Cincinnati Area Thread (Tri-State, Ohio/Kentucky/Indiana)
Discussion in 'Ohio' started by Breezy, Nov 1, 2015.
  1. Mar 15, 2019 at 8:32 PM
    #8421
    09TRDSport4x4
    09TRDSport4x4 OCD Approved!
    Nick
    Southwest Ohio
    Hmm, I’m not usually a fan of aftermarket headlights. I tend to prefer retrofit OEM headlights but the newer LED technology is quite appealing.
  2. Mar 15, 2019 at 10:08 PM
    #8422
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    I ordered the aftermarket ones already and new tail lights.
    Wife went to bed and left me unsupervised with my phone.
    eBay and Amazon make it too easy.
  3. Mar 16, 2019 at 1:45 AM
    #8423
    09TRDSport4x4
    Nick
    Southwest Ohio
    I’m interested to see how they look in person.
  4. Mar 16, 2019 at 2:44 AM
    #8424
    Shearboy2005
    Shearboy2005 It can't stay tight if it's a liquid.
    Ky
    2015 TRD SPORT, 06 PreRunner
    Switched mine to led bulbs and thought I was to going break them before they snapped in.
    dre5491 likes this.
  5. Mar 16, 2019 at 10:10 AM
    #8425
    09TRDSport4x4
    Nick
    Southwest Ohio
  6. Mar 16, 2019 at 7:55 PM
    #8426
    09TRDSport4x4
    Nick
    Southwest Ohio
    So I’m about to order all the parts for the T4R/Lexus GX470 front brake upgrade and it’s got me thinking about how I want to go about installing all this stuff I’ve bought recently. I’m gonna lay out the plan I’ve got in my head below and some notes about a few things. Feel free to throw some wisdom or insight my way if you think I’d be better off doing things differently or in a different order.
    Day 1 (exact date still TBD):
    - T4R/Lexus GX470 front brake swap.
    - Full brake system bleed, including ABS module (requires a scan tool from what I’ve heard but helps with the squishy pedal feel)
    - Knock the rust off the rear drums, spray them them black (the dirty, burnt orange color just isn’t doing it for me)
    - Swap the 1” wheel spacers with a new set of 1.25” spacers
    Day 2 (exact date still TBD)
    - Remove the 1/4” top plate spacer from the driver’s side strut assembly, install 1/2” spacer
    - Install the 1/4” top plate spacer on the passenger side
    - Install SPC Upper Control Arms
    - Drive truck to shop and have the new 285s mounted and balanced
    - Get truck aligned
    Day 3 (could happen before or after the other two days)
    - Install Cali Raised Stealth Mount LED bar behind the lower grill
    - Wash the Truck and give exterior some much needed TLC
    Backstory on the front brake upgrade is long, but to keep it somewhat short, I’m about 15 months into a full OEM parts front brake job and I’ve had at least one warped rotor for the last few months. Had the pads and rotors changed originally because of a horrible squeak I was getting in reverse every morning. Turns out one of the pistons in my passenger front caliper is sticking and in addition to the wobble I feel when braking at higher speeds, the squeak has begun to return...
    In regards to day two, I’ve been chasing a random clunk in my front suspension over harsher bumps lately, so I’m still debating whether to replace the upper shock mounts with new hardware. I’m also going to test my lower ball joints for play and if needed, I may order new LCAs for one or both sides. I’d obviously like to avoid disassembling the strut assemblies and paying for LCAs but that damn clunk is annoying when it happens. I’ve already got a sway bar relocation kit installed (I will not be removing the front sway) and there are no signs of the OME springs hitting the stock UCAs but I read it could be the sway bar hitting the skid plate underneath. I’ll need to look around under there before I do any of this stuff to see if I can find any evidence of metal on metal contact.
    Also, I’m regards to the alignment, I’ve read a lot about how to set the UCAs and what to tell the alignment tech to do in order to maximize tire clearance at the rear of the front fender well but I’m all ears about ideal alignment specs when it’s done. Ideally, I can fit the 285/70/17 tires without a CMC but I’m aware that it may be unavoidable. I’m still researching the best alignment specs and how to go about setting things before letting a tech start changing things.
    dre5491 and EdinCincinnati like this.
