tire dilemma. Now I just need to order new wheel spacers. Then, once everything arrives, I can install my new top plate spacers to level my lift, add the SPC uppers and hopefully get the new tires mounted and an alignment all in the same day.
  3. Mar 13, 2019 at 7:47 AM
    #8323
    dre5491
    dre5491 Well-Known Member
    Devin
    Cincinnati
    2019 MGM TRD Off Road
    Do seat covers count?
    Just be like me and run over something on the hwy and destroy a tire. I used it as an excuse to upgrade to 265/75/16 Cooper St Maxx
  4. Mar 13, 2019 at 7:58 AM
    #8324
    09TRDSport4x4
    Nick
    Southwest Ohio
    Just ordered the wider wheel spacers. Now I’m gonna have to pick a day to take off work and go to town on the truck. Anyone have any tips or care to lend a hand with the SPC uppers? Also, I don’t have a spring compressor so I’m a bit worried about how I’m going to swap the top plate spacers. I bought the longer studs for the thicker spacer but from what I’m reading, the shock assembly needs to come out and be disassembled to install the new, thicker spacer, at least on the driver’s side. I might be able to slide the 1/4” spacer into the passenger side without taking as many things apart since it can reuse the OEM studs.
  5. Mar 13, 2019 at 8:29 AM
    #8325
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    What Matt said. You'll have to bend some metal out of the way for the UCA bolts to come out completely. Battery removal may be needed for driver side also.
  6. Mar 13, 2019 at 8:57 AM
    #8326
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    No spring compressor method is where its at. loosen the LCA bolts just a little so they can swing down. Also dont tighten the LCA cams until the truck is back on the ground.
  7. Mar 13, 2019 at 8:58 AM
    #8327
    09TRDSport4x4
    Nick
    Southwest Ohio
    Hmm, that’s a shit ton easier than I thought. You think I’d be able to swap the top plate spacers after loosening the lower control arm and removing that top nut, then letting the spring and strut assembly slowly fall? Obviously, I’d have to remove the three nuts on the top plate studs but will I have enough room to get in there at that point?
  8. Mar 13, 2019 at 9:00 AM
    #8328
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    Yes. Eventually there will be no pressure from spring and you can leave the top mount just bolted in place if the spacer is to go on top of spring.
  9. Mar 13, 2019 at 9:01 AM
    #8329
    09TRDSport4x4
    Nick
    Southwest Ohio
    Perfect. This won’t be hard at all. Now I just need to find a jack that can actually get the front of the truck off the ground...
  10. Mar 13, 2019 at 9:03 AM
    #8330
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
  11. Mar 13, 2019 at 9:05 AM
    #8331
    dirty deeds
    Nick
    Eastern KY
    If you have real skids, just put the jack on the front skid. Centered, obviously, just past where it gets flat under the engine. 4x4 wood blocks are your friend too!
  12. Mar 13, 2019 at 9:07 AM
    #8332
    09TRDSport4x4
    Nick
    Southwest Ohio
    I’ve got the TRD skid plate on the front. Don’t know if I’d want to jack on that thing... I guess I could always remove it though. And hmm, I like that $60 jack. Might need to snatch one of those.
  13. Mar 13, 2019 at 9:08 AM
    #8333
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    You probably need to take skids off to get to LCA bolts anyway.
    And they are only $45 currently...get two!
    dirty deeds likes this.
  14. Mar 13, 2019 at 9:09 AM
    #8334
    09TRDSport4x4
    Nick
    Southwest Ohio
    And it looks like PepBoys is running some kind of promotion. I can get that thing for $45
    Haha, you beat me to it.
    CusterFan and iwashmycar like this.
  15. Mar 13, 2019 at 9:11 AM
    #8335
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    You will still need your standard floor jack to lower the spindle down slowly so you dont kill yourself with a spring FYI. So have one of those regardless.
  16. Mar 13, 2019 at 9:12 AM
    #8336
    09TRDSport4x4
    Nick
    Southwest Ohio
    It won’t let me change the quantity to 2...
    And oh yeah, I’ve got a floor jack I can use for the spindle. It just might require a block of wood to get up that high.
    And it’s been a long time since I worked on a car/truck by myself. Been too busy with the kids and the divorce to even attempt anything...
  17. Mar 13, 2019 at 9:13 AM
    #8337
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    Then their location only has one in stock. Might try another store if you can.
  18. Mar 13, 2019 at 9:20 AM
    #8338
    09TRDSport4x4
    Nick
    Southwest Ohio
    Looks like each location near me has one in stock. I reserved one but I guess I could make two stops.
  19. Mar 13, 2019 at 9:23 AM
    #8339
    dirty deeds
    Nick
    Eastern KY
    Yeah, don't do that lol. Use the 'tit' looking thing as the jack point then. My 885s are pretty stiff so I only get a few inches of droop taking the truck up in the air, don't remember that stock coil life.
  20. Mar 13, 2019 at 9:25 AM
    #8340
    09TRDSport4x4
    Nick
    Southwest Ohio
    I’m on 885s as well. And I know exactly what jack point you’re referring to. It’s just beyond the back of the skid plate.
