Cincinnati Area Thread (Tri-State, Ohio/Kentucky/Indiana)
Discussion in 'Ohio' started by Breezy, Nov 1, 2015.
  1. Jun 3, 2019 at 9:33 AM
    #8941
    09TRDSport4x4
    09TRDSport4x4 OCD Approved!
    Nick
    Southwest Ohio
    I was just curious. I’m sitting on 885s at the lowest perch and, according to OME, they have the same spring rate as the 887. They’re just a bit shorter. I have the top plate spacers but that’s not going to help with total compression. Larger bump stops are a possibility but for me, adding any more lift is not. I don’t want to mess with the rear right now so I’m good where I’m at up front. I’ll have to take the truck into the woods and see what kind of trimming and/or hammering needs to be done to avoid rubbing. Right now my biggest concern are the tires. I drove it up to Lebanon last night to do some fishing and the tires are definitely not balanced properly... it’s super annoying to have my teeth chattering on the highway.
  2. Jun 3, 2019 at 9:42 AM
    #8942
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    You should look for some of these:
    Just a thin piece of plastic you put on the hub, then the spacer. Keeps the aluminum and steel from contacting.
  3. Jun 3, 2019 at 10:01 AM
    #8943
    Klgreen
    Klgreen New Member
    Kyle
    2015 Tacoma sr5 crew cab long bed
    None yet
    Dayton here just picked up a 2015 sat traded off a 2012 f150.
  4. Jun 3, 2019 at 10:31 AM
    #8944
    JohnnyRed
    JohnnyRed Well-Known Member
    Northern Kentucky
    2008 DCLB TRD Sport
    @dirty deeds - Lol true. That's an option, I kind of like the look of the factor flares and don't want to cut them in a way that it's visible.
    dirty deeds likes this.
  5. Jun 3, 2019 at 10:45 AM
    #8945
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Measure wheel center to fender to confirm lift #'s
    A little bit of pre-load doesn't really hurt... you actually need some to get effective use of your full range of travel, but more than 1/2" of pre-load on any 500+ lb spring will "ruin" your HS rebound damping.
    Also, a little bit of lift from the spring won't fix the issue, just decrease the frequency of occurrence.
    I think all the solutions have been identified... to prevent the issue completely, you should either limit uptravel or increase clearance from the fully compressed position to the fender.
    After watching your truck walk stuff, IMO adjusting your bump stops a little bit to prevent that last .5" of travel will work very well.
    IDK if you have them, but UCA's adjust your camber curve a bit, and can pull the tire in earlier in travel... but $$ and not certain victory.
    I gotta say I haven't taken my own advice here.
  6. Jun 3, 2019 at 10:49 AM
    #8946
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
  7. Jun 3, 2019 at 10:59 AM
    #8947
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
  8. Jun 3, 2019 at 11:32 AM
    #8948
    JohnnyRed
    Northern Kentucky
    2008 DCLB TRD Sport
    @Bandido - It's been so long since I was on stock suspension I forget my original numbers. From what I remember my original setup was about +2.25" and now on my new setup I gained an additional. ~.5" on top of that....but oh well. I do have SPC UCAs and could adjust the camber, I hadn't thought of that. After thinking through it I think the best options are to trim, or limit travel. I've been looking for a reason to get some superbumps, so this may be my excuse.
    @Caboose117 - Damnit! I wish that was around last year when I did my Total Chaos gussets....I like the Marlin so much more. I guess a part-out is necessary.
  9. Jun 3, 2019 at 12:10 PM
    #8949
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    It says in the post he put up that these will work in addition to your gussets
    Hell
    Mine are more overkill than the Tc ones and I’ll still likely be doing this one or similar
  10. Jun 3, 2019 at 12:29 PM
    #8950
    JohnnyRed
    Northern Kentucky
    2008 DCLB TRD Sport
    Good point...I missed that. He says:
    "If you already have aftermarket 1/4" thick cam tab gussets installed, then simply shave 1/8" off our Uprights and install to your frame like normal."
    I think our definition of "Simple" may be a bit different. Yes, the area circled in blue seems pretty simple to get a grinder into. The area circled in red....not so much.
