Cincinnati Area Thread (Tri-State, Ohio/Kentucky/Indiana)
Discussion in 'Ohio' started by Breezy, Nov 1, 2015.
  1. Jul 31, 2019 at 12:16 PM
    #9141
    09TRDSport4x4
    09TRDSport4x4 OCD Approved!
    Nick
    Southwest Ohio
    Ok wise, local Tacoma owners, I need some help...
    Recently my truck has started vibrating my teeth loose on the highway and I’m trying to decide where to start diagnosing the issue. At about 50 mph and all the way up to 80+ the truck is almost unbearable on the highway. I can sometimes feel the vibration at lower speeds but it gets really bad above 50 mph. It doesn’t change when braking or when I let off the gas pedal and it’s worse on some roads than others. It’s not a side to side shimmy and I don’t really feel it in the steering wheel, it’s more like the entire cab is shaking (I can feel it in my seat, the center console, the pedals and in the back floor board). The problem started out slowly (originally from 50 mph to about 60 mph) but has gotten worse with time. As far as I can tell, it started around the time I had my 285/70/17 C load rating BFG KO2s mounted and since then I’ve done the following:
    - had the tires balanced three times, most recently by Discount Tire using the road force machine. None of the tires showed any major abnormalities and they balanced very well for AT tires according to the tech. (no change after each balancing).
    - swapped wheel spacers, went from 1” to 1.25” which didn’t change the vibration at all.
    - torqued and re-torqued the wheel spacer bolts and the lug nuts in a star pattern, tightening all six on each wheel to 60 ft pounds first, then to 85 ft pounds. Again, no change.
    More details... the truck is lifted about three inches, has the ECGS needle bearing replacement and I have a custom one piece rear drive shaft. The front wheel bearings are relatively new, only been on the truck for 15k miles or so. The shocks all have about 45k miles on them. The SPC UCAs and tires are brand new (less than 2k miles) and the LCAs, lower ball joints and tie rod ends are all OEM. The truck has 109k miles on it right now.
    At this point, I’m leaning towards it being rear drive shaft related (maybe a bad U joint or the one piece shaft is out of balance), rear wheel bearings (no humming or noise at all though) or potentially something in the front suspension. I wouldn’t know where to start with a front suspension problem but the truck has felt a bit sloppy on the front drivers side ever since the new UCAs went in. I’m open to any and all suggestions because right now it’s hard to even drive the truck on the highway and I’m getting to the point where I’m considering selling it and moving on to something newer. Let me know what you guys think. Thanks!
  2. Jul 31, 2019 at 12:26 PM
    #9142
    KY_Rob
    KY_Rob Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    If it’s a rear drive shaft, you should be able to shake it from underneath and get play at the U-joints (if they’re that bad).
    Don’t have a loose cab mount? Transfer case is mounted right? No loose/missing bolts or broken welds on the frame or cross members? Leaf spring shackles are all tight? LCA bushings ok? Can’t think of anything else off the top of my head...
  3. Jul 31, 2019 at 12:35 PM
    #9143
    09TRDSport4x4
    Nick
    Southwest Ohio
    I was thinking about removing the rear shaft and driving the truck on the highway in 4H (essentially front wheel drive) to see if the vibration goes away. That should at least identify or eliminate the rear drive shaft as the culprit.
    Other than that, I feel like I’d be guessing at it being anything else.
    rdpoe and tacofort like this.
  4. Jul 31, 2019 at 12:44 PM
    #9144
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Who made these lights?
  5. Jul 31, 2019 at 12:46 PM
    #9145
    KY_Rob
    Rob
    North East Ohio
    Once upon a time, I drove a ‘76 CJ5 around like that for 2 weeks. Just be especially careful making turns on pavement.
  6. Jul 31, 2019 at 1:08 PM
    #9146
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    2019 TRD OR DCLB (Sold), Honda Civic TRD PRO
    Subd for tree fort stickers
    tacofort likes this.
  7. Jul 31, 2019 at 1:09 PM
    #9147
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Theres a *started* 1st gen double cab for a great price near me. if one of you buys it then I can stop almost buying it.
    @Breezy
    @tacofort - to hold you over a couple years until the 4th gen
    On FB marketplace.
    rdpoe likes this.
  8. Jul 31, 2019 at 1:17 PM
    #9148
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Does the steering wheel shake more or your ass in the seat?
    & how many miles on your driveshaft?
  9. Jul 31, 2019 at 1:18 PM
    #9149
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    That green one? I’ve been eyeing it too
    Bandido[QUOTED] and tacofort like this.
  10. Jul 31, 2019 at 1:20 PM
    #9150
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Yeah.
    I'm legit considering buying it for the GF.
    Also trying to talk some car friends into getting it.
    .... I need a fuckin DD
    tacofort and rdpoe[QUOTED] like this.
  11. Jul 31, 2019 at 1:21 PM
    #9151
    09TRDSport4x4
    Nick
    Southwest Ohio
    It’s more in the cab/seat than in the steering wheel. My teeth will literally chatter if I let them...
  12. Jul 31, 2019 at 1:24 PM
    #9152
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    Unlikely to be in the front end then. But based on your mileage I'd say you are due for some LBJ's.
    How many miles on your Driveshaft?
    And how frequently do you grease the U-joints?
  13. Jul 31, 2019 at 1:32 PM
    #9153
    09TRDSport4x4
    Nick
    Southwest Ohio
    The custom one piece rear driveshaft went in about 20k to 25k miles ago and I don’t know if they greased the U joints when they built it. All I know is they used as much of the OEM two piece shaft as they could to construct the one piece. I have not greased the U joints since it was installed. But the truck did drive very smooth when it was installed.
  14. Jul 31, 2019 at 1:39 PM
    #9154
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    I would recommend a greasing... and if I read that right, that means you likely have oem U joints in there still?
    My Name is Rahl likes this.
  15. Jul 31, 2019 at 1:41 PM
    #9155
    09TRDSport4x4
    Nick
    Southwest Ohio
    Not entirely sure, but most likely. I’d have to crawl under there and see what they look like. I also don’t own a grease gun so... I’ll have to either buy one or take it somewhere.
  16. Jul 31, 2019 at 1:46 PM
    #9156
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    The new ones I just installed or the projectors I just removed?
  17. Jul 31, 2019 at 1:46 PM
    #9157
    TireFire
    Olympic Peninsula
    The ones you removed and want to sell. I like them but I’m in WA
  18. Jul 31, 2019 at 1:47 PM
    #9158
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    I’m too lazy to ship.
  19. Jul 31, 2019 at 1:50 PM
    #9159
    09TRDSport4x4
    Nick
    Southwest Ohio
    I’ll ship them for you if you can fix this stupid vibration in my truck.
  20. Jul 31, 2019 at 1:53 PM
    #9160
    tacofort
    tacofort Well-Known Member
    Joe
    Cincinnati, OH
    2017 Toyota Tacoma TRD PRO, Automatic, Cement
    Adventure Trailers Tacoma Habitat Pelfreybilt Rock Sliders Line-X Pelfreybilt Pro mid, Gas, Exhaust Reroute Skids Hondo Unholey Dash mount Total Chaos Bed Stiffeners Redline Tuning Hood Lift Struts Weathertech Floor Liners
    The green one with arb bumper and 210k miles. Looks clean
    Bandido and rdpoe like this.
