Cincinnati Area Thread (Tri-State, Ohio/Kentucky/Indiana)
Discussion in 'Ohio' started by Breezy, Nov 1, 2015.
  1. May 19, 2019 at 9:09 AM
    #8901
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Mine is set +1degree but I don’t know which letter that corresponds to.
    How was getting those long bolts out?
  2. May 19, 2019 at 10:00 AM
    #8902
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Mine are set at D, 0°. Not moved them yet and haven't ponied up the money to pay $160 for the only alignment shop that will actually adjust on the UCA. Other shops only think they live and breathe at the LCA bolts so $60 does good enough.
  3. May 19, 2019 at 10:02 AM
    #8903
    dirty deeds
    Nick
    Eastern KY
    Those bolts were actually pretty easy for @beertimecontinuum and myself. Pair of longer flat jaw channel locks were handy for bending the metal out of the way. Just a tedious job since the battery and washer fluid resi had to be removed
    beertimecontinuum likes this.
  4. May 19, 2019 at 10:41 AM
    #8904
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Step no.1) Drink a beers of your choice.
  5. May 19, 2019 at 4:47 PM
    #8905
    09TRDSport4x4
    09TRDSport4x4 OCD Approved!
    Nick
    Southwest Ohio
    Getting the bolts out was a task to say the least. We did the same thing, using channel locks to bend the metal but the driver’s side bolt has so much corrosion on it that the nut wouldn’t come loose. We tried PB Blaster and a torch and it still wouldn’t budge with an impact gun. We had to use a long breaker bar and push like hell to move it 1/8th of a turn at a time. Finally got it off and had to use a punch to tap it out of the hole. On the passenger side we didn’t have as much corrosion but the fender metal was reinforced up near the power steering reservoir and wouldn’t bend as much. We didn’t remove the battery or the washer fluid reservoir. Neither one was really in the way. Just unhooked a few wiring loom clips and a bracket bolted under the battery.
    I’ve got mine set to E right now. And since we maxed the caster on the lowers (as far as they would go being slightly corroded) I’m going to stand next to the tech tomorrow and tell him to adjust camber on the top UCA bolt only and depending on where the caster is right now, make any tweaks down low. I’m just debating whether I need to set it to position D before he starts...
  6. May 20, 2019 at 2:06 PM
    #8906
    tacofort
    tacofort Well-Known Member
    Joe
    Cincinnati, OH
    2017 Toyota Tacoma TRD PRO, Automatic, Cement
    Adventure Trailers Tacoma Habitat Pelfreybilt Rock Sliders Line-X Pelfreybilt Pro mid, Gas, Exhaust Reroute Skids Hondo Unholey Dash mount Total Chaos Bed Stiffeners Redline Tuning Hood Lift Struts Weathertech Floor Liners
  7. May 20, 2019 at 5:16 PM
    #8907
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
  8. May 21, 2019 at 7:53 AM
    #8908
    dirty deeds
    Nick
    Eastern KY
  9. May 21, 2019 at 9:42 AM
    #8909
    09TRDSport4x4
    Nick
    Southwest Ohio
    Got the 285/70/17 tires mounted yesterday and got the truck aligned. Ended up using the D setting on the SPC UCA ball joint to get 3+ degrees of caster. The lower cams are set at max caster and all the adjustments were made at the UCA. Camber is as close to 0 as we could get it and toe is at about +3/32nd. I bought the one year alignment policy so I may have them tweak it in a few weeks using the lower control arm cams but for now it feels great and tracks straight. There’s a little bit of bump steer over harsh bumps at higher speeds but I guess that’s to be expected with close to 3” of lift and the larger, heavier tires.
    As for rubbing, the rear of the front tires doesn’t even come close to the cab mounts on a level surface and even during a hard turn over a curb, no rubbing in the back yet. However, the tires are definitely rubbing the front plastic fender liner on a full turn. I’ve still got the 1.25” spacers I need to install but I’m not sure if the extra ~7mm of negative offset will eliminate the rub on its own. I’m probably going to need to use a heat gun or even trim some plastic but I’d much rather mess with the front than the back so I’m happy.
  10. May 22, 2019 at 6:30 AM
    #8910
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
  11. May 24, 2019 at 6:44 AM
    #8911
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
  12. May 24, 2019 at 7:03 AM
    #8912
    Roll Tide
    Q
    01 T4R
    @mwc273 How did those tires do in the snow this year? Hard pack? Slush?
  13. May 27, 2019 at 12:45 PM
    #8913
    09TRDSport4x4
    Nick
    Southwest Ohio
    Well, I’m trying to install my 1.25” spacers but I can’t get the 1” spacer off the back left... it seems to be corroded to the hub and as you can probably see, I’ve sprayed it with PB Blaster and beat the hell out of it with a hammer...
    I even put all six lugs and the wheel back on the spacer (without it bolted to the hub) and tried to break it free. It won’t budge.
    Any advice?
  14. May 27, 2019 at 12:51 PM
    #8914
    dirty deeds
    Nick
    Eastern KY
    Bigger hammer. Or flat head or other prying instruments between spacer and hub. Or start beating the studs in to push spacer out
    KY_Rob likes this.
  15. May 27, 2019 at 1:05 PM
    #8915
    09TRDSport4x4
    Nick
    Southwest Ohio
    I tried to pound two different flat head screwdrivers behind the spacer and between it and the drum, that got me nowhere. But I could put the factory lug nuts on a few of the studs and start hitting them straight in against the drum and see if that gets it moving.
  16. May 27, 2019 at 1:06 PM
    #8916
    09TRDSport4x4
    Nick
    Southwest Ohio
    I thought about that too but this garage mechanic doesn’t have a functional torch laying around...
    dirty deeds likes this.
  17. May 27, 2019 at 1:31 PM
    #8917
    09TRDSport4x4
    Nick
    Southwest Ohio
    I found a small bottle of propane. It’s not getting hot enough...
  18. May 27, 2019 at 1:45 PM
    #8918
    09TRDSport4x4
    Nick
    Southwest Ohio
    Me: 1
    Spacer: 47
    I got angry and it paid off. After torching it for a bit I put the wheel back on using two of the lug nuts. Tightened them down then kicked the tire a few times and it finally popped off.
  19. May 27, 2019 at 1:46 PM
    #8919
    09TRDSport4x4
    Nick
    Southwest Ohio
    Now let’s just hope the other side won’t be as corroded... the fronts have been removed recently (thanks again @EdinCincinnati!) when we did the brake upgrade.
    dirty deeds and EdinCincinnati like this.
  20. May 27, 2019 at 2:33 PM
    #8920
    09TRDSport4x4
    Nick
    Southwest Ohio
    And the other side is corroded to the hub too...
    *Edited*
    Already got it off!