  11. Jun 3, 2019 at 12:31 PM
    #8951
    My Name is Rahl
    Would probably have to use a die grinder on the red circled area.
  12. Jun 8, 2019 at 7:08 AM
    #8952
    MassAppeal16
    MassAppeal16 Well-Known Member
    Carrollton, KY
    17 TRD MGM DCSB
    Anyone around the Cincy area done the BHLM and feel froggy enough to do another set for me? I would pay of course.
  13. Jun 8, 2019 at 8:09 AM
    #8953
    NKYTaco
    NKYTaco Well-Known Member
    Brandon
    South Eastern Indiana
    2014 MGM TRD Pinstripe Edition
    I live in Glencoe and would be more than happy to help you.
  14. Jun 10, 2019 at 9:42 AM
    #8954
    Roll Tide
    Q
    01 T4R
    We need a wrench-a-thon scheduled....
    I'd love to do a bunch of shit to the HoRunner.....but I dont have the balls to do it myself....
    Plus, I'm going to be ordering the suspension, all new bushings, etc. Would love to add a retrofit headlight item to that list.
    (I'm pretty confident in installing the suspension. I simply like having other people there who are familiar so that they can make observations or suggestions that I havent considered.)
    When it comes to retrofitting headlights, the only thing really holding me back is installing the projectors. My OCD kicks in which seems to send an automating activation to my anxiety concerning making sure they are straight and aligned properly. Plus, all the electrical stuff is supposed to be plug and play, but I'm telling you now, there will be an issue somewhere along the way. HAHAHA.
    rdpoe likes this.
  15. Jun 10, 2019 at 9:44 AM
    #8955
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    You could've joined me last week and i would've let you turn all the wrenches you wanted. 2 New Axles, UCA's, Brake Caliper, and now waiting on the tie rods to arrive.
  16. Jun 10, 2019 at 9:45 AM
    #8956
    Roll Tide
    Q
    01 T4R
    Thanks for reminding me that I probably need to do all new front end assemblies as well..................................................................FAK.
  17. Jun 11, 2019 at 8:15 AM
    #8957
    09TRDSport4x4
    Nick
    Southwest Ohio
    I’m down for a wrench-a-thon. I’ve still got a handful of small things I’d like to do to my truck, including rear stainless lines (with new hardlines, fuck you corrosion) and an LED light bar install.
    As for retrofits, I’ve had headlights apart numerous times in my day but I’ve yet to attempt to install a set of projectors for the exact reason you mentioned. That’s why I just paid to have someone else do it and couldn’t be happier with my headlights right now. But, with that said, I’m about as OCD as it comes, so I’d be happy to assist with lining them up and making sure everything is straight. The wiring really should be plug and play unless it’s a cheap kit. The Morimoto kit I installed with my retrofits was cake. The hardest part for me was hiding all the wires and mounting the ballasts out of sight.
    Roll Tide likes this.
  18. Jun 11, 2019 at 8:24 AM
    #8958
    Roll Tide
    Q
    01 T4R
    Another issue I have is seeing all the JB Weld slathered on the backs of these headlights.
    I understand it is a fix, but It just looks bad. I know, its on a part you never see. I get it.
    The other issue I have is the fact that the kits and parts are about $300 (give or take $100-$150 depending on additions or quality improvements.) So, for me to pay $800 for someone else to do it....seems extreme. Especially when there is a collective group of fellas who are intelligent and able to help. I'll have to see if I can find some junk yard headlights and maybe piece together a retrofit cheaply. Just for practice.
  19. Jun 11, 2019 at 9:15 AM
    #8959
    iwashmycar
    iwashmycar a lot
    Adam
    Lewis Center, Ohio
    07 FJ 4x4 AT
    33's | 3" | skids | rails | dent | CB | lights | dingus
    Shit tons of JB Weld > leaks.
  20. Jun 11, 2019 at 9:30 AM
    #8960
    Roll Tide
    Q
    01 T4R
    Oh, I get the point.
    Looks like shit though.
    iwashmycar[QUOTED] likes this.