  7. Mar 16, 2019 at 8:08 PM
    #8427
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    Doug at Tire Discounters in Mariemont is an excellent alignment tech. He has been aligning and realigning my truck for 3 years. If you want to fit 285s without doing the CMC he can do it as he has done so with mine. He understands having an adjustable upper control arm and how to set the lower cams for clearance of the tire rotation and then set the alignment from up top.
    Call ahead, set an appointment though. That’s a busy store.
    fleckosaurus and 09TRDSport4x4 like this.
  8. Mar 16, 2019 at 11:31 PM
    #8428
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    I only count four? :boink:
    My Name is Rahl and dirty deeds like this.
  9. Mar 17, 2019 at 12:37 AM
    #8429
    aphillips916
    aphillips916 Well-Known Member
    Aaron
    Winchester, Kentucky
    2018 Cement TRD Sport
    What’s up fellas, been here for a while as a shadow but wanting to get active. Live just outside of Lexington, but heard this forum is more active than them central KY thread. Hard with my schedule but I’d like to have more taco friends! Here’s my ‘18
  10. Mar 17, 2019 at 4:43 AM
    #8430
    09TRDSport4x4
    Nick
    Southwest Ohio
    Good point. I’ll need to buy a used one from bestusedtires.com to put on my spare. That is, if I want to deal with what’s required to make it fit underneath...
  11. Mar 17, 2019 at 4:44 AM
    #8431
    phishtaco
    phishtaco Well-Known Member
    Marty
    GX470 FJ40
    I’m far from a Tacoma expert but I know a little about t4r and gx470s. I think you would early 5th gen t4r or gx460 calipers. 4th gen t4r and gx470s are known for seizing.
  12. Mar 17, 2019 at 5:39 AM
    #8432
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    There's gonna be some sweet newly built trucks in here for the next couple wheeling trips! Cant wait to see you guys on the trail
    dre5491, tacofort and EdinCincinnati like this.
  13. Mar 17, 2019 at 6:20 AM
    #8433
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Shit man, I need to get out and see how these gears and locker do.
    My Name is Rahl likes this.
  14. Mar 17, 2019 at 8:01 AM
    #8434
    09TRDSport4x4
    Nick
    Southwest Ohio
    I’m buying aftermarket calipers from NAPA. Not looking to spend the money Toyota wants for even remanufactured calipers.
    It’s that or I could buy them used and rebuild them myself, but that’s just more time and effort.
  15. Mar 17, 2019 at 9:01 AM
    #8435
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Make sure whatever calipers you get fit inside your wheel. That's the biggest problem with brake upgrades on our trucks
  16. Mar 17, 2019 at 9:06 AM
    #8436
    09TRDSport4x4
    Nick
    Southwest Ohio
    Yep, I made sure the 4th Gen T4R upgrade would fit the stock TRD sport 17” wheels. Which makes sense, considering the T4R limited or whatever models had these calipers all came with 17” wheels. I’ve seen pictures of this exact setup inside a TRD SEMA wheel and reports of no fitment issues on the 17” Gen2 Sport wheels.
    With that said, I’m not sure if the 14WA calipers from the 5th Gen T4R will fit the stock 17” Sport wheels or not.
  17. Mar 17, 2019 at 9:09 AM
    #8437
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    Mostly you just have to be careful with 16" wheels, the 17s seem to be g2g
  18. Mar 17, 2019 at 9:22 AM
    #8438
    09TRDSport4x4
    Nick
    Southwest Ohio
    I’m curious about the 5th Gen T4R calipers now. Some quick research tells me most of the OEM parts list I have acquired for the 4th Gen setup would need to be updated... looks like at least the backing plate and the rotors are different. And I can always get stainless lines instead of OEM parts if I can’t find those part numbers too...
  19. Mar 17, 2019 at 10:42 AM
    #8439
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    I need new tie rod ends. Any recommendations or brands to stay away from?
  20. Mar 17, 2019 at 12:08 PM
    #8440
    Cfout4050
    Cfout4050 Active Member
    Chad
    19 trd Tacoma
    Stock as of March 3 18
    Is there a outing scheduled if so where and when ?
    Kinda like to try this out before I go ordering shit I don't need .
